9.6. Advisory TFV-6 (CVE-2017-5753, CVE-2017-5715, CVE-2017-5754)
Trusted Firmware-A exposure to speculative processor vulnerabilities using cache timing side-channels
CVE-2017-5753 / CVE-2017-5715 / CVE-2017-5754 / CVE-2018-3640 / CVE-2018-3639 / CVE-2022-23960
Date
03 Jan 2018 (Updated 11 Jan, 18 Jan, 26 Jan, 30 Jan, 07 June 2018 and 07 Aug 2025)
All, up to and including v1.4
Configurations Affected
All
Leakage of secure world data to normal world
Pull Request #1214, Pull Request #1228, Pull Request #1240 and Pull Request #1405
Google / Arm
This security advisory describes the current understanding of the Trusted Firmware-A exposure to the speculative processor vulnerabilities identified by Google Project Zero. To understand the background and wider impact of these vulnerabilities on Arm systems, please refer to the Arm Processor Security Update.
9.6.1. Variant 1 (CVE-2017-5753)
At the time of writing, no vulnerable patterns have been observed in upstream TF code, therefore no workarounds have been applied or are planned.
9.6.2. Variant 2 (CVE-2017-5715)
Where possible on vulnerable CPUs, Arm recommends invalidating the branch predictor as early as possible on entry into the secure world, before any branch instruction is executed. There are a number of implementation defined ways to achieve this.
For Cortex-A57 and Cortex-A72 CPUs, the Pull Requests (PRs) in this advisory invalidate the branch predictor when entering EL3 by disabling and re-enabling the MMU.
For Cortex-A73 and Cortex-A75 CPUs, the PRs in this advisory invalidate the branch predictor when entering EL3 by temporarily dropping into AArch32 Secure-EL1 and executing the BPIALL instruction. This workaround is significantly more complex than the “MMU disable/enable” workaround. The latter is not effective at invalidating the branch predictor on Cortex-A73/Cortex-A75.
Note that if other privileged software, for example a Rich OS kernel, implements its own branch predictor invalidation during context switch by issuing an SMC (to execute firmware branch predictor invalidation), then there is a dependency on the PRs in this advisory being deployed in order for those workarounds to work. If that other privileged software is able to workaround the vulnerability locally (for example by implementing “MMU disable/enable” itself), there is no such dependency.
Pull Request #1240 and Pull Request #1405 optimise the earlier fixes by implementing a specified CVE-2017-5715 workaround SMC (SMCCC_ARCH_WORKAROUND_1) for use by normal world privileged software. This is more efficient than calling an arbitrary SMC (for example PSCI_VERSION). Details of SMCCC_ARCH_WORKAROUND_1 can be found in the CVE-2017-5715 mitigation specification. The specification and implementation also enable the normal world to discover the presence of this firmware service.
On Juno R1 we measured the round trip latency for both the PSCI_VERSION and SMCCC_ARCH_WORKAROUND_1 SMCs on Cortex-A57, using both the “MMU disable/enable” and “BPIALL at AArch32 Secure-EL1” workarounds described above. This includes the time spent in test code conforming to the SMC Calling Convention (SMCCC) from AArch64. For the SMCCC_ARCH_WORKAROUND_1 cases, the test code uses SMCCC v1.1, which reduces the number of general purpose registers it needs to save/restore. Although the BPIALL instruction is not effective at invalidating the branch predictor on Cortex-A57, the drop into Secure-EL1 with MMU disabled that this workaround entails effectively does invalidate the branch predictor. Hence this is a reasonable comparison.
The results were as follows:
Test
Time (ns)
PSCI_VERSION baseline (without PRs in this advisory)
515
PSCI_VERSION baseline (with PRs in this advisory)
527
PSCI_VERSION with “MMU disable/enable”
930
SMCCC_ARCH_WORKAROUND_1 with “MMU disable/enable”
386
PSCI_VERSION with “BPIALL at AArch32 Secure-EL1”
1276
SMCCC_ARCH_WORKAROUND_1 with “BPIALL at AArch32 Secure-EL1”
770
Due to the high severity and wide applicability of this issue, the above workarounds are enabled by default (on vulnerable CPUs only), despite some performance and code size overhead. Platforms can choose to disable them at compile time if they do not require them. Pull Request #1240 disables the workarounds for unaffected upstream platforms.
For vulnerable AArch32-only CPUs (for example Cortex-A8, Cortex-A9 and Cortex-A17), the BPIALL instruction should be used as early as possible on entry into the secure world. For Cortex-A8, also set ACTLR[6] to 1 during early processor initialization. Note that the BPIALL instruction is not effective at invalidating the branch predictor on Cortex-A15. For that CPU, set ACTLR[0] to 1 during early processor initialization, and invalidate the branch predictor by performing an ICIALLU instruction.
On AArch32 EL3 systems, the monitor and secure-SVC code is typically tightly integrated, for example as part of a Trusted OS. Therefore any Variant 2 workaround should be provided by vendors of that software and is outside the scope of TF. However, an example implementation in the minimal AArch32 Secure Payload, SP_MIN is provided in Pull Request #1228.
Refer to Arm CPU Security Bulletin-Spectre/Meltdown for list of impacted CPUs.
For more information about non-Arm CPUs, please contact the CPU vendor.
9.6.3. Variant 3 (CVE-2017-5754)
This variant is only exploitable between Exception Levels within the same translation regime, for example between EL0 and EL1, therefore this variant cannot be used to access secure memory from the non-secure world, and is not applicable for TF. However, Secure Payloads (for example, Trusted OS) should provide mitigations on vulnerable CPUs to protect themselves from exploited Secure-EL0 applications.
9.6.4. Variant 3a (CVE-2018-3640)
In general, it is not believed that software mitigations for this issue are necessary.
9.6.5. Variant 4 (CVE-2018-3639)
Refer to Advisory TFV-7 (CVE-2018-3639) for further details on this variant.
9.6.6. Spectre-BHB (CVE-2022-23960)
Refer to Advisory TFV-9 (CVE-2022-23960) for further details on this variant.
