5.2. Authentication Framework & Chain of Trust
The aim of this document is to describe the authentication framework implemented in Trusted Firmware-A (TF-A). This framework fulfills the following requirements:
  1. It should be possible for a platform port to specify the Chain of Trust in terms of certificate hierarchy and the mechanisms used to verify a particular image/certificate.
  2. The framework should distinguish between:
    • The mechanism used to encode and transport information, e.g. DER encoded X.509v3 certificates to ferry Subject Public Keys, hashes and non-volatile counters.
    • The mechanism used to verify the transported information i.e. the cryptographic libraries.
The framework has been designed following a modular approach illustrated in the next diagram:
| Trusted       | Trusted       | Trusted    |
| Firmware      | Firmware      | Firmware   |
| Generic       | IO Framework  | Platform   |
| Code i.e.     | (IO)          | Port       |
| BL1/BL2 (GEN) |               | (PP)       |
       v               v               v
 |           |   |           |   | Image     |
 | Crypto    |   | Auth      |   | Parser    |
 | Module    |<->| Module    |<->| Module    |
 | (CM)      |   | (AM)      |   | (IPM)     |
       v                               v
| Cryptographic  |             | Image Parser    |
| Libraries (CL) |             | Libraries (IPL) |
              v                v
             | Misc. Libs e.g. |
             | ASN.1 decoder   |
DIAGRAM 1.
This document describes the inner details of the authentication framework and the abstraction mechanisms available to specify a Chain of Trust.
5.2.1. Framework design
This section describes some aspects of the framework design and the rationale behind them. These aspects are key to verify a Chain of Trust.
5.2.1.1. Chain of Trust
A CoT is basically a sequence of authentication images which usually starts with a root of trust and culminates in a single data image. The following diagram illustrates how this maps to a CoT for the BL31 image described in the TBBR-Client specification.
| ROTPK/ROTPK Hash |------>| Trusted Key       |
+------------------+       | Certificate       |
                           | (Auth Image)      |
                     L                v
| Trusted World    |------>| BL31 Key          |
| Public Key       |       | Certificate       |
+------------------+       | (Auth Image)      |
                      /               v
+------------------+ L     +-------------------+
| BL31 Content     |------>| BL31 Content      |
| Certificate PK   |       | Certificate       |
                      /               v
| BL31 Hash        |------>| BL31 Image        |
|                  |       | (Data Image)      |
DIAGRAM 2.
The root of trust is usually a public key (ROTPK) that has been burnt in the platform and cannot be modified.
5.2.1.2. Image types
Images in a CoT are categorised as authentication and data images. An authentication image contains information to authenticate a data image or another authentication image. A data image is usually a boot loader binary, but it could be any other data that requires authentication.
5.2.1.3. Component responsibilities
For every image in a Chain of Trust, the following high level operations are performed to verify it:
  1. Allocate memory for the image either statically or at runtime.
  2. Identify the image and load it in the allocated memory.
  3. Check the integrity of the image as per its type.
  4. Authenticate the image as per the cryptographic algorithms used.
  5. If the image is an authentication image, extract the information that will be used to authenticate the next image in the CoT.
In Diagram 1, each component is responsible for one or more of these operations. The responsibilities are briefly described below.
5.2.1.3.1. TF-A Generic code and IO framework (GEN/IO)
These components are responsible for initiating the authentication process for a particular image in BL1 or BL2. For each BL image that requires authentication, the Generic code asks recursively the Authentication module what is the parent image until either an authenticated image or the ROT is reached. Then the Generic code calls the IO framework to load the image and calls the Authentication module to authenticate it, following the CoT from ROT to Image.
5.2.1.3.2. TF-A Platform Port (PP)
The platform is responsible for:
  1. Specifying the CoT for each image that needs to be authenticated. Details of how a CoT can be specified by the platform are explained later. The platform also specifies the authentication methods and the parsing method used for each image.
  2. Statically allocating memory for each parameter in each image which is used for verifying the CoT, e.g. memory for public keys, hashes etc.
  3. Providing the ROTPK or a hash of it.
  4. Providing additional information to the IPM to enable it to identify and extract authentication parameters contained in an image, e.g. if the parameters are stored as X509v3 extensions, the corresponding OID must be provided.
  5. Fulfill any other memory requirements of the IPM and the CM (not currently described in this document).
  6. Export functions to verify an image which uses an authentication method that cannot be interpreted by the CM, e.g. if an image has to be verified using a NV counter, then the value of the counter to compare with can only be provided by the platform.
  7. Export a custom IPM if a proprietary image format is being used (described later).
5.2.1.3.3. Authentication Module (AM)
It is responsible for:
  1. Providing the necessary abstraction mechanisms to describe a CoT. Amongst other things, the authentication and image parsing methods must be specified by the PP in the CoT.
  2. Verifying the CoT passed by GEN by utilising functionality exported by the PP, IPM and CM.
  3. Tracking which images have been verified. In case an image is a part of multiple CoTs then it should be verified only once e.g. the Trusted World Key Certificate in the TBBR-Client spec. contains information to verify SCP_BL2, BL31, BL32 each of which have a separate CoT. (This responsibility has not been described in this document but should be trivial to implement).
  4. Reusing memory meant for a data image to verify authentication images e.g. in the CoT described in Diagram 2, each certificate can be loaded and verified in the memory reserved by the platform for the BL31 image. By the time BL31 (the data image) is loaded, all information to authenticate it will have been extracted from the parent image i.e. BL31 content certificate. It is assumed that the size of an authentication image will never exceed the size of a data image. It should be possible to verify this at build time using asserts.
5.2.1.3.4. Cryptographic Module (CM)
The CM is responsible for providing an API to:
  1. Verify a digital signature.
  2. Verify a hash.
The CM does not include any cryptography related code, but it relies on an external library to perform the cryptographic operations. A Crypto-Library (CL) linking the CM and the external library must be implemented. The following functions must be provided by the CL:
void (*init)(void);
int (*verify_signature)(
                        /* Data to verify. */
                        void *data_ptr, unsigned int data_len,
                        /* Bit string of the signature in DER format. */
                        void *sig_ptr, unsigned int sig_len,
                        /* ASN1 SignatureAlgorithm struct. */
                        void *sig_alg, unsigned int sig_alg_len,
                        /* ASN1 SubjectPublicKeyInfo struct. */
                        void *pk_ptr, unsigned int pk_len);
int (*calc_hash)(
                        /* SHA256, SHA384 and SHA512 can be used. */
                        enum crypto_md_algo alg
                        /* Data to hash. */
                        /* Buffer to store the output. */
                        unsigned char output[CRYPTO_MD_MAX_SIZE]);
int (*verify_hash)(
                        /* ASN1 DigestInfo struct. */
                        void *digest_info_ptr, unsigned int digest_info_len);
int (*auth_decrypt)(
                        /* Currently AES-GCM is the only supported alg. */
                        enum crypto_dec_algo dec_algo,
                        /* Data to decrypt. */
                        void *data_ptr, size_t len,
                        /* Decryption key. */
                        const void *key, unsigned int key_len,
                        unsigned int key_flags,
                        /* Initialization vector. */
                        const void *iv, unsigned int iv_len,
                        /* Authentication tag. */
                        const void *tag, unsigned int tag_len);
The above functions return values from the enum crypto_ret_value. The functions are registered in the CM using the macro:
REGISTER_CRYPTO_LIB(_name,
                    _init,
                    _verify_signature,
                    _verify_hash,
                    _calc_hash,
                    _auth_decrypt,
                    _convert_pk);
_name must be a string containing the name of the CL. This name is used for debugging purposes.
The _init function is used to perform any initialization required for the specific CM and CL.
The _verify_signature function is used to verify certificates, and _verify_hash is used to verify raw images.
The _calc_hash function is mainly used in the MEASURED_BOOT and DRTM_SUPPORT features to calculate the hashes of various images/data.
The _auth_decrypt function uses an authentication tag to perform authenticated decryption, providing guarantees on the authenticity of encrypted data. This function is used when the optional encrypted firmware feature is enabled, that is when ENCRYPT_BL31 or ENCRYPT_BL32 are set to 1 and DECRYPTION_SUPPORT is set to aes_ccm or aes_gcm.
Optionally, a platform function can be provided to convert public key (_convert_pk). It is only used if the platform saves a hash of the ROTPK. Most platforms save the hash of the ROTPK, but some may save slightly different information - e.g the hash of the ROTPK plus some related information. Defining this function allows to transform the ROTPK used to verify the signature to the buffer (a platform specific public key) which hash is saved in OTP.
int (*convert_pk)(void *full_pk_ptr, unsigned int full_pk_len,
                  void **hashed_pk_ptr, unsigned int *hashed_pk_len);
  • full_pk_ptr: Pointer to Distinguished Encoding Rules (DER) ROTPK.
  • full_pk_len: DER ROTPK size.
  • hashed_pk_ptr: to return a pointer to a buffer, which hash should be the one saved in OTP.
  • hashed_pk_len: previous buffer size
5.2.1.3.5. Image Parser Module (IPM)
The IPM is responsible for:
  1. Checking the integrity of each image loaded by the IO framework.
  2. Extracting parameters used for authenticating an image based upon a description provided by the platform in the CoT descriptor.
Images may have different formats (for example, authentication images could be x509v3 certificates, signed ELF files or any other platform specific format). The IPM allows to register an Image Parser Library (IPL) for every image format used in the CoT. This library must implement the specific methods to parse the image. The IPM obtains the image format from the CoT and calls the right IPL to check the image integrity and extract the authentication parameters.
See Section “Describing the image parsing methods” for more details about the mechanism the IPM provides to define and register IPLs.
5.2.1.4. Authentication methods
The AM supports the following authentication methods:
  1. Hash
  2. Digital signature
The platform may specify these methods in the CoT in case it decides to define a custom CoT instead of reusing a predefined one.
If a data image uses multiple methods, then all the methods must be a part of the same CoT. The number and type of parameters are method specific. These parameters should be obtained from the parent image using the IPM.
  1. Hash
    Parameters:
    1. A pointer to data to hash
    2. Length of the data
    3. A pointer to the hash
    4. Length of the hash
    The hash will be represented by the DER encoding of the following ASN.1 type:
    DigestInfo ::= SEQUENCE {
        digestAlgorithm  DigestAlgorithmIdentifier,
        digest           Digest
    This ASN.1 structure makes it possible to remove any assumption about the type of hash algorithm used as this information accompanies the hash. This should allow the Cryptography Library (CL) to support multiple hash algorithm implementations.
  2. Digital Signature
    Parameters:
    1. A pointer to data to sign
    3. Public Key Algorithm
    4. Public Key value
    5. Digital Signature Algorithm
    6. Digital Signature value
    The Public Key parameters will be represented by the DER encoding of the following ASN.1 type:
    SubjectPublicKeyInfo  ::=  SEQUENCE  {
        algorithm         AlgorithmIdentifier{PUBLIC-KEY,{PublicKeyAlgorithms}},
        subjectPublicKey  BIT STRING  }
    The Digital Signature Algorithm will be represented by the DER encoding of the following ASN.1 types.
    AlgorithmIdentifier {ALGORITHM:IOSet } ::= SEQUENCE {
        algorithm         ALGORITHM.&id({IOSet}),
        parameters        ALGORITHM.&Type({IOSet}{@algorithm}) OPTIONAL
    The digital signature will be represented by:
    signature  ::=  BIT STRING
The authentication framework will use the image descriptor to extract all the information related to authentication.
5.2.2. Specifying a Chain of Trust
A CoT can be described as a set of image descriptors linked together in a particular order. The order dictates the sequence in which they must be verified. Each image has a set of properties which allow the AM to verify it. These properties are described below.
The PP is responsible for defining a single or multiple CoTs for a data image. Unless otherwise specified, the data structures described in the following sections are populated by the PP statically.
5.2.2.1. Describing the image parsing methods
The parsing method refers to the format of a particular image. For example, an authentication image that represents a certificate could be in the X.509v3 format. A data image that represents a boot loader stage could be in raw binary or ELF format. The IPM supports three parsing methods. An image has to use one of the three methods described below. An IPL is responsible for interpreting a single parsing method. There has to be one IPL for every method used by the platform.
  1. Raw format: This format is effectively a nop as an image using this method is treated as being in raw binary format e.g. boot loader images used by TF-A. This method should only be used by data images.
  2. X509V3 method: This method uses industry standards like X.509 to represent PKI certificates (authentication images). It is expected that open source libraries will be available which can be used to parse an image represented by this method. Such libraries can be used to write the corresponding IPL e.g. the X.509 parsing library code in mbed TLS.
  3. Platform defined method: This method caters for platform specific proprietary standards to represent authentication or data images. For example, The signature of a data image could be appended to the data image raw binary. A header could be prepended to the combined blob to specify the extents of each component. The platform will have to implement the corresponding IPL to interpret such a format.
The following enum can be used to define these three methods.
typedef enum img_type_enum {
    IMG_RAW,            /* Binary image */
    IMG_PLAT,           /* Platform specific format */
    IMG_CERT,           /* X509v3 certificate */
    IMG_MAX_TYPES,
} img_type_t;
An IPL must provide functions with the following prototypes:
void init(void);
int check_integrity(void *img, unsigned int img_len);
int get_auth_param(const auth_param_type_desc_t *type_desc,
                      void *img, unsigned int img_len,
                      void **param, unsigned int *param_len);
An IPL for each type must be registered using the following macro:
REGISTER_IMG_PARSER_LIB(_type, _name, _init, _check_int, _get_param)
  • _type: one of the types described above.
  • _name: a string containing the IPL name for debugging purposes.
  • _init: initialization function pointer.
  • _check_int: check image integrity function pointer.
  • _get_param: extract authentication parameter function pointer.
The init() function will be used to initialize the IPL.
The check_integrity() function is passed a pointer to the memory where the image has been loaded by the IO framework and the image length. It should ensure that the image is in the format corresponding to the parsing method and has not been tampered with. For example, RFC-2459 describes a validation sequence for an X.509 certificate.
The get_auth_param() function is passed a parameter descriptor containing information about the parameter (type_desc and cookie) to identify and extract the data corresponding to that parameter from an image. This data will be used to verify either the current or the next image in the CoT sequence.
Each image in the CoT will specify the parsing method it uses. This information will be used by the IPM to find the right parser descriptor for the image.
5.2.2.2. Describing the authentication method(s)
As part of the CoT, each image has to specify one or more authentication methods which will be used to verify it. As described in the Section “Authentication methods”, there are three methods supported by the AM.
typedef enum {
    AUTH_METHOD_NONE,
    AUTH_METHOD_HASH,
    AUTH_METHOD_SIG,
    AUTH_METHOD_NUM
} auth_method_type_t;
The AM defines the type of each parameter used by an authentication method. It uses this information to:
  1. Specify to the get_auth_param() function exported by the IPM, which parameter should be extracted from an image.
  2. Correctly marshall the parameters while calling the verification function exported by the CM and PP.
  3. Extract authentication parameters from a parent image in order to verify a child image e.g. to verify the certificate image, the public key has to be obtained from the parent image.
typedef enum {
    AUTH_PARAM_NONE,
    AUTH_PARAM_RAW_DATA,    /* Raw image data */
    AUTH_PARAM_SIG,         /* The image signature */
    AUTH_PARAM_SIG_ALG,     /* The image signature algorithm */
    AUTH_PARAM_HASH,        /* A hash (including the algorithm) */
    AUTH_PARAM_PUB_KEY,     /* A public key */
    AUTH_PARAM_NV_CTR,      /* A non-volatile counter */
} auth_param_type_t;
The AM defines the following structure to identify an authentication parameter required to verify an image.
typedef struct auth_param_type_desc_s {
    auth_param_type_t type;
    void *cookie;
} auth_param_type_desc_t;
cookie is used by the platform to specify additional information to the IPM which enables it to uniquely identify the parameter that should be extracted from an image. For example, the hash of a BL3x image in its corresponding content certificate is stored in an X509v3 custom extension field. An extension field can only be identified using an OID. In this case, the cookie could contain the pointer to the OID defined by the platform for the hash extension field while the type field could be set to AUTH_PARAM_HASH. A value of 0 for the cookie field means that it is not used.
For each method, the AM defines a structure with the parameters required to verify the image.
 * Parameters for authentication by hash matching
typedef struct auth_method_param_hash_s {
    auth_param_type_desc_t *data;   /* Data to hash */
    auth_param_type_desc_t *hash;   /* Hash to match with */
} auth_method_param_hash_t;
 * Parameters for authentication by signature
typedef struct auth_method_param_sig_s {
    auth_param_type_desc_t *pk; /* Public key */
    auth_param_type_desc_t *sig;    /* Signature to check */
    auth_param_type_desc_t *alg;    /* Signature algorithm */
    auth_param_type_desc_t *tbs;    /* Data signed */
} auth_method_param_sig_t;
The AM defines the following structure to describe an authentication method for verifying an image
 * Authentication method descriptor
typedef struct auth_method_desc_s {
    auth_method_type_t type;
    union {
        auth_method_param_hash_t hash;
        auth_method_param_sig_t sig;
    } param;
} auth_method_desc_t;
Using the method type specified in the type field, the AM finds out what field needs to access within the param union.
5.2.2.3. Storing Authentication parameters
A parameter described by auth_param_type_desc_t to verify an image could be obtained from either the image itself or its parent image. The memory allocated for loading the parent image will be reused for loading the child image. Hence parameters which are obtained from the parent for verifying a child image need to have memory allocated for them separately where they can be stored. This memory must be statically allocated by the platform port.
The AM defines the following structure to store the data corresponding to an authentication parameter.
typedef struct auth_param_data_desc_s {
    void *auth_param_ptr;
    unsigned int auth_param_len;
} auth_param_data_desc_t;
The auth_param_ptr field is initialized by the platform. The auth_param_len field is used to specify the length of the data in the memory.
For parameters that can be obtained from the child image itself, the IPM is responsible for populating the auth_param_ptr and auth_param_len fields while executing the img_get_auth_param() function.
The AM defines the following structure to enable an image to describe the parameters that should be extracted from it and used to verify the next image (child) in a CoT.
typedef struct auth_param_desc_s {
    auth_param_type_desc_t type_desc;
    auth_param_data_desc_t data;
} auth_param_desc_t;
5.2.2.4. Describing an image in a CoT
An image in a CoT is a consolidation of the following aspects of a CoT described above.
  1. A unique identifier specified by the platform which allows the IO framework to locate the image in a FIP and load it in the memory reserved for the data image in the CoT.
  2. A parsing method which is used by the AM to find the appropriate IPM.
  3. Authentication methods and their parameters as described in the previous section. These are used to verify the current image.
  4. Parameters which are used to verify the next image in the current CoT. These parameters are specified only by authentication images and can be extracted from the current image once it has been verified.
The following data structure describes an image in a CoT.
typedef struct auth_img_desc_s {
    unsigned int img_id;
    const struct auth_img_desc_s *parent;
    img_type_t img_type;
    const auth_method_desc_t *const img_auth_methods;
    const auth_param_desc_t *const authenticated_data;
} auth_img_desc_t;
A CoT is defined as an array of pointers to auth_image_desc_t structures linked together by the parent field. Those nodes with no parent must be authenticated using the ROTPK stored in the platform.
5.2.3. Implementation example
This section is a detailed guide explaining a trusted boot implementation using the authentication framework. This example corresponds to the Applicative Functional Mode (AFM) as specified in the TBBR-Client document. It is recommended to read this guide along with the source code.
5.2.3.1. The TBBR CoT
CoT specific to BL1 and BL2 can be found in drivers/auth/tbbr/tbbr_cot_bl1.c and drivers/auth/tbbr/tbbr_cot_bl2.c respectively. The common CoT used across BL1 and BL2 can be found in drivers/auth/tbbr/tbbr_cot_common.c. This CoT consists of an array of pointers to image descriptors and it is registered in the framework using the macro REGISTER_COT(cot_desc), where cot_desc must be the name of the array (passing a pointer or any other type of indirection will cause the registration process to fail).
The number of images participating in the boot process depends on the CoT. There is, however, a minimum set of images that are mandatory in TF-A and thus all CoTs must present:
  • BL2
  • SCP_BL2 (platform specific)
  • BL31
  • BL32 (optional)
  • BL33
The TBBR specifies the additional certificates that must accompany these images for a proper authentication. Details about the TBBR CoT may be found in the Trusted Board Boot document.
Following the Porting Guide, a platform must provide unique identifiers for all the images and certificates that will be loaded during the boot process. If a platform is using the TBBR as a reference for trusted boot, these identifiers can be obtained from include/common/tbbr/tbbr_img_def.h. Arm platforms include this file in include/plat/arm/common/arm_def.h. Other platforms may also include this file or provide their own identifiers.
Important: the authentication module uses these identifiers to index the CoT array, so the descriptors location in the array must match the identifiers.
Each image descriptor must specify:
  • img_id: the corresponding image unique identifier defined by the platform.
  • img_type: the image parser module uses the image type to call the proper parsing library to check the image integrity and extract the required authentication parameters. Three types of images are currently supported:
    • IMG_RAW: image is a raw binary. No parsing functions are available, other than reading the whole image.
    • IMG_PLAT: image format is platform specific. The platform may use this type for custom images not directly supported by the authentication framework.
    • IMG_CERT: image is an x509v3 certificate.
  • parent: pointer to the parent image descriptor. The parent will contain the information required to authenticate the current image. If the parent is NULL, the authentication parameters will be obtained from the platform (i.e. the BL2 and Trusted Key certificates are signed with the ROT private key, whose public part is stored in the platform).
  • img_auth_methods: this points to an array which defines the authentication methods that must be checked to consider an image authenticated. Each method consists of a type and a list of parameter descriptors. A parameter descriptor consists of a type and a cookie which will point to specific information required to extract that parameter from the image (i.e. if the parameter is stored in an x509v3 extension, the cookie will point to the extension OID). Depending on the method type, a different number of parameters must be specified. This pointer should not be NULL. Supported methods are:
    • AUTH_METHOD_HASH: the hash of the image must match the hash extracted from the parent image. The following parameter descriptors must be specified:
      • data: data to be hashed (obtained from current image)
      • hash: reference hash (obtained from parent image)
    • AUTH_METHOD_SIG: the image (usually a certificate) must be signed with the private key whose public part is extracted from the parent image (or the platform if the parent is NULL). The following parameter descriptors must be specified:
      • pk: the public key (obtained from parent image)
      • sig: the digital signature (obtained from current image)
      • alg: the signature algorithm used (obtained from current image)
      • data: the data to be signed (obtained from current image)
  • authenticated_data: this array pointer indicates what authentication parameters must be extracted from an image once it has been authenticated. Each parameter consists of a parameter descriptor and the buffer address/size to store the parameter. The CoT is responsible for allocating the required memory to store the parameters. This pointer may be NULL.
In the tbbr_cot*.c file, a set of buffers are allocated to store the parameters extracted from the certificates. In the case of the TBBR CoT, these parameters are hashes and public keys. In DER format, an RSA-4096 public key requires 550 bytes, and a hash requires 51 bytes. Depending on the CoT and the authentication process, some of the buffers may be reused at different stages during the boot.
Next in that file, the parameter descriptors are defined. These descriptors will be used to extract the parameter data from the corresponding image.
5.2.3.1.1. Example: the BL31 Chain of Trust
Four image descriptors form the BL31 Chain of Trust:
static const auth_img_desc_t trusted_key_cert = {
        .img_id = TRUSTED_KEY_CERT_ID,
        .img_type = IMG_CERT,
        .parent = NULL,
        .img_auth_methods =  (const auth_method_desc_t[AUTH_METHOD_NUM]) {
                [0] = {
                        .type = AUTH_METHOD_SIG,
                        .param.sig = {
                                .pk = &subject_pk,
                                .sig = &sig,
                                .alg = &sig_alg,
                                .data = &raw_data
                [1] = {
                        .type = AUTH_METHOD_NV_CTR,
                        .param.nv_ctr = {
                                .cert_nv_ctr = &trusted_nv_ctr,
                                .plat_nv_ctr = &trusted_nv_ctr
        .authenticated_data = (const auth_param_desc_t[COT_MAX_VERIFIED_PARAMS]) {
                [0] = {
                        .type_desc = &trusted_world_pk,
                        .data = {
                                .ptr = (void *)trusted_world_pk_buf,
                                .len = (unsigned int)PK_DER_LEN
                [1] = {
                        .type_desc = &non_trusted_world_pk,
                        .data = {
                                .ptr = (void *)non_trusted_world_pk_buf,
static const auth_img_desc_t soc_fw_key_cert = {
        .img_id = SOC_FW_KEY_CERT_ID,
        .parent = &trusted_key_cert,
                [0] = {
                        .param.sig = {
                                .pk = &trusted_world_pk,
                                .sig = &sig,
                                .alg = &sig_alg,
                                .data = &raw_data
                [1] = {
                        .param.nv_ctr = {
                [0] = {
                        .type_desc = &soc_fw_content_pk,
                        .data = {
                                .ptr = (void *)content_pk_buf,
static const auth_img_desc_t soc_fw_content_cert = {
        .img_id = SOC_FW_CONTENT_CERT_ID,
        .parent = &soc_fw_key_cert,
                [0] = {
                        .param.sig = {
                                .pk = &soc_fw_content_pk,
                                .sig = &sig,
                                .alg = &sig_alg,
                                .data = &raw_data
                [1] = {
                        .param.nv_ctr = {
                [0] = {
                        .type_desc = &soc_fw_hash,
                        .data = {
                                .ptr = (void *)soc_fw_hash_buf,
                                .len = (unsigned int)HASH_DER_LEN
                [1] = {
                        .type_desc = &soc_fw_config_hash,
                        .data = {
                                .ptr = (void *)soc_fw_config_hash_buf,
static const auth_img_desc_t bl31_image = {
        .img_id = BL31_IMAGE_ID,
        .img_type = IMG_RAW,
        .parent = &soc_fw_content_cert,
                [0] = {
                        .type = AUTH_METHOD_HASH,
                        .param.hash = {
                                .data = &raw_data,
                                .hash = &soc_fw_hash
The Trusted Key certificate is signed with the ROT private key and contains the Trusted World public key and the Non-Trusted World public key as x509v3 extensions. This must be specified in the image descriptor using the img_auth_methods and authenticated_data arrays, respectively.
The Trusted Key certificate is authenticated by checking its digital signature using the ROTPK. Four parameters are required to check a signature: the public key, the algorithm, the signature and the data that has been signed. Therefore, four parameter descriptors must be specified with the authentication method:
  • subject_pk: parameter descriptor of type AUTH_PARAM_PUB_KEY. This type is used to extract a public key from the parent image. If the cookie is an OID, the key is extracted from the corresponding x509v3 extension. If the cookie is NULL, the subject public key is retrieved. In this case, because the parent image is NULL, the public key is obtained from the platform (this key will be the ROTPK).
  • sig: parameter descriptor of type AUTH_PARAM_SIG. It is used to extract the signature from the certificate.
  • sig_alg: parameter descriptor of type AUTH_PARAM_SIG. It is used to extract the signature algorithm from the certificate.
  • raw_data: parameter descriptor of type AUTH_PARAM_RAW_DATA. It is used to extract the data to be signed from the certificate.
Once the signature has been checked and the certificate authenticated, the Trusted World public key needs to be extracted from the certificate. A new entry is created in the authenticated_data array for that purpose. In that entry, the corresponding parameter descriptor must be specified along with the buffer address to store the parameter value. In this case, the trusted_world_pk descriptor is used to extract the public key from an x509v3 extension with OID TRUSTED_WORLD_PK_OID. The BL31 key certificate will use this descriptor as parameter in the signature authentication method. The key is stored in the trusted_world_pk_buf buffer.
The BL31 Key certificate is authenticated by checking its digital signature using the Trusted World public key obtained previously from the Trusted Key certificate. In the image descriptor, we specify a single authentication method by signature whose public key is the trusted_world_pk. Once this certificate has been authenticated, we have to extract the BL31 public key, stored in the extension specified by soc_fw_content_pk. This key will be copied to the content_pk_buf buffer.
The BL31 certificate is authenticated by checking its digital signature using the BL31 public key obtained previously from the BL31 Key certificate. We specify the authentication method using soc_fw_content_pk as public key. After authentication, we need to extract the BL31 hash, stored in the extension specified by soc_fw_hash. This hash will be copied to the soc_fw_hash_buf buffer.
The BL31 image is authenticated by calculating its hash and matching it with the hash obtained from the BL31 certificate. The image descriptor contains a single authentication method by hash. The parameters to the hash method are the reference hash, soc_fw_hash, and the data to be hashed. In this case, it is the whole image, so we specify raw_data.
5.2.3.2. The image parser library
The image parser module relies on libraries to check the image integrity and extract the authentication parameters. The number and type of parser libraries depend on the images used in the CoT. Raw images do not need a library, so only an x509v3 library is required for the TBBR CoT.
Arm platforms will use an x509v3 library based on mbed TLS. This library may be found in drivers/auth/mbedtls/mbedtls_x509_parser.c. It exports three functions:
void init(void);
The library is registered in the framework using the macro REGISTER_IMG_PARSER_LIB(). Each time the image parser module needs to access an image of type IMG_CERT, it will call the corresponding function exported in this file.
The build system must be updated to include the corresponding library and mbed TLS sources. Arm platforms use the arm_common.mk file to pull the sources.
5.2.3.3. The cryptographic library
The cryptographic module relies on a library to perform essential operations such as verifying a hash or a digital signature. Arm platforms use a library based on mbedTLS located at drivers/auth/mbedtls/mbedtls_crypto.c. Additionally, an experimental alternative library based on PSA Crypto is available at drivers/auth/mbedtls/mbedtls_psa_crypto.c. In future, mbedtls_psa_crypto.c will replace mbedtls_crypto.c as the default Arm CM. Both libraries are registered in the authentication framework using the macro REGISTER_CRYPTO_LIB(). These libraries implement the following exported functions, their implementations are compared side-by-side below:
Comparison of exported CM function implementations
CM function
mbedtls_crypto.c
init
Initialize the heap for mbedTLS.
Initialize the heap for mbedTLS and call psa_crypto_init.
verify_signature
Use mbedTLS to parse the ASN1 inputs, and then use the mbedTLS pk module to verify the signature.
Use mbedTLS to parse the ASN1 inputs, use the mbedTLS pk module to parse the key, import it into the PSA key system and then use psa_verify_message to verify the signature.
calc_hash
Use the mbedtls_md API to calculate the hash of the given data.
Use psa_hash_compute to calculate the hash of the given data.
verify_hash
Use the mbedtls_md API to calculate the hash of the given data, and then compare it against the data which is to be verified.
Call psa_hash_compare, which both calculates the hash of the given data and compares this hash against the data to be verified.
auth_decrypt
Use the mbedtls_gcm API to decrypt the data, and then verify the returned tag by comparing it to the inputted tag.
Load the key into the PSA key store, and then use psa_aead_verify to decrypt and verify the tag.
The mbedTLS library algorithm support is configured by both the TF_MBEDTLS_KEY_ALG and TF_MBEDTLS_KEY_SIZE variables.
  • TF_MBEDTLS_KEY_ALG can take in 3 values: rsa, ecdsa or rsa+ecdsa. This variable allows the Makefile to include the corresponding sources in the build for the various algorithms. Setting the variable to rsa+ecdsa enables support for both rsa and ecdsa algorithms in the mbedTLS library.
  • TF_MBEDTLS_KEY_SIZE sets the supported RSA key size for TFA. Valid values include 1024, 2048, 3072 and 4096.
  • TF_MBEDTLS_USE_AES_GCM enables the authenticated decryption support based on AES-GCM algorithm. Valid values are 0 and 1.
If code size is a concern, the build option MBEDTLS_SHA256_SMALLER can be defined in the platform Makefile. It will make mbed TLS use an implementation of SHA-256 with smaller memory footprint (~1.5 KB less) but slower (~30%).
Copyright (c) 2017-2024, Arm Limited and Contributors. All rights reserved.
