4.15.1. FF-A manifests binding to device tree
This document defines the nodes and properties used to define a partition, according to the FF-A specification, and the SPMC manifest.
4.15.1.1. FF-A Partition Manifest Properties
The FF-A partition manifest is consumed by the SPMC to configure the state associated with the related Secure Partition.
  • compatible [mandatory]
    • value type: <string>
    • Must be the string “arm,ffa-manifest-X.Y” which specifies the major and minor versions of the device tree binding for the FFA manifest represented by this node. The minor number is incremented if the binding changes in a backwards compatible manner.
      • X is an integer representing the major version number of this document.
      • Y is an integer representing the minor version number of this document.
  • ffa-version [mandatory]
    • value type: <u32>
    • Must be two 16 bits values (X, Y), concatenated as 31:16 -> X, 15:0 -> Y, where:
      • X is the major version of FF-A expected by the partition at the FFA instance it will execute.
      • Y is the minor version of FF-A expected by the partition at the FFA instance it will execute.
  • id
    • value type: <u32>
    • Pre-allocated partition ID.
  • auxiliary-id
    • value type: <u32>
    • Pre-allocated ID that could be used in memory management transactions.
  • description
    • Name of the partition e.g. for debugging purposes.
  • execution-ctx-count [mandatory]
    • value type: <u32>
    • Number of vCPUs that a VM or SP wants to instantiate.
      • In the absence of virtualization, this is the number of execution contexts that a partition implements.
      • If value of this field = 1 and number of PEs > 1 then the partition is treated as UP & migrate capable.
      • If the value of this field > 1 then the partition is treated as a MP capable partition irrespective of the number of PEs.
  • exception-level [mandatory]
    • value type: <u32>
    • The target exception level for the partition:
      • 0x0: EL1
      • 0x1: S_EL0
      • 0x2: S_EL1
  • execution-state [mandatory]
    • value type: <u32>
    • The target execution state of the partition:
      • 0: AArch64
      • 1: AArch32
  • load-address
    • value type: <u64>
    • Physical base address of the partition in memory. Absence of this field indicates that the partition is position independent and can be loaded at any address chosen at boot time.
  • entrypoint-offset
    • value type: <u64>
    • Offset from the base of the partition’s binary image to the entry point of the partition. Absence of this field indicates that the entry point is at offset 0x0 from the base of the partition’s binary.
  • xlat-granule
    • value type: <u32>
    • Translation granule used with the partition:
      • 0x0: 4k
      • 0x1: 16k
      • 0x2: 64k
  • boot-order
    • value type: <u32>
    • A unique number amongst all partitions that specifies if this partition must be booted before others. The partition with the smaller number will be booted first. Highest vlue allowed for this field is 0xFFFF.
  • rx-tx-buffer
    • value type: “memory-regions” node
    • Specific “memory-regions” nodes that describe the RX/TX buffers expected by the partition. The “compatible” must be the string “arm,ffa-manifest-rx_tx-buffer”.
  • managed-exit
    • value type: <empty>
    • Specifies if managed exit is supported.
    • This field is deprecated in favor of ns-interrupts-action field in the FF-A v1.1 EAC0 spec.
  • managed-exit-virq
    • Indicates if the partition needs managed exit, if supported, to be signaled through vIRQ signal.
  • ns-interrupts-action [mandatory]
    • value type: <u32>
    • Specifies the action that the SPMC must take in response to a Non-secure physical interrupt.
      • 0x0: Non-secure interrupt is queued
      • 0x1: Non-secure interrupt is signaled after a managed exit
      • 0x2: Non-secure interrupt is signaled
    • This field supersedes the managed-exit field in the FF-A v1.0 spec.
  • other-s-interrupts-action
    • value type: <u32>
    • Specifies the action that the SPMC must take in response to a Other-Secure physical interrupt.
      • 0x0: Other-Secure interrupt is queued
      • 0x1: Other-Secure interrupt is signaled
  • sri-interrupts-policy
    • value type: <u32>
    • Specifies how secure interrupts are handled when the SP is in a waiting state and is targeted by a secure interrupt, or when the SP attempts to return to a waiting state with pending secure interrupts. The value is a bitfield.
      • 0x0: Proactively inject the VI and resume SP when handling a secure interrupt and SP in the waiting state.
      • 0x1: Only when a secure interrupt is fired while target SP in the waiting state, pend SRI to the NWd and rely on the scheduler to explicitly donate CPU cycles to the SP.
      • 0x2: Only when the SP attempts to go back to the waiting state while having pending secure interrupts, trigger the SRI to the NWd and rely on the scheduler to explicitly donate CPU cycles to the SP.
      • 0x3: Enable both actions for values 0x1 and 0x2.
  • has-primary-scheduler
    • Presence of this field indicates that the partition implements the primary scheduler. If so, run-time EL must be EL1.
  • time-slice-mem
    • Presence of this field indicates that the partition doesn’t expect the partition manager to time slice long running memory management functions.
  • gp-register-num
    • value type: <u32>
    • The field specifies the general purpose register number but not its width. The width is derived from the partition’s execution state, as specified in the partition properties. For example, if the number value is 1 then the general-purpose register used will be x1 in AArch64 state and w1 in AArch32 state. Presence of this field indicates that the partition expects the address of the FF-A boot information blob to be passed in the specified general purpose register.
  • power-management-messages
    • value type: <u32>
    • Specifies which power management messages a partition subscribes to. A set bit means the partition should be informed of the power event, clear bit - should not be informed of event:
      • Bit[0]: CPU_OFF
      • Bit[1]: CPU_SUSPEND
      • Bit[2]: CPU_SUSPEND_RESUME
  • vm-availability-messages
    • value type: <u32>
    • Specifies which VM availability messages a partition subscribes to. A set bit means the partition should be informed of the event, clear bit - should not be informed of event:
      • Bit[0]: VM created
      • Bit[1]: VM destroyed
  • lifecycle-support
    • Presence of this field indicates support for all partition lifecycle states defined in the FF-A v1.3 ALP2 spec.
  • abort-action
    • value type: <u32>
    • Specifies the action that the SPMC takes when a partition encounters a fatal error.
      • 0x0: STOP
      • 0x1: DESTROY
      • 0x2: RESTART
      • 0x3: PROPAGATE
    • All other values are unsupported. If a partition does not specify this field in the manifest, the SPMC takes implementation defined action.
  • live-activation-support
    • Presence of this field indicates support for partition framework messages necessary for live activation as defined in the FF-A v1.3 ALP2 spec.
  • live-activation-register
    • value type: <u32>
    • Register used by the SPMC to report to the SP that it is undergoing live activation. Must be one of x0–x3 or x5–x7 so that it does not clash with the boot-info register or the reserved x4 linear vCPU index.
  • image-uuid
    • value type: <prop-encoded-array>
    • Exactly one tuple of 4 <u32> values identifying the partition image UUID. The UUID must not be all zeros and must not collide with any protocol UUID exposed by the partition.
  • live-state-buffer-info
    • value type: <phandle>
    • Child node with compatible = "arm,ffa-manifest,live-state-buffer" whose live-state-buffer property points to the backing memory-region entry.
When live-activation-support is present the manifest must also meet the following requirements:
  • lifecycle-support must be present and execution-ctx-count must be 1.
  • live-activation-register and image-uuid must follow the constraints above; manifests advertising multiple image UUIDs or invalid registers are rejected.
  • The live state buffer referenced via live-state-buffer-info must be defined under memory-regions and describe a page-aligned, read/write region that sits outside the working memory region (which is overwritten during activation) and is large enough to preserve the framework state.
Informative example:
lifecycle-support;
execution-ctx-count = <1>;
abort-action = <1>;
live-activation-support;
live-activation-register = <1>;
image-uuid = <0x962a7bf0 0x174d471d 0xa686c89e 0x5c3e254e>;
live-state-buffer-info {
    compatible = "arm,ffa-manifest,live-state-buffer";
    live-state-buffer = <&livestatebuffer>;
memory-regions {
    compatible = "arm,ffa-manifest-memory-regions";
    livestatebuffer: live-state-buffer {
        description = "live-state-buffer";
        base-address = <0x00000000 0x06780000>;
        pages-count = <1>;
        attributes = <0x3>; /* read-write */
4.15.1.1.1. Services
  • A service pairs a protocol UUID with supported messaging methods that clients use to reach the SP.
  • For the compatible value at the root set to “arm,ffa-manifest-1.0”, the UUIDs and messaging methods are specified in two separate lists at the root node as below:
    • uuid [mandatory]
      • An array of comma separated tuples each consisting of 4 <u32> values, identifying the protocol UUIDs of the services implemented by this partition. The UUID format is described in RFC 4122.
      • These 4 <u32> values are packed similar to the UUID register mapping specified in section ‘5.3 Unique Identification format’, SMC Calling Convention, DEN0028, v1.6 G BET0 (https://developer.arm.com/documentation/den0028/latest/).
    • messaging-method [mandatory]
      • An array of <u32> values which specify which messaging methods are supported for each service. If one value is specified all services support those messaging methods. If multiple values are specified, there must be the same number as UUIDs specified, and the messaging method at each index is paired with the UUID at the matching index of the uuid array. Set bit means the feature is supported, clear bit - not supported:
        • Bit[0]: partition can receive direct requests via FFA_MSG_SEND_DIRECT_REQ ABI if set
        • Bit[1]: partition can send direct requests via FFA_MSG_SEND_DIRECT_REQ ABI if set
        • Bit[2]: partition can send and receive indirect messages
        • Bit[9]: partition can receive direct requests via FFA_MSG_SEND_DIRECT_REQ2 ABI if set
        • Bit[10]: partition can send direct requests via FFA_MSG_SEND_DIRECT_REQ2 ABI if set
      • A request targeting a specific protocol UUID requires that service to have the corresponding bit set. Requests that do not target a specific protocol UUID (for example, a NULL UUID or FFA_MSG_SEND_DIRECT_REQ) are allowed if any service exposes the required messaging method.
  • For compatible value “arm,ffa-manifest-X.Y” with X.Y > 1.0, specify services under a parent “services” node like so:
    • services [mandatory]
        • Must be the string “arm,ffa-manifest-services”.
      • Child service nodes [mandatory]
        • uuid [mandatory]
          • value type: <u32>
          • Specifies which messaging methods are supported by this service, set bit means the feature is supported, clear bit - not supported:
        • Each child under “services” pairs a protocol UUID with a messaging method. At least one child must be specified.
4.15.1.1.2. Memory Regions
    • Must be the string “arm,ffa-manifest-memory-regions”.
  • description
    • Name of the memory region e.g. for debugging purposes.
  • pages-count [mandatory]
    • value type: <u32>
    • Count of pages of memory region as a multiple of the translation granule size
  • attributes [mandatory]
    • value type: <u32>
    • Mapping modes: ORed to get required permission
      • 0x1: Read
      • 0x2: Write
      • 0x4: Execute
      • 0x8: Security state
  • base-address
    • value type: <u64>
    • Base address of the region. The address must be aligned to the translation granule size. The address given may be a Physical Address (PA), Virtual Address (VA), or Intermediate Physical Address (IPA). Refer to the FF-A specification for more information on the restrictions around the address type. If the base address is omitted then the partition manager must map a memory region of the specified size into the partition’s translation regime and then communicate the region properties (including the base address chosen by the partition manager) to the partition.
  • load-address-relative-offset
    • value type: <u64>
    • Offset relative to the load address of the partition. When this is provided in the partition manifest, it should be added to the load address to get the base address of the region. The secure partition manifest can have either “base-address” or “load-address-relative-offset”. It cannot have both.
  • stream-ids
    • List of IDs belonging to a DMA capable peripheral device that has access to the memory region represented by current node.
    • Each ID must have been declared in exactly one device region node.
  • smmu-id
    • value type: <u32>
    • Identifies the SMMU IP that enforces the access control for the DMA device that owns the above stream-ids.
  • stream-ids-access-permissions
    • List of attributes representing the instruction and data access permissions used by the DMA device streams to access the memory region represented by current node.
4.15.1.1.3. Device Regions
    • Must be the string “arm,ffa-manifest-device-regions”.
  • description
    • Name of the device region e.g. for debugging purposes.
    • value type: <u32>
    • value type: <u32>
      • 0x1: Read
      • 0x2: Write
      • 0x4: Execute
  • base-address [mandatory]
    • value type: <u64>
  • smmu-id
    • value type: <u32>
    • On systems with multiple System Memory Management Units (SMMUs) this identifier is used to inform the partition manager which SMMU the device is upstream of. If the field is omitted then it is assumed that the device is not upstream of any SMMU.
  • stream-ids
    • List of IDs where an ID is a unique <u32> value amongst all devices assigned to the partition.
  • interrupts
    • A list of (id, attributes) pair describing the device interrupts, where:
      • id: The <u32> interrupt IDs.
      • attributes: A <u32> value, containing attributes for each interrupt ID:
        Field
        Bit(s)
        Priority
        7:0
        Security state
        8
        Config(Edge/Level)
        9
        Type(SPI/PPI/SGI)
        11:10
        Security state:
        • Secure: 1
        • Non-secure: 0
        Configuration:
        • Edge triggered: 0
        • Level triggered: 1
        Type:
        • SPI: 0b10
        • PPI: 0b01
        • SGI: 0b00
  • interrupts-target
    • A list of (id, mpdir upper bits, mpidr lower bits) tuples describing which mpidr the interrupt is routed to, where:
      • id: The <u32> interrupt ID. Must be one of those specified in the
        “interrupts” field.
      • mpidr upper bits: The <u32> describing the upper bits of the 64 bits
        mpidr
      • mpidr lower bits: The <u32> describing the lower bits of the 64 bits
        mpidr
  • exclusive-access
    • Presence of this field implies that this endpoint must be granted exclusive access and ownership of this device’s MMIO region.
4.15.1.2. SPMC Manifest Properties
This manifest contains the SPMC attribute node consumed by the SPMD at boot time.
4.15.1.2.1. attribute
  • spmc_id
    • value type: <u32>
    • Defines the endpoint ID value that SPMC can query through FFA_ID_GET.
  • maj_ver
    • value type: <u32>
    • Major of the FF-A version implemented by the SPMC. SPMD checks against its own version.
  • min_ver
    • value type>: <u32>
    • Minor of the FF-A version implemented by the SPMC. SPMD checks against its own version.
  • exec_state
    • value type: <u32>
    • Defines the SPMC execution state (AArch64 or AArch32).
  • load_address
    • value type: <u64>
    • Base physical address in which the SPMC binary is placed. Should be page aligned.
  • entrypoint:
    • value type: <u64>
    • Defines the physical address for the cold boot primary core entrypoint used by the SPMD (currently matches BL32_BASE) to enter the SPMC.
  • binary_size
    • value type: <u32>
    • Defines the maximum size of the SPMC binary. It is used with load_address to sanitize the specified entrypoint.
Copyright (c) 2019-2026, Arm Limited and Contributors. All rights reserved.
