Advisory TFV-14 (CVE-2026-34879) ================================ +----------------+-----------------------------------------------------------------+ | Title | BL1 FWU range-check mismatch in FWU_SMC_IMAGE_COPY can cause | | | out-of-range memory access. | +================+=================================================================+ | CVE ID | `CVE-2026-34879`_ | +----------------+-----------------------------------------------------------------+ | Date | Reported on 16 Jan 2026 | +----------------+-----------------------------------------------------------------+ | Versions | TF-A releases with BL1 FWU mode enabled prior to the fixes | | Affected | in `48739`_ and `48740`_. | +----------------+-----------------------------------------------------------------+ | Configurations | Platforms that enable BL1 FWU mode and expose | | Affected | FWU_SMC_IMAGE_COPY to the Normal World. | +----------------+-----------------------------------------------------------------+ | Impact | Denial of Service (secure world data abort / reboot loop). | +----------------+-----------------------------------------------------------------+ | Fix Version | `48739`_ "fix(bl1): harden FWU copy/auth overflow checks" | | | `48740`_ "fix(arm): harden FWU address range checks" | +----------------+-----------------------------------------------------------------+ | Credit | Prasanth Sundararajan | | | https://www.linkedin.com/in/prasanthsundararajan/ | +----------------+-----------------------------------------------------------------+ Description ----------- In BL1 Firmware Update (FWU) mode, the FWU_SMC_IMAGE_COPY path validated image ranges using an overflow check based on (size - 1) but then consumed the full block size in subsequent range checks and memcpy operations. This created a mismatch where certain malformed requests could pass validation and later trigger a memcpy from an invalid or unmapped address. A compromised Normal World component can issue a malformed FWU_SMC_IMAGE_COPY request while the device is in FWU mode, pass validation, and cause BL1 to attempt to copy from an invalid address. In testing, this results in a BL1 data abort and can lead to a secure-side reboot loop (availability impact). Exploitability Details ---------------------- This issue is exploitable only when the device is running in BL1 FWU mode and the `FWU_SMC_IMAGE_COPY` interface is reachable from the Normal World. An attacker needs control of a Normal World component capable of issuing SMC calls in FWU mode (for example, a compromised bootloader, recovery image, or update agent). No secure-world code execution is required; the attack is performed entirely through crafted FWU requests. The attacker submits a request with carefully chosen source address and size parameters that pass the legacy range validation but produce a different effective range when the copy occurs. Because the copy uses the full block size, BL1 attempts to read from an invalid or unmapped address, resulting in a secure-world data abort. In practice this yields a denial of service in FWU mode, often observed as a secure-side reboot loop. Mitigation and Recommendations ------------------------------ The issue is fixed by making overflow and range validation match the actual block size used by bl1_plat_mem_check() and memcpy(), and by validating end-exclusive ranges computed safely from (base + size). Users should apply the fixes in the commits referenced below and ensure that all TF-A builds enabling BL1 FWU mode include these changes. .. _CVE-2026-34879: https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2026-34879 .. _48739: https://review.trustedfirmware.org/c/TF-A/trusted-firmware-a/+/48739 .. _48740: https://review.trustedfirmware.org/c/TF-A/trusted-firmware-a/+/48740
