12. Architecture Features
The Arm architecture evolves through versioning, with new architectural features being introduced almost every year listed in Feature_description. While most of these features require no control at EL3, some demand explicit configuration of EL3 control registers to enable their use at lower Exception Levels. For features with EL3 controls, it is relatively straightforward to examine the code and determine whether TF-A support them. However, for features that are transparent to EL3, it is more challenging to confirm whether they have been analyzed and verified as not requiring changes in TF-A.
This document serves as a central reference point to track and clarify the support status of architectural features within TF-A.
This document organizes features according to the yearly updates, while the specific architecture versions (8.X, 9.X) to which they apply can be found in Feature_description
Status legend —
  • OK: TF-A has explicit support;
  • NA: Transparent from EL3 (no EL3 changes required);
  • NO: Analyzed but decided not to implement;
  • WIP: Implementation in progress;
  • (empty): Not analyzed.
12.1. 2025 Extensions
Feature
Status
FEAT_GCIE
OK
FEAT_GCIE_LEGACY
NA
FEAT_F16F32DOT
NA
FEAT_F16F32MM
NA
FEAT_F16MM
NA
FEAT_SVE_B16MM
NA
FEAT_SME2p3
NA
FEAT_MTE_EIRG
NA
FEAT_MTETC
NA
FEAT_SVE2p3
NA
FEAT_SCR2
FEAT_LSCP
NA
FEAT_MPAMv2_VID
NA
FEAT_MPAMv2_MSC
NA
FEAT_MPAMv2_MSC_MON_SEC
NA
FEAT_MPAMv2_ALT_ID
NA
FEAT_MPAMv2
FEAT_FDIT
FEAT_CMH
NA
FEAT_EAESR
NA
FEAT_TLBID
FEAT_SRMASK2
FEAT_BBML3
NA
FEAT_NV3
FEAT_PAuth_EnhCtl
FEAT_LORRL
NA
12.2. 2024 Extensions
Feature
Status
FEAT_PMUv3_EXTPMN
NA
FEAT_SPEv1p5
OK
FEAT_SPE_EXC
OK
FEAT_SPE_nVM
OK
FEAT_TRBEv1p1
NA
FEAT_TRBE_EXC
OK
FEAT_SME_MOP4
NA
FEAT_SME_TMOP
NA
FEAT_PoPS
NA
FEAT_SME2p2
NA
FEAT_CMPBR
NA
FEAT_SSVE_AES
NA
FEAT_RME_GPC3
WIP
FEAT_RME_GDI
OK
FEAT_SVE2p2
NA
FEAT_SSVE_BitPerm
NA
FEAT_SSVE_FEXPA
NA
FEAT_SVE_AES2
NA
FEAT_LSFE
NA
FEAT_FPRCVT
NA
FEAT_SVE_F16F32MM
NA
FEAT_F8F16MM
NA
FEAT_F8F32MM
NA
FEAT_SVE_BFSCALE
NA
FEAT_OCCMO
NA
FEAT_LS64WB
NA
FEAT_AMU_EXTACR
NA
FEAT_MPAM_MSC_DOMAINS
NA
FEAT_MPAM_MSC_DCTRL
NA
FEAT_MPAM_PE_BW_CTRL
OK
FEAT_PCDPHINT
NA
FEAT_SRMASK
OK
FEAT_IDTE3
OK
FEAT_UINJ
OK
FEAT_NV2p1
NA
FEAT_LSUI
NA
12.3. 2023 Extensions
Feature
Status
FEAT_E2H0
NA
FEAT_SME_LUTv2
NA
FEAT_LUT
NA
FEAT_FAMINMAX
NA
FEAT_FPMR
OK
FEAT_FP8
NA
FEAT_FP8FMA
NA
FEAT_SSVE_FP8FMA
NA
FEAT_FP8DOT4
NA
FEAT_SSVE_FP8DOT4
NA
FEAT_FP8DOT2
NA
FEAT_SSVE_FP8DOT2
NA
FEAT_SME_F8F16
NA
FEAT_SME_F8F32
NA
FEAT_CPA
NA
FEAT_CPA2
OK
FEAT_STEP2
OK
FEAT_BWE2
NA
FEAT_SPE_FPF
NA
FEAT_SPE_EFT
NA
FEAT_PMUv3_TH2
NA
FEAT_SPMU2
NA
FEAT_E3DSE
FEAT_PMUv3_SME
NA
FEAT_SPE_SME
NA
FEAT_SPE_ALTCLK
NA
FEAT_HDBSS
OK
FEAT_HACDBS
OK
FEAT_TLBIW
NA
FEAT_ASID2
NA
FEAT_RME_GPC2
OK
FEAT_FGWTE3
OK
FEAT_PAuth_LR
OK
FEAT_ETS3
NA
12.4. 2022 Extensions
Feature
Status
FEAT_BWE
NA
FEAT_ADERR
OK
FEAT_ANERR
OK
FEAT_DoubleFault2
FEAT_PFAR
OK
FEAT_RASv2
OK
FEAT_CSSC
NA
FEAT_RPRFM
NA
FEAT_PRFMSLC
NA
FEAT_SPECRES2
FEAT_CLRBHB
Ok
FEAT_ECBHB
NA
FEAT_SME2p1
NA
FEAT_SME_F16F16
NA
FEAT_SVE_B16B16
NA
FEAT_SME_B16B16
NA
FEAT_FGT2
OK
FEAT_MTE4
NA
FEAT_MTE_CANONICAL_TAGS
NA
FEAT_MTE_NO_ADDRESS_TAGS
NA
FEAT_MTE_TAGGED_FAR
NA
FEAT_MTE_PERM
NA
FEAT_MTE_STORE_ONLY
NA
FEAT_ITE
NA
FEAT_TRBE_EXT
NA
FEAT_TRBE_MPAM
FEAT_ETEv1p3
NA
FEAT_GCS
OK
FEAT_CHK
NA
FEAT_SPE_DPFZS
NA
FEAT_SPE_CRR
NA
FEAT_EBEP
OK
FEAT_SEBEP
NO
FEAT_PMUv3_SS
FEAT_SPMU
FEAT_PMUv3_ICNTR
FEAT_PMUv3p9
OK
FEAT_SVE2p1
NA
FEAT_Debugv8p9
OK
FEAT_ABLE
NA
FEAT_PCSRv8p9
NA
FEAT_LRCPC3
NA
FEAT_SPEv1p4
NA
FEAT_SPE_FDS
OK
FEAT_PMUv3_EDGE
NA
FEAT_D128
OK
FEAT_AIE
OK
FEAT_S1PIE
OK
FEAT_ATS1A
NA
FEAT_S1POE
OK
FEAT_S2PIE
OK
FEAT_S2POE
OK
FEAT_SYSREG128
OK
FEAT_SYSINSTR128
NA
FEAT_LSE128
NA
FEAT_HAFT
NA
FEAT_THE
OK
FEAT_LVA3
NA
FEAT_MTE_ASYNC
NA
FEAT_EDHSR
NA
FEAT_AMU_EXT64
NA
12.5. 2021 Extensions
Feature
Status
FEAT_SME2
OK
FEAT_MEC
OK
FEAT_BRBEv1p1
OK
FEAT_CMOW
NA
FEAT_Debugv8p8
NA
FEAT_HBC
NA
FEAT_MOPS
OK
FEAT_NMI
OK
FEAT_SPEv1p3
NA
FEAT_TIDCP1
NA
FEAT_PMUv3_TH
NA
FEAT_PMUv3p8
NA
FEAT_SCTLR2
OK
FEAT_TCR2
OK
FEAT_PMUv3_EXT64
NA
12.6. 2020 Extensions
Feature
Status
FEAT_EBF16
NA
FEAT_ETEv1p1
NA
FEAT_HCX
OK
FEAT_PAN3
OK
FEAT_WFxT
NA
FEAT_XS
NO
FEAT_AFP
NA
FEAT_RPRES
NA
FEAT_LPA2
NO
FEAT_LS64
NA
FEAT_LS64_V
NA
FEAT_LS64_ACCDATA
OK
FEAT_MTE3
NA
FEAT_MTE_ASYM_FAULT
NA
FEAT_SPEv1p2
OK
FEAT_SPE_FnE
NA
FEAT_SPE_PBT
OK
FEAT_PMUv3p7
OK
12.7. The ENABLE_FEAT mechanism
The Arm architecture defines several architecture extension features, named FEAT_xxx in the architecure manual. Some of those features require setup code in higher exception levels, other features might be used by TF-A code itself.
Most of the feature flags defined in the TF-A build system are allowed to take the values 0, 1 or 2, with the following meaning:
ENABLE_FEAT_* = 0: Feature is unconditionally disabled at compile time.
ENABLE_FEAT_* = 1: Feature is unconditionally enabled at compile time.
ENABLE_FEAT_* = 2: Feature support is compiled in, but only enabled if the
                   feature present at runtime.
When setting the flag to 0, the feature is disabled during compilation, and the compiler’s optimization stage and the linker will try to remove as much of this code as possible.
If it is defined to 1, the code will use the feature unconditionally, so the CPU is expected to support that feature. The FEATURE_DETECTION debug feature, if enabled, will verify this.
If the feature flag is set to 2, support for the feature will be compiled in, but its existence will be checked at runtime, so it works on CPUs with or without the feature. This is mostly useful for platforms which either support multiple different CPUs, or where the CPU is configured at runtime, like in emulators.
12.8. Adding support for a new feature
Adding support for a feature is required when:
  1. a feature is added to the architecture and it includes controls at EL3
  2. a feature is to be used by EL3 itself
  3. EL3 wants to hide a feature from lower ELs (eg. with FEAT_IDTE3)
The following is a checklist with guidance on what to do to add a new feature, in this case a fictional FEAT_ABC. This is not an exhaustive list on how to do this, so please consult with previous such patches and/or maintainers. Please consult the Arm ARM on any specifics about the feature itself. You can speed this process up by using the new-cpu-feature agent skill.
  • Add a feature flag to the build system.
    • The flag’s name should be in the form ENABLE_FEAT_ABC.
    • Add it to the assert_numerics and add_defines lists in the Makefile.
    • Add a default of 0 for it in make_helpers/defaults.mk.
    • If the feature is listed as mandatory from a certain revision of the architecture, add it to the appropriate list in make_helpers/arch_features.mk.
    • Add any constraints in make_helpers/constraints.mk. This will usually be other features which this feature depends on or is incompatible with and can be found in the main description of the feature in the Arm ARM.
  • Create a macro for the feature in include/arch/aarch64/arch_features.h and add it to the appropriate list to register with other frameworks. If the feature doesn’t neatly fit in the standard pattern, it can be progressively unravelled.
    • In rare occasions, the feature must be checked in assembly. A is_feat_abc_present_asm macro must be added to include/lib/cpus/aarch64/cpu_macros.S.
  • Add support for the feature. This will be very feature specific and exact code will depend on why support is being added. Usually, support will be a few lines in lib/el3_runtime/aarch64/context_mgmt.c. Some common things to do include:
    • If support requires more extensive code sequences, consider adding them to a file in lib/extensions/abc/. Functions in this file must be named similar to other features. Those are likely to be abc_enable(), abc_enable_el3(), or abc_disable(). Naming depends on the call site.
  • If the feature introduces SCR_EL3, MDCR_EL3, or CPTR_EL3 controls for lower ELs, access must be enabled for at least NS world, preferably all worlds by setting/clearing the bit in the context copy of this register.
  • If the feature introduces any control bits in SCR_EL3, MDCR_EL3, CPTR_EL3, or MPAM3_EL3, those must be added to the appropriate list in include/services/arm_arch_svc.h to register with ARCH_FEATURE_AVAILABILITY. This must also be done in the test_smccc_arch_feature_availability test in TFTF, otherwise CI will fail.
  • If the feature introduces any bits in PSTATE, those should be added to create_spsr() in bl31/bl31_traps.c.
  • If the feature comes with lower EL registers:
    • those should be context switched if enabling the feature for multiple worlds.
    • if these are EL2 control registers, consider their fields’ reset values. If they can reset to a value that would make a field active (like enabling a trap), a safe inactive reset value should be added to setup_el2_context() in lib/el3_runtime/aarch64/context_mgmt.c.
  • Consider whether the feature introduces any potential side channels and how to close them.
  • Add documentation in docs/getting_started/build-options.rst. This should include a brief description of what the enablement does, what values the flag can take, the default, and that it conforms to the ENABLE_FEAT mechanism. Adding feature enablement that does not conform to this mechanism is only done in exceptional cases. You should also update the list of features at the top of this file.
    • Update the field in the table above.
  • Enable the feature for dynamic platforms in make_helpers/all_features.mk, setting it to 2 (FEAT_STATE_CHECKED).
  • Finally, do all of this in a single commit. Include the following information: - a brief description of the feature - any tradeoffs that the implementation makes that aren’t just the obvious - the version of the Arm ARM used (and link if another document)
  • If the feature is optional, enable it in CI in the “allconfig” fragments. Those currently happens in a list at the top of model/base-aemva-common.sh. Mandatory features are expected to be covered by the architecture revision passed to the model.
  • Optionally, although recommended, is to add a test in TFTF. This should only be done if there are observable effects from lower ELs like register traps. It is not necessary to add a test for functionality that does not have EL3 involvement (eg. whether a new instruction that cannot trap works).
