4.24. DebugFS interface
The optional DebugFS interface is accessed through a Vendor specific EL3 service. Refer to the component documentation for details.
String parameters are passed through a shared buffer using a specific union:
union debugfs_parms {
struct {
char fname[MAX_PATH_LEN];
} open;
struct mount {
char srv[MAX_PATH_LEN];
char where[MAX_PATH_LEN];
char spec[MAX_PATH_LEN];
} mount;
struct {
char path[MAX_PATH_LEN];
dir_t dir;
} stat;
struct {
char oldpath[MAX_PATH_LEN];
char newpath[MAX_PATH_LEN];
} bind;
Format of the dir_t structure as such:
typedef struct {
char name[NAMELEN];
long length;
unsigned char mode;
unsigned char index;
unsigned char dev;
qid_t qid;
} dir_t;
Identifiers
SMC_OK |
0 |
SMC_UNK |
-1 |
DEBUGFS_E_INVALID_PARAMS |
-2 |
MOUNT |
0 |
CREATE |
1 |
OPEN |
2 |
CLOSE |
3 |
READ |
4 |
WRITE |
5 |
SEEK |
6 |
BIND |
7 |
STAT |
8 |
INIT |
10 |
VERSION |
11 |
4.24.1. MOUNT
4.24.1.1. Description
This operation mounts a blob of data pointed to by path stored in src, at filesystem location pointed to by path stored in where, using driver pointed to by path in spec.
4.24.1.2. Parameters
uint32_t |
FunctionID (0x87000010 / 0xC7000010) |
uint32_t |
4.24.1.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if mount operation failed |
4.24.2. OPEN
4.24.2.1. Description
This operation opens the file path pointed to by fname.
4.24.2.2. Parameters
uint32_t |
uint32_t |
uint32_t |
mode |
mode can be one of:
enum mode {
O_READ = 1 << 0,
O_WRITE = 1 << 1,
O_RDWR = 1 << 2,
O_BIND = 1 << 3,
O_DIR = 1 << 4,
O_STAT = 1 << 5
4.24.2.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if open operation failed |
uint32_t |
w1: file descriptor id on success. |
4.24.3. CLOSE
4.24.3.1. Description
This operation closes a file described by a file descriptor obtained by a previous call to OPEN.
4.24.3.2. Parameters
uint32_t |
uint32_t |
uint32_t |
File descriptor id returned by OPEN |
4.24.3.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if close operation failed |
4.24.4. READ
4.24.4.1. Description
This operation reads a number of bytes from a file descriptor obtained by a previous call to OPEN.
4.24.4.2. Parameters
uint32_t |
uint32_t |
uint32_t |
uint32_t |
Number of bytes to read |
4.24.4.3. Return values
On success, the read data is retrieved from the shared buffer after the operation.
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if read operation failed |
uint32_t |
w1: number of bytes read on success. |
4.24.5. SEEK
4.24.5.1. Description
Move file pointer for file described by given file descriptor of given offset related to whence.
4.24.5.2. Parameters
uint32_t |
uint32_t |
uint32_t |
sint32_t |
offset in the file relative to whence |
uint32_t |
whence |
whence can be one of:
KSEEK_SET |
0 |
KSEEK_CUR |
1 |
KSEEK_END |
2 |
4.24.5.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if seek operation failed |
4.24.6. BIND
4.24.6.1. Description
Create a link from oldpath to newpath.
4.24.6.2. Parameters
uint32_t |
uint32_t |
4.24.6.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if bind operation failed |
4.24.7. STAT
4.24.7.1. Description
Perform a stat operation on provided file name and returns the directory entry statistics into dir.
4.24.7.2. Parameters
uint32_t |
uint32_t |
4.24.7.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if stat operation failed |
4.24.8. INIT
4.24.8.1. Description
Initial call to setup the shared exchange buffer. Notice if successful once, subsequent calls fail after a first initialization. The caller maps the same page frame in its virtual space and uses this buffer to exchange string parameters with filesystem primitives.
4.24.8.2. Parameters
uint32_t |
uint32_t |
uint64_t |
Physical address of the shared buffer. |
4.24.8.3. Return values
int32_t |
w0 == SMC_OK on success w0 == DEBUGFS_E_INVALID_PARAMS if already initialized, or internal error occurred. |
4.24.9. VERSION
4.24.9.1. Description
Returns the debugfs interface version if implemented in TF-A.
4.24.9.2. Parameters
uint32_t |
uint32_t |
4.24.9.3. Return values
int32_t |
w0 == SMC_OK on success w0 == SMC_UNK if interface is not implemented |
uint32_t |
w1: On success, debugfs interface version, 32 bits value with major version number in upper 16 bits and minor version in lower 16 bits. |
CREATE(1) and WRITE (5) command identifiers are unimplemented and return SMC_UNK.
Copyright (c) 2024, Arm Limited and Contributors. All rights reserved.
