9.9. Advisory TFV-9 (CVE-2022-23960)
Trusted Firmware-A exposure to speculative processor vulnerabilities with branch prediction target reuse
CVE-2022-23960
Date
08 Mar 2022
All, up to and including v2.6
Configurations Affected
All
Potential leakage of secure world data to normal world if an attacker is able to find a TF-A exfiltration primitive that can be predicted as a valid branch target, and somehow induce misprediction onto that primitive. There are currently no known exploits.
Gerrit topic #spectre_bhb
Systems and Network Security Group at Vrije Universiteit Amsterdam for CVE-2022-23960, Arm for patches
This security advisory describes the current understanding of the Trusted Firmware-A exposure to the new speculative processor vulnerability. To understand the background and wider impact of these vulnerabilities on Arm systems, please refer to the Arm Processor Security Update. The whitepaper referred to below describes the Spectre attack and mitigation in more detail including implementation specific mitigation details for all impacted Arm CPUs.
9.9.1. CVE-2022-23960
Where possible on vulnerable CPUs that implement FEAT_CSV2, Arm recommends inserting a loop workaround with implementation specific number of iterations that will discard the branch history on exception entry to a higher exception level for the given CPU. This is done as early as possible on entry into EL3, before any branch instruction is executed. This is sufficient to mitigate Spectre-BHB on behalf of all secure world code, assuming that no secure world code is under attacker control.
The below table lists the CPUs that mitigate against this vulnerability in TF-A using the loop workaround(all cores that implement FEAT_CSV2 except the revisions of Cortex-A73 and Cortex-A75 that implements FEAT_CSV2).
Core
Cortex-A72(from r1p0)
Cortex-A76
Cortex-A76AE
Cortex-A77
Cortex-A78
Cortex-A78AE
Cortex-A78C
Cortex-X1
Cortex-X2
Cortex-X3
Cortex-A710
Cortex-A715
Neoverse-N1
Neoverse-N2
Neoverse-V1
Neoverse-V2
For all other cores impacted by Spectre-BHB, some of which that do not implement FEAT_CSV2 and some that do e.g. Cortex-A73, the recommended mitigation is to flush all branch predictions via an implementation specific route.
In case local workaround is not feasible, the Rich OS can invoke the SMC (SMCCC_ARCH_WORKAROUND_3) to apply the workaround. Refer to SMCCC Calling Convention specification for more details.
Gerrit topic #spectre_bhb This patchset implements the Spectre-BHB loop workaround for CPUs mentioned in the above table. For CPUs supporting speculative barrier instruction, the loop workaround is optimised by using SB in place of the common DSB and ISB sequence. It also mitigates against this vulnerability for Cortex-A72 CPU versions that support the CSV2 feature (from r1p0). The patch stack also includes an implementation for a specified CVE-2022-23960 workaround SMC(SMCCC_ARCH_WORKAROUND_3) for use by normal world privileged software. Details of SMCCC_ARCH_WORKAROUND_3 can be found in the SMCCC Calling Convention specification. The specification and implementation also enables the normal world to discover the presence of this firmware service. This patch also implements SMCCC_ARCH_WORKAROUND_3 for Cortex-A57, Coxtex-A72, Cortex-A73 and Cortex-A75 using the existing workaround. for CVE-2017-5715. Cortex-A15 patch extends Spectre V2 mitigation to Spectre-BHB.
The above workaround is enabled by default (on vulnerable CPUs only). Platforms can choose to disable them at compile time if they do not require them.
For more information about non-Arm CPUs, please contact the CPU vendor.
