Experimental Nix flake ====================== The repository contains an experimental `Nix flake`_ for reproducibly building the default |TF-A| configuration, which currently builds an AArch64 release for the FVP platform, and supports AArch64 and x86-64 hosts running Linux or macOS. .. note:: The flake's interface is preliminary and is likely to change. Installing Nix -------------- On Linux and macOS, a multi-user installation can be performed with the official installer: .. code:: shell curl -L https://nixos.org/nix/install | sh -s -- --daemon Start a new shell after the installer finishes, then confirm that Nix is available: .. code:: shell nix --version See the `Nix download page`_ for other installation methods and platform- specific instructions. Enabling flakes --------------- Enable the ``nix-command`` and ``flakes`` experimental features by adding the following line to ``~/.config/nix/nix.conf``: .. code:: text experimental-features = nix-command flakes The same setting can instead be added to ``/etc/nix/nix.conf`` for all users. To try the flake without changing either configuration file, pass the features on the command line: .. code:: shell nix build --extra-experimental-features "nix-command flakes" Building TF-A ------------- From the root of the |TF-A| repository, run: .. code:: shell nix build On success, the ``result`` symbolic link should contain: .. code:: text result/bl1.bin result/bl2.bin result/bl31.bin Useful commands --------------- The following commands inspect and validate the flake or format its Nix files: .. code:: shell nix flake show nix flake check nix fmt **/*.nix Add ``--print-build-logs`` to ``nix build`` to display the complete build log. Updating the pinned dependencies with ``nix flake update`` changes ``flake.lock`` and should be committed and reviewed like any other source change. Some Git worktree configurations cannot currently be read by Nix's Git implementation. If Nix reports an unsupported Git repository extension, use an explicit path flake reference: .. code:: shell nix build "path:${PWD}" -------------- *Copyright (c) 2026, Arm Limited. All rights reserved.* .. _Nix flake: https://nix.dev/concepts/flakes.html .. _Nix download page: https://nixos.org/download/
