10.4. DRTM Proof of Concept
Dynamic Root of Trust for Measurement (DRTM) begins a new trust environment by measuring and executing a protected payload. The architectural requirements and formal definition of DRTM for Arm-based systems are detailed in the DRTM Architecture for Arm
Static Root of Trust for Measurement (SRTM)/Measured Boot implementation, currently used by TF-A covers all firmwares, from the boot ROM to the normal world bootloader. As a whole, they make up the system’s TCB. These boot measurements allow attesting to what software is running on the system and enable enforcing security policies.
As the boot chain grows or firmware becomes dynamically extensible, establishing an attestable TCB becomes more challenging. DRTM provides a solution to this problem by allowing measurement chains to be started at any time. As these measurements are stored separately from the boot-time measurements, they reduce the size of the TCB, which helps reduce the attack surface and the risk of untrusted code executing, which could compromise the security of the system.
10.4.1. Components
DCE-Preamble: The DCE Preamble prepares the platform for DRTM by doing any needed configuration, loading the target payload image(DLME), and preparing input parameters needed by DRTM. Finally, it invokes the DL Event to start the dynamic launch.
D-CRTM: The D-CRTM is the trust anchor (or root of trust) for the DRTM boot sequence and is where the dynamic launch starts. The D-CRTM must be implemented as a trusted agent in the system. The D-CRTM initializes the TPM for DRTM and prepares the environment for the next stage of DRTM, the DCE. The D-CRTM measures the DCE, verifies its signature, and transfers control to it.
DCE: The DCE executes on an application core. The DCE verifies the system’s state, measures security-critical attributes of the system, prepares the memory region for the target payload, measures the payload, and finally transfers control to the payload.
DLME: The protected payload is referred to as the Dynamically Launched Measured Environment, or DLME. The DLME begins execution in a safe state, with a single thread of execution, DMA protections, and interrupts disabled. The DCE provides data to the DLME that it can use to verify the configuration of the system.
In this proof of concept, DCE and D-CRTM are implemented in BL31 and DCE-Preamble and DLME are implemented in UEFI application. A DL Event is triggered as a SMC by DCE-Preamble and handled by D-CRTM, which launches the DLME via DCE.
TF-A CI pipeline already includes coverage for building TF-A with a prebuilt EDK2 and the DRTM UEFI application.
Copyright (c) 2022-2025, Arm Limited. All rights reserved.
