5.10. Building FIP images with support for Trusted Board Boot
Trusted Board Boot primarily consists of the following two features:
The following steps should be followed to build FIP and (optionally) FWU_FIP images with support for these features:
  1. Fulfill the dependencies of the mbedtls cryptographic and image parser modules by checking out a recent version of the mbed TLS Repository. It is important to use a version that is compatible with TF-A and fixes any known security vulnerabilities. See mbed TLS Security Center for more information. See the Prerequisites document for the appropriate version of mbed TLS to use.
    The drivers/auth/mbedtls/mbedtls_*.mk files contain the list of mbed TLS source files the modules depend upon. include/drivers/auth/mbedtls/mbedtls_config.h contains the configuration options required to build the mbed TLS sources.
    Note that the mbed TLS library is licensed under the Apache version 2.0 license. Using mbed TLS source code will affect the licensing of TF-A binaries that are built using this library.
  2. To build the FIP image, ensure the following command line variables are set while invoking make to build TF-A:
    • TRUSTED_BOARD_BOOT=1
    • GENERATE_COT=1
    By default, this will use the Chain of Trust described in the TBBR-client document. To select a different one, use the COT build option.
    If using a custom build of OpenSSL, set the OPENSSL_DIR variable accordingly so it points at the OpenSSL installation path, as explained in Build Options. In addition, set the LD_LIBRARY_PATH variable when running to point at the custom OpenSSL path, so the OpenSSL libraries are loaded from that path instead of the default OS path. Export this variable if necessary.
    In the case of Arm platforms, the location of the ROTPK must also be specified at build time. The following locations are currently supported (see ARM_ROTPK_LOCATION build option):
    • ARM_ROTPK_LOCATION=regs: the ROTPK hash is obtained from the Trusted root-key storage registers present in the platform. On Juno, these registers are read-only. On FVP Base and Cortex models, the registers are also read-only, but the value can be specified using the command line option bp.trusted_key_storage.public_key when launching the model. On Juno board, the default value corresponds to an ECDSA-SECP256R1 public key hash, whose private part is not currently available.
    • ARM_ROTPK_LOCATION=devel_rsa: the ROTPK is a hash of the RSA public key corresponding to the private key specified by ROT_KEY. If ROT_KEY is not specified, the private key is the development key plat/arm/board/common/rotpk/arm_rotprivk_rsa.pem. There are also 3k and 4k RSA development keys in plat/arm/board/common/rotpk/. The hashing algorithm is selected by HASH_ALG; sha256 is used if HASH_ALG is not specified.
    • ARM_ROTPK_LOCATION=devel_ecdsa: the ROTPK is a hash of the ECDSA public key corresponding to the private key specified by ROT_KEY. If ROT_KEY is not specified, the private key is the development key plat/arm/board/common/rotpk/arm_rotprivk_ecdsa.pem by default, a 384 bit key plat/arm/board/common/rotpk/arm_rotprivk_ecdsa_secp384r1.pem also exists, and can be specified by ROT_KEY. The hashing algorithm is selected by HASH_ALG; sha256 is used if HASH_ALG is not specified.
    • ARM_ROTPK_LOCATION=devel_full_dev_rsa_key: the ROTPK is an unhashed RSA public key corresponding to the private key specified by ROT_KEY. If ROT_KEY is not specified, the private key is the development key plat/arm/board/common/rotpk/arm_rotprivk_rsa.pem. There are also 3k and 4k RSA development keys in plat/arm/board/common/rotpk/.
    • ARM_ROTPK_LOCATION=devel_full_dev_ecdsa_key: the ROTPK is an unhashed RSA public key corresponding to the private key specified by ROT_KEY. If ROT_KEY is not specified, the private key is the development key plat/arm/board/common/rotpk/arm_rotprivk_ecdsa.pem, a 384 bit key plat/arm/board/common/rotpk/arm_rotprivk_ecdsa_secp384r1.pem also exists, and can be specified by ROT_KEY.
    Example of command line using RSA development keys:
    make PLAT=<platform> TRUSTED_BOARD_BOOT=1 GENERATE_COT=1        \
    ARM_ROTPK_LOCATION=devel_rsa                                    \
    ROT_KEY=plat/arm/board/common/rotpk/arm_rotprivk_rsa.pem        \
    BL33=<path-to>/<bl33_image> OPENSSL_DIR=<path-to>/<openssl>     \
    all fip
    The result of this build will be the bl1.bin and the fip.bin binaries. This FIP will include the certificates corresponding to the selected Chain of Trust. These certificates can also be found in the output build directory.
  3. The optional FWU_FIP contains any additional images to be loaded from Non-Volatile storage during the Firmware Update (FWU) process. To build the FWU_FIP, any FWU images required by the platform must be specified on the command line. On Arm development platforms like Juno, these are:
    • NS_BL2U. The AP non-secure Firmware Updater image.
    • SCP_BL2U. The SCP Firmware Update Configuration image.
    Example of Juno command line for generating both fwu and fwu_fip targets using RSA development:
    make PLAT=juno TRUSTED_BOARD_BOOT=1 GENERATE_COT=1              \
    SCP_BL2=<path-to>/<scp_bl2_image>                               \
    SCP_BL2U=<path-to>/<scp_bl2u_image>                             \
    NS_BL2U=<path-to>/<ns_bl2u_image>                               \
    all fip fwu_fip
    The BL2U image will be built by default and added to the FWU_FIP. The user may override this by adding BL2U=<path-to>/<bl2u_image> to the command line above.
    Building and installing the non-secure and SCP FWU images (NS_BL1U, NS_BL2U and SCP_BL2U) is outside the scope of this document.
    The result of this build will be bl1.bin, fip.bin and fwu_fip.bin binaries. Both the FIP and FWU_FIP will include the certificates corresponding to the selected Chain of Trust. These certificates can also be found in the output build directory.
Copyright (c) 2019-2024, Arm Limited. All rights reserved.
