2.6. Build Options
The TF-A build system supports the following build options. Unless mentioned otherwise, these options are expected to be specified at the build command line and are not to be modified in any component makefiles. Note that the build system doesn’t track dependency for build options. Therefore, if any of the build options are changed from a previous build, a clean build must be performed.
2.6.1. Common build options
AARCH32_INSTRUCTION_SET: Choose the AArch32 instruction set that the compiler should use. Valid values are T32 and A32. It defaults to T32 due to code having a smaller resulting size.AARCH32_SP: Choose the AArch32 Secure Payload component to be built as as the BL32 image whenARCH=aarch32. The value should be the path to the directory containing the SP source, relative to thebl32/; the directory is expected to contain a makefile called<aarch32_sp-value>.mk.ARM_BL2_SP_LIST_DTS: Path to DTS file snippet to override the hardcoded SP nodes in tb_fw_config.ARM_RECOM_STATE_ID_ENC: The PSCI1.0 specification recommends an encoding for the construction of composite state-ID in the power-state parameter. The existing PSCI clients currently do not support this encoding of State-ID yet. Hence this flag is used to configure whether to use the recommended State-ID encoding or not. The default value of this flag is 0, in which case the platform is configured to expect NULL in the State-ID field of power-state parameter.ARM_SPMC_MANIFEST_DTS: path to an alternate manifest file used as the SPMC Core manifest. Valid whenSPD=spmdis selected.BL2: This is an optional build option which specifies the path to BL2 image for thefiptarget. In this case, the BL2 in the TF-A will not be built.BL2U: This is an optional build option which specifies the path to BL2U image. In this case, the BL2U in TF-A will not be built.RESET_TO_BL2: Boolean option to enable BL2 entrypoint as the CPU reset vector instead of the BL1 entrypoint. It can take the value 0 (CPU reset to BL1 entrypoint) or 1 (CPU reset to BL2 entrypoint). The default value is 0.BL2_RUNS_AT_EL3: This is an implicit flag to denote that BL2 runs at EL3. While it is explicitly set to 1 when RESET_TO_BL2 is set to 1 it can also be true in a 4-world system where RESET_TO_BL2 is 0.BL2_INV_DCACHE: This is an optional build option which control dcache invalidation upon BL2 entry. Some platform cannot handle cache operations during entry as the coherency unit is not yet initialized. This may cause crashing. Leaving this option to ‘1’ (default) will allow the operation. This option is only relevant when BL2 is set to run at EL3.BL2_ENABLE_SP_LOAD: Boolean option to enable loading SP packages from the FIP. Automatically enabled ifSP_LAYOUT_FILEis provided.BL2_IN_XIP_MEM: In some use-cases BL2 will be stored in eXecute In Place (XIP) memory, like BL1. In these use-cases, it is necessary to initialize the RW sections in RAM, while leaving the RO sections in place. This option enable this use-case. For now, this option is only supported when RESET_TO_BL2 is set to ‘1’.BL31: This is an optional build option which specifies the path to BL31 image for thefiptarget. In this case, the BL31 in TF-A will not be built.BL31_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the BL31 private key in PEM format or a PKCS11 URI. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.BL32: This is an optional build option which specifies the path to BL32 image for thefiptarget. In this case, the BL32 in TF-A will not be built.BL32_EXTRA1: This is an optional build option which specifies the path to Trusted OS Extra1 image for thefiptarget.BL32_EXTRA2: This is an optional build option which specifies the path to Trusted OS Extra2 image for thefiptarget.BL32_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the BL32 private key in PEM format or a PKCS11 URI. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.RMM: This is an optional build option used whenENABLE_RMMis set. It specifies the path to RMM binary for thefiptarget. If the RMM option is not specified, TF-A builds the TRP to load and run at R-EL2.BL33: Path to BL33 image in the host file system. This is mandatory forfiptarget in case TF-A BL2 is used.BL33_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the BL33 private key in PEM format or a PKCS11 URI. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.BUILD_MESSAGE_TIMESTAMP: String used to identify the time and date of the compilation of each build. It must be set to a C string (including quotes where applicable). Defaults to a string that contains the time and date of the compilation.BUILD_STRING: Input string for VERSION_STRING, which allows the TF-A build to be uniquely identified. Defaults to the current git commit id.BUILD_BASE: Output directory for the build. Defaults to./buildCFLAGS: Extra user options appended on the compiler’s command line in addition to the options set by the build system.COLD_BOOT_SINGLE_CPU: This option indicates whether the platform may release several CPUs out of reset. It can take either 0 (several CPUs may be brought up) or 1 (only one CPU will ever be brought up during cold reset). Default is 0. If the platform always brings up a single CPU, there is no need to distinguish between primary and secondary CPUs and the boot path can be optimised. Theplat_is_my_cpu_primary()andplat_secondary_cold_boot_setup()platform porting interfaces do not need to be implemented in this case.COT: When Trusted Boot is enabled, selects the desired chain of trust. Defaults totbbr.CRASH_REPORTING: A non-zero value enables a console dump of processor register state when an unexpected exception occurs during execution of BL31. This option defaults to the value ofDEBUG- i.e. by default this is only enabled for a debug build of the firmware.CREATE_KEYS: This option is used whenGENERATE_COT=1. It tells the certificate generation tool to create new keys in case no valid keys are present or specified. Allowed options are ‘0’ or ‘1’. Default is ‘1’.DEBUG: Chooses between a debug and release build. It can take either 0 (release) or 1 (debug) as values. 0 is the default.DECRYPTION_SUPPORT: This build flag enables the user to select the authenticated decryption algorithm to be used to decrypt firmware/s during boot. It accepts 3 values:aes_ccm,aes_gcmandnone. The default value of this flag isnoneto disable firmware decryption which is an optional feature as per TBBR.DISABLE_BIN_GENERATION: Boolean option to disable the generation of the binary image. If set to 1, then only the ELF image is built. 0 is the default.DYN_DISABLE_AUTH: Provides the capability to dynamically disable Trusted Board Boot authentication at runtime. This option is meant to be enabled only for development platforms.TRUSTED_BOARD_BOOTflag must be set if this flag has to be enabled. 0 is the default.E: Boolean option to make warnings into errors. Default is 1.When specifying higher warnings levels (
W=1and higher), this option defaults to 0. This is done to encourage contributors to use them, as they are expected to produce warnings that would otherwise fail the build. New contributions are still expected to build withW=0andE=1(the default).EARLY_CONSOLE: This option is used to enable early traces before default console is properly setup. It introduces EARLY_* traces macros, that will use the non-EARLY traces macros if the flag is enabled, or do nothing otherwise. To use this feature, platforms will have to create the function plat_setup_early_console(). Default is 0 (disabled)EL3_PAYLOAD_BASE: This option enables booting an EL3 payload instead of the normal boot flow. It must specify the entry point address of the EL3 payload. Please refer to the “Booting an EL3 payload” section for more details.ENABLE_AMU_AUXILIARY_COUNTERS: Enables support for AMU auxiliary counters (also known as group 1 counters). These are implementation-defined counters, and as such require additional platform configuration. Default is 0.ENABLE_ASSERTIONS: This option controls whether or not calls toassert()are compiled out. For debug builds, this option defaults to 1, and calls toassert()are left in place. For release builds, this option defaults to 0 and calls toassert()function are compiled out. This option can be set independently ofDEBUG. It can also be used to hide any auxiliary code that is only required for the assertion and does not fit in the assertion itself.ENABLE_BACKTRACE: This option controls whether to enable backtrace dumps or not. It is supported in both AArch64 and AArch32. However, in AArch32 the format of the frame records are not defined in the AAPCS and they are defined by the implementation. This implementation of backtrace only supports the format used by GCC when T32 interworking is disabled. For this reason enabling this option in AArch32 will force the compiler to only generate A32 code. This option is enabled by default only in AArch64 debug builds, but this behaviour can be overridden in each platform’s Makefile or in the build command line.ENABLE_LTO: Boolean option to enable Link Time Optimization (LTO) support. This option is currently only supported for AArch64. On GCC it only applies to TF-A proper, and not its libraries. If LTO on libraries (except the libc) is desired a platform can pass -flto -ffat-lto-objects as long as GCC >= 14 is in use.ENABLE_LTOis enabled by default on release builds. Default is 0.ENABLE_MPMM: Boolean option to enable support for the Maximum Power Mitigation Mechanism supported by certain Arm cores, which allows the SoC firmware to detect and limit high activity events to assist in SoC processor power domain dynamic power budgeting and limit the triggering of whole-rail (i.e. clock chopping) responses to overcurrent conditions. Defaults to0.ENABLE_PIE: Boolean option to enable Position Independent Executable(PIE) support within generic code in TF-A. This option is currently only supported in BL2, BL31, and BL32 (TSP) for AARCH64 binaries, and in BL32 (SP_min) for AARCH32. Default is 0.ENABLE_PMF: Boolean option to enable support for optional Performance Measurement Framework(PMF). Default is 0.ENABLE_PSCI_STAT: Boolean option to enable support for optional PSCI functionsPSCI_STAT_RESIDENCYandPSCI_STAT_COUNT. Default is 0. In the absence of an alternate stat collection backend,ENABLE_PMFmust be enabled. IfENABLE_PMFis set, the residency statistics are tracked in software.ENABLE_RUNTIME_INSTRUMENTATION: Boolean option to enable runtime instrumentation which injects timestamp collection points into TF-A to allow runtime performance to be measured. Currently, only PSCI is instrumented. Enabling this option enables theENABLE_PMFbuild option as well. Default is 0.ENABLE_STACK_PROTECTOR: String option to enable the stack protection checks in GCC. Allowed values are “all”, “strong”, “default” and “none”. The default value is set to “none”. “strong” is the recommended stack protection level if this feature is desired. “none” disables the stack protection. For all values other than “none”, theplat_get_stack_protector_canary()platform hook needs to be implemented. The value is passed as the last component of the option-fstack-protector-$ENABLE_STACK_PROTECTOR.ENABLE_ERRATA_ALL: This option is used only for testing purposes, Booleanoption to enable the workarounds for all errata that TF-A implements. Normally they should be explicitly enabled depending on each platform’s needs. Not recommended for release builds. This option is default set to 0.
ENCRYPT_BL31: Binary flag to enable encryption of BL31 firmware. This flag depends onDECRYPTION_SUPPORTbuild flag.ENCRYPT_BL32: Binary flag to enable encryption of Secure BL32 payload. This flag depends onDECRYPTION_SUPPORTbuild flag.ENCRYPT_BL33: Binary flag to enable encryption of BL33 non-trusted firmware. This flag depends on theDECRYPTION_SUPPORTbuild flag. Note that BL33 encryption offers confidentiality against offline firmware extraction or cloning. However, since BL33 eventually executes in the Normal World, its decrypted contents can be generally accessible after decryption and handoff.ENC_KEY: A 32-byte (256-bit) symmetric key in hex string format. It could either be SSK or BSSK depending onFW_ENC_STATUSflag. This value depends onDECRYPTION_SUPPORTbuild flag.ENC_NONCE: A 12-byte (96-bit) encryption nonce or Initialization Vector (IV) in hex string format. This value depends onDECRYPTION_SUPPORTbuild flag.ERROR_DEPRECATED: This option decides whether to treat the usage of deprecated platform APIs, helper functions or drivers within Trusted Firmware as error. It can take the value 1 (flag the use of deprecated APIs as error) or 0. The default is 0.ETHOSN_NPU_DRIVER: boolean option to enable a SiP service that can configure an Arm® Ethos™-N NPU. To use this service the target platform’sHW_CONFIGmust include the device tree nodes for the NPU. Currently, only the Arm Juno platform has this included in itsHW_CONFIGand the platform only loads theHW_CONFIGin AArch64 builds. Default is 0.ETHOSN_NPU_TZMP1: boolean option to enable TZMP1 support for the Arm® Ethos™-N NPU. RequiresETHOSN_NPU_DRIVERandTRUSTED_BOARD_BOOTto be enabled.ETHOSN_NPU_FW: location of the NPU firmware binary (`ethosn.bin`). This firmware image will be included in the FIP and loaded at runtime.EL3_EXCEPTION_HANDLING: When set to1, enable handling of exceptions targeted at EL3. When set0(default), no exceptions are expected or handled at EL3, and a panic will result. The exception to this rule is whenSPMD_SPM_AT_SEL2is set to1, in which case, only exceptions occuring during normal world execution, are trapped to EL3. Any exception trapped during secure world execution are trapped to the SPMC. This is supported only for AArch64 builds.FAULT_INJECTION_SUPPORT: Boolean option to enable FEAT_RASv1p1 fault injection. When unset, all accesses will be trapped to EL3 and emulated as RAZ/WI. Default value is0.This feature is intended for testing purposes only, and is advisable to keep disabled for production images.
FIP_NAME: This is an optional build option which specifies the FIP filename for thefiptarget. Default isfip.bin.FWU_FIP_NAME: This is an optional build option which specifies the FWU FIP filename for thefwu_fiptarget. Default isfwu_fip.bin.FW_ENC_STATUS: Top level firmware’s encryption numeric flag, values:0: Encryption is done with Secret Symmetric Key (SSK) which is common for a class of devices. 1: Encryption is done with Binding Secret Symmetric Key (BSSK) which is unique per device.
DECRYPTION_SUPPORTbuild flag.GENERATE_COT: Boolean flag used to build and execute thecert_createtool to create certificates as per the Chain of Trust described in Trusted Board Boot. The build system then callsfiptoolto include the certificates in the FIP and FWU_FIP. Default value is ‘0’.Specify both
TRUSTED_BOARD_BOOT=1andGENERATE_COT=1to include support for the Trusted Board Boot feature in the BL1 and BL2 images, to generate the corresponding certificates, and to include those certificates in the FIP and FWU_FIP.Note that if
TRUSTED_BOARD_BOOT=0andGENERATE_COT=1, the BL1 and BL2 images will not include support for Trusted Board Boot. The FIP will still include the corresponding certificates. This FIP can be used to verify the Chain of Trust on the host machine through other mechanisms.Note that if
TRUSTED_BOARD_BOOT=1andGENERATE_COT=0, the BL1 and BL2 images will include support for Trusted Board Boot, but the FIP and FWU_FIP will not include the corresponding certificates, causing a boot failure.GICV2_G0_FOR_EL3: Unlike GICv3, the GICv2 architecture doesn’t have inherent support for specific EL3 type interrupts. Setting this build option to1assumes GICv2 Group 0 interrupts are expected to target EL3, both by platform abstraction layer and Interrupt Management Framework. This allows GICv2 platforms to enable features requiring EL3 interrupt type. This also means that all GICv2 Group 0 interrupts are delivered to EL3, and the Secure Payload interrupts needs to be synchronously handed over to Secure EL1 for handling. The default value of this option is0, which means the Group 0 interrupts are assumed to be handled by Secure EL1.HANDLE_EA_EL3_FIRST_NS: When set to1, External Aborts and SError Interrupts, resulting from errors in NS world, will be always trapped in EL3 i.e. in BL31 at runtime. When set to0(default), these exceptions will be trapped in the current exception level (or in EL1 if the current exception level is EL0).HW_ASSISTED_COHERENCY: On most Arm systems to-date, platform-specific software operations are required for CPUs to enter and exit coherency. However, newer systems exist where CPUs’ entry to and exit from coherency is managed in hardware. Such systems require software to only initiate these operations, and the rest is managed in hardware, minimizing active software management. In such systems, this boolean option enables TF-A to carry out build and run-time optimizations during boot and power management operations. This option defaults to 0 and if it is enabled, then it impliesWARMBOOT_ENABLE_DCACHE_EARLYis also enabled.If this flag is disabled while the platform which TF-A is compiled for includes cores that manage coherency in hardware, then a compilation error is generated. This is based on the fact that a system cannot have, at the same time, cores that manage coherency in hardware and cores that don’t. In other words, a platform cannot have, at the same time, cores that require
HW_ASSISTED_COHERENCY=1and cores that requireHW_ASSISTED_COHERENCY=0.Note that, when
HW_ASSISTED_COHERENCYis enabled, version 2 of translation library (xlat tables v2) must be used; version 1 of translation library is not supported.IMPDEF_SYSREG_TRAP: Numeric value to enable the handling traps for implementation defined system register accesses from lower ELs. Default value is0.INVERTED_MEMMAP: memmap tool print by default lower addresses at the bottom, higher addresses at the top. This build flag can be set to ‘1’ to invert this behavior. Lower addresses will be printed at the top and higher addresses at the bottom.INIT_UNUSED_NS_EL2: This build flag guards code that disables EL2 safely in scenario where NS-EL2 is present but unused. This flag is set to 0 by default. Platforms without NS-EL2 in use must enable this flag.KEY_ALG: This build flag enables the user to select the algorithm to be used for generating the PKCS keys and subsequent signing of the certificate. It accepts 5 values:rsa,rsa_1_5,ecdsa,ecdsa-brainpool-regularandecdsa-brainpool-twisted. The optionrsa_1_5is the legacy PKCS#1 RSA 1.5 algorithm which is not TBBR compliant and is retained only for compatibility. The default value of this flag isrsawhich is the TBBR compliant PKCS#1 RSA 2.1 scheme.KEY_SIZE: This build flag enables the user to select the key size for the algorithm specified byKEY_ALG. The valid values forKEY_SIZEdepend on the chosen algorithm and the cryptographic module.KEY_ALG
Possible key sizes
rsa
1024 , 2048 (default), 3072, 4096
ecdsa
256 (default), 384
256 (default)
256 (default)
HASH_ALG: This build flag enables the user to select the secure hash algorithm. It accepts 3 values:sha256,sha384andsha512. The default value of this flag issha256.HW_CONFIG_BASE: This option specifies the location in memory where the DTBshould either be loaded by BL2 or can be found by later stages.
LDFLAGS: Extra user options appended to the linkers’ command line in addition to the one set by the build system.LOG_LEVEL: Chooses the log level, which controls the amount of console log output compiled into the build. This should be one of the following:0 (LOG_LEVEL_NONE) 10 (LOG_LEVEL_ERROR) 20 (LOG_LEVEL_NOTICE) 30 (LOG_LEVEL_WARNING) 40 (LOG_LEVEL_INFO) 50 (LOG_LEVEL_VERBOSE)
All log output up to and including the selected log level is compiled into the build. The default value is 40 in debug builds and 20 in release builds.
LOG_DEBUG: Boolean option to enable support for module level internal logs. There can be situation where a module has detail internal debugging logs, these debugging logs may not be required to print even when log level is VERBOSE. Such logs can be put under this flag. This is a file level build flag. By default this should be disabled (0) in each file.MEASURED_BOOT: Boolean flag to include support for the Measured Boot feature. This flag can be enabled withTRUSTED_BOARD_BOOTin order to provide trust that the code taking the measurements and recording them has not been tampered with.This option defaults to 0.
DISCRETE_TPM: Boolean flag to include support for a Discrete TPM.This option defaults to 0.
TPM_INTERFACE: WhenDISCRETE_TPM=1, this is a required flag to select the TPM interface. Currently only one interface is supported:FIFO_SPIMBOOT_TPM_HASH_ALG: Build flag to select the TPM hash algorithm used during Measured Boot. Currently acceptssha256andsha384as valid algorithms.MARCH_DIRECTIVE: used to pass a -march option from the platform build options to the compiler. An example usage:MARCH_DIRECTIVE := -march=armv8.5-a
HARDEN_SLS: used to pass -mharden-sls=all from the TF-A build options to the compiler currently supporting only of the options. GCC documentation: https://gcc.gnu.org/onlinedocs/gcc/AArch64-Options.html#index-mharden-slsAn example usage:
HARDEN_SLS := 1
NON_TRUSTED_WORLD_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the Non-Trusted World private key in PEM format or a PKCS11 URI. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.NS_BL2U: Path to NS_BL2U image in the host file system. This image is optional. It is only needed if the platform makefile specifies that it is required in order to build thefwu_fiptarget.OVERRIDE_LIBC: This option allows platforms to override the default libc for the BL image. It can be either 0 (include) or 1 (remove). The default value is 0.PL011_GENERIC_UART: Boolean option to indicate the PL011 driver that the underlying hardware is not a full PL011 UART but a minimally compliant generic UART, which is a subset of the PL011. The driver will not access any register that is not part of the SBSA generic UART specification. Default value is 0 (a full PL011 compliant UART is present).PLAT: Choose a platform to build TF-A for. The chosen platform name must be subdirectory of any depth underplat/, and must contain a platform makefile namedplatform.mk. For example, to build TF-A for the Arm Juno board, select PLAT=juno.PLATFORM_REPORT_CTX_MEM_USE: Reports the context memory allocated for each core as well as the global context. The data includes the memory used by each world and each privileged exception level. This build option is applicable only forARCH=aarch64builds. The default value is 0.PLAT_EXTRA_LD_SCRIPT: Allows the platform to include a custom LD scriptsnippet for any custom sections that cannot be expressed otherwise. Defaults to 0.
PRELOADED_BL33_BASE: This option enables booting a preloaded BL33 image instead of the normal boot flow. When defined, it must specify the entry point address for the preloaded BL33 image. This option is incompatible withEL3_PAYLOAD_BASE. If both are defined,EL3_PAYLOAD_BASEhas priority overPRELOADED_BL33_BASE.PRESERVE_DSU_PMU_REGS: This options when enabled allows the platform to save/restore the DynamIQ Shared Unit’s(DSU) Performance Monitoring Unit(PMU) registers when the cluster goes through a power cycle. This is disabled by default and platforms that require this feature have to enable them.PROGRAMMABLE_RESET_ADDRESS: This option indicates whether the reset vector address can be programmed or is fixed on the platform. It can take either 0 (fixed) or 1 (programmable). Default is 0. If the platform has a programmable reset address, it is expected that a CPU will start executing code directly at the right address, both on a cold and warm reset. In this case, there is no need to identify the entrypoint on boot and the boot path can be optimised. Theplat_get_my_entrypoint()platform porting interface does not need to be implemented in this case.PSCI_EXTENDED_STATE_ID: As per PSCI1.0 Specification, there are 2 formats possible for the PSCI power-state parameter: original and extended State-ID formats. This flag if set to 1, configures the generic PSCI layer to use the extended format. The default value of this flag is 0, which means by default the original power-state format is used by the PSCI implementation. This flag should be specified by the platform makefile and it governs the return value of PSCI_FEATURES API for CPU_SUSPEND smc function id. When this option is enabled on Arm platforms, the optionARM_RECOM_STATE_ID_ENCneeds to be set to 1 as well.PSCI_OS_INIT_MODE: Boolean flag to enable support for optional PSCI OS-initiated mode. This option defaults to 0.ARCH_FEATURE_AVAILABILITY: Boolean flag to enable support for the optional SMCCC_ARCH_FEATURE_AVAILABILITY call. This option implicitly interacts with IMPDEF_SYSREG_TRAP and software emulation. This option defaults to 0.RESET_TO_BL31: Enable BL31 entrypoint as the CPU reset vector instead of the BL1 entrypoint. It can take the value 0 (CPU reset to BL1 entrypoint) or 1 (CPU reset to BL31 entrypoint). The default value is 0.RESET_TO_SP_MIN: SP_MIN is the minimal AArch32 Secure Payload provided in TF-A. This flag configures SP_MIN entrypoint as the CPU reset vector instead of the BL1 entrypoint. It can take the value 0 (CPU reset to BL1 entrypoint) or 1 (CPU reset to SP_MIN entrypoint). The default value is 0.RME_GPT_BITLOCK_BLOCK: This defines the block size (in number of 512MB blocks) covered by a single bit of the bitlock structure during RME GPT operations. The lower the block size, the better opportunity for parallelising GPT operations but at the cost of more bits being needed for the bitlock structure. This numeric parameter can take the values from 0 to 512 and must be a power of 2. The value of 0 is special and and it chooses a single spinlock for all GPT L1 table entries. Default value is 1 which corresponds to block size of 512MB per bit of bitlock structure.RME_GPT_MAX_BLOCK: Numeric value in MB to define the maximum size of supported contiguous blocks in GPT Library. This parameter can take the values 0, 2, 32 and 512. Setting this value to 0 disables use of Contigious descriptors. Default value is 512.ROT_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the ROT private key in PEM format or a PKCS11 URI and enforces public key hash generation. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.SAVE_KEYS: This option is used whenGENERATE_COT=1. It tells the certificate generation tool to save the keys used to establish the Chain of Trust. Allowed options are ‘0’ or ‘1’. Default is ‘0’ (do not save).SCP_BL2: Path to SCP_BL2 image in the host file system. This image is optional. If a SCP_BL2 image is present then this option must be passed for thefiptarget.SCP_BL2_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the SCP_BL2 private key in PEM format or a PKCS11 URI. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.SCP_BL2U: Path to SCP_BL2U image in the host file system. This image is optional. It is only needed if the platform makefile specifies that it is required in order to build thefwu_fiptarget.SDEI_SUPPORT: Setting this to1enables support for Software Delegated Exception Interface to BL31 image. This defaults to0.When set to
1, the build optionEL3_EXCEPTION_HANDLINGmust also be set to1.SEPARATE_CODE_AND_RODATA: Whether code and read-only data should be isolated on separate memory pages. This is a trade-off between security and memory usage. See “Isolating code and read-only data on separate memory pages” section in Firmware Design. This flag is disabled by default and affects all BL images.SEPARATE_NOBITS_REGION: Setting this option to1allows the NOBITS sections of BL31 (.bss, stacks, page tables, and coherent memory) to be allocated in RAM discontiguous from the loaded firmware image. When set, the platform is expected to provide definitions forBL31_NOBITS_BASEandBL31_NOBITS_LIMIT. When the option is0(the default), NOBITS sections are placed in RAM immediately following the loaded firmware image.SEPARATE_BL2_NOLOAD_REGION: Setting this option to1allows the NOLOAD sections of BL2 (.bss, stacks, page tables) to be allocated in RAM discontiguous from loaded firmware images. When set, the platform need to provide definitions ofBL2_NOLOAD_STARTandBL2_NOLOAD_LIMIT. This flag is disabled by default and NOLOAD sections are placed in RAM immediately following the loaded firmware image.SEPARATE_BL2_FIP: This option enables the separation of the BL2 FIP image from the main FIP image. When this option is enabled, the BL2 FIP image is built as a separate FIP image. The default value is 0.SEPARATE_SIMD_SECTION: Setting this option to1allows the SIMD contextdata structures to be put in a dedicated memory region as decided by platform integrator. Default value is
0which means the SIMD context is put in BSS section of EL3 firmware.
SMC_PCI_SUPPORT: This option allows platforms to handle PCI configuration access requests via a standard SMCCC defined in DEN0115. When combined with UEFI+ACPI this can provide a certain amount of OS forward compatibility with newer platforms that aren’t ECAM compliant.SPD: Choose a Secure Payload Dispatcher component to be built into TF-A. This build option is only valid ifARCH=aarch64. The value should be the path to the directory containing the SPD source, relative toservices/spd/; the directory is expected to contain a makefile called<spd-value>.mk. The SPM Dispatcher standard service is located in services/std_svc/spmd and enabled bySPD=spmd.SPIN_ON_BL1_EXIT: This option introduces an infinite loop in BL1. It can take either 0 (no loop) or 1 (add a loop). 0 is the default. This loop stops execution in BL1 just before handing over to BL31. At this point, all firmware images have been loaded in memory, and the MMU and caches are turned off. Refer to the “Debugging options” section for more details.SPMC_AT_EL3: This boolean option is used jointly with the SPM Dispatcher option (SPD=spmd). When enabled (1) it indicates the SPMC component runs at the EL3 exception level. The default value is0( disabled). This configuration supports pre-Armv8.4 platforms (aka not implementing theFEAT_SEL2extension).SPMC_AT_EL3_SEL0_SP: Boolean option to enable SEL0 SP load support whenSPMC_AT_EL3is enabled. The default value if0(disabled). This option cannot be enabled (1) when (SPMC_AT_EL3) is disabled.SPMC_OPTEE: This boolean option is used jointly with the SPM Dispatcher option (SPD=spmd) and withSPMD_SPM_AT_SEL2=0to indicate that the SPMC at S-EL1 is OP-TEE and an OP-TEE specific loading mechanism should be used.SPMD_SPM_AT_SEL2: This boolean option is used jointly with the SPM Dispatcher option (SPD=spmd). When enabled (1) it indicates the SPMC component runs at the S-EL2 exception level provided by theFEAT_SEL2extension. This is the default when enabling the SPM Dispatcher. When disabled (0) it indicates the SPMC component runs at the S-EL1 execution state or at EL3 ifSPMC_AT_EL3is enabled. The latter configurations support pre-Armv8.4 platforms (aka not implementing theFEAT_SEL2extension).SP_LAYOUT_FILE: Platform provided path to JSON file containing the description of secure partitions. The build system will parse this file and package all secure partition blobs into the FIP. This file is not necessarily part of TF-A tree. Only available whenSPD=spmd.SP_MIN_WITH_SECURE_FIQ: Boolean flag to indicate the SP_MIN handles secure interrupts (caught through the FIQ line). Platforms can enable this directive if they need to handle such interruption. When enabled, the FIQ are handled in monitor mode and non secure world is not allowed to mask these events. Platforms that enable FIQ handling in SP_MIN shall implement the apisp_min_plat_fiq_handler(). The default value is 0.SVE_VECTOR_LEN: SVE vector length to configure in ZCR_EL3. Platforms can configure this if they need to lower the hardware limit, for example due to asymmetric configuration or limitations of software run at lower ELs. The default is the architectural maximum of 2048 which should be suitable for most configurations, the hardware will limit the effective VL to the maximum physically supported VL.TRNG_SUPPORT: Setting this to1enables support for True Random Number Generator Interface to BL31 image. This defaults to0.TRUSTED_BOARD_BOOT: Boolean flag to include support for the Trusted Board Boot feature. When set to ‘1’, BL1 and BL2 images include support to load and verify the certificates and images in a FIP, and BL1 includes support for the Firmware Update. The default value is ‘0’. Generation and inclusion of certificates in the FIP and FWU_FIP depends upon the value of theGENERATE_COToption.Warning
This option depends on
CREATE_KEYSto be enabled. If the keys already exist in disk, they will be overwritten without further notice.TRUSTED_WORLD_KEY: This option is used whenGENERATE_COT=1. It specifies a file that contains the Trusted World private key in PEM format or a PKCS11 URI. IfSAVE_KEYS=1, only a file is accepted and it will be used to save the key.TSP_INIT_ASYNC: Choose BL32 initialization method as asynchronous or synchronous, (see “Initializing a BL32 Image” section in Firmware Design). It can take the value 0 (BL32 is initialized using synchronous method) or 1 (BL32 is initialized using asynchronous method). Default is 0.TSP_NS_INTR_ASYNC_PREEMPT: A non zero value enables the interrupt routing model which routes non-secure interrupts asynchronously from TSP to EL3 causing immediate preemption of TSP. The EL3 is responsible for saving and restoring the TSP context in this routing model. The default routing model (when the value is 0) is to route non-secure interrupts to TSP allowing it to save its context and hand over synchronously to EL3 via an SMC.Note
When
EL3_EXCEPTION_HANDLINGis1,TSP_NS_INTR_ASYNC_PREEMPTmust also be set to1.TS_SP_FW_CONFIG: DTC build flag to include Trusted Services (Crypto and internal-trusted-storage) as SP in tb_fw_config device tree.TWED_DELAY: Numeric value to be set in order to delay the trapping of WFE instruction.ENABLE_FEAT_TWEDbuild option must be enabled to set this delay. It can take values in the range (0-15). Default value is0and based on this value, 2^(TWED_DELAY + 8) cycles will be delayed. Platforms need to explicitly update this value based on their requirements.USE_ARM_LINK: This flag determines whether to enable support for ARM linker. When theLINKERbuild variable points to the armlink linker, this flag is enabled automatically. To enable support for armlink, platforms will have to provide a scatter file for the BL image. Currently, Tegra platforms use the armlink support to compile BL3-1 images.USE_COHERENT_MEM: This flag determines whether to include the coherent memory region in the BL memory map or not (see “Use of Coherent memory in TF-A” section in Firmware Design). It can take the value 1 (Coherent memory region is included) or 0 (Coherent memory region is excluded). Default is 1.USE_KERNEL_DT_CONVENTION: When this option is enabled, the hardware device tree is passed to BL33 using register x0, aligning with the expectations of the Linux kernel on Arm platforms. If this option is disabled, a different register, typically x1, may be used instead. This build option is not necessary when firmware handoff is active (that is, when TRANSFER_LIST=1 is set), and it will be removed once all platforms have transitioned to that convention.USE_DSU_DRIVER: This flag enables DSU (DynamIQ Shared Unit) driver. The DSU driver allows save/restore of DSU PMU registers throughPRESERVE_DSU_PMU_REGSbuild option, provides access to PMU registers at EL1 and allows platforms to configure powerdown and power settings of DSU.DSU_PDL2_SUPPORT: Boolean option to indicate that the platform uses two CPU-level power domains CPUL1PD and CPUL2P2. In such platforms: the core PDL2 power domain contains the core L2, debug and trace logic, as well as part of the core asynchronous bridge that belongs to the VCORE voltage domain. The PDL1 power domain contains the rest of the core logic. This requiresUSE_DSU_DRIVER.ARM_IO_IN_DTB: This flag determines whether to use IO based on the firmware configuration framework. This will move the io_policies into a configuration device tree, instead of static structure in the code base.COT_DESC_IN_DTB: This flag determines whether to create COT descriptors at runtime using fconf. If this flag is enabled, COT descriptors are statically captured in tb_fw_config file in the form of device tree nodes and properties. Currently, COT descriptors used by BL2 are moved to the device tree and COT descriptors used by BL1 are retained in the code base statically.SDEI_IN_FCONF: This flag determines whether to configure SDEI setup in runtime using firmware configuration framework. The platform specific SDEI shared and private events configuration is retrieved from device tree rather than static C structures at compile time. This is only supported if SDEI_SUPPORT build flag is enabled.SEC_INT_DESC_IN_FCONF: This flag determines whether to configure Group 0 and Group1 secure interrupts using the firmware configuration framework. The platform specific secure interrupt property descriptor is retrieved from device tree in runtime rather than depending on static C structure at compile time.USE_ROMLIB: This flag determines whether library at ROM will be used. This feature creates a library of functions to be placed in ROM and thus reduces SRAM usage. Refer to Library at ROM for further details. Default is 0.V: Verbose build. If assigned anything other than 0, the build commands are printed. Default is 0.VERSION_STRING: String used in the log output for each TF-A image. Defaults to a string formed by concatenating the version number, build type and build string.W: Warning level. Some compiler warning options of interest have been regrouped and put in the root Makefile. This flag can take the values 0 to 3, each level enabling more warning options. Default is 0.This option is closely related to the
Eoption, which enables-Werror.W=0(default)Enables a wide assortment of warnings, most notably
-Walland-Wextra, as well as various bad practices and things that are likely to result in errors. Includes some compiler specific flags. No warnings are expected at this level for any build.W=1Enables warnings we want the generic build to include but are too time consuming to fix at the moment. It re-enables warnings taken out for
W=0builds (a few of the-Wextraadditions). This level is expected to eventually be merged intoW=0. Some warnings are expected on some builds, but new contributions should not introduce new ones.W=2(recommended)
Enables warnings we want the generic build to include but cannot be enabled due to external libraries. This level is expected to eventually be merged into
W=0. Lots of warnings are expected, primarily from external libraries like zlib and compiler-rt, but new controbutions should not introduce new ones.W=3Enables warnings that are informative but not necessary and generally too verbose and frequently ignored. A very large number of warnings are expected.
The exact set of warning flags depends on the compiler and TF-A warning level, however they are all succinctly set in the top-level Makefile. Please refer to the GCC or Clang documentation for more information on the individual flags.
WARMBOOT_ENABLE_DCACHE_EARLY: Boolean option to enable D-cache early on the CPU after warm boot. This is applicable for platforms which do not require interconnect programming to enable cache coherency (eg: single cluster platforms). If this option is enabled, then warm boot path enables D-caches immediately after enabling MMU. This option defaults to 0.ERRATA_SPECULATIVE_AT: This flag determines whether to enableATspeculative errata workaround or not. It accepts 2 values:1and0. The default value of this flag is0.ATspeculative errata workaround disables stage1 page table walk for lower ELs (EL1 and EL0) in EL3 so thatATspeculative fetch at any point produces either the correct result or failure without TLB allocation.This boolean option enables errata for all below CPUs.
Errata
CPU
Workaround Define
1165522
Cortex-A76
ERRATA_A76_11655221319367
Cortex-A72
ERRATA_A72_13193671541130
Cortex-A65
ERRATA_A65_15411301638571
Cortex-A65AE
ERRATA_A65AE_16385711319537
Cortex-A57
ERRATA_A57_13195371530923
Cortex-A55
ERRATA_A55_15309231530924
Cortex-A53
ERRATA_A53_1530924Note
This option is enabled by build only if platform sets any of above defines mentioned in ’Workaround Define’ column in the table. If this option is enabled for the EL3 software then EL2 software also must implement this workaround due to the behaviour of the errata mentioned in new SDEN document which will get published soon.
RAS_TRAP_NS_ERR_REC_ACCESS: Boolean option to disable FEAT_RAS access to ERR and ERX registers from lower ELs. When set, all accesses will be trapped to EL3 and emulated as RAZ/WI. Default value is0.OPENSSL_DIR: This option is used to provide the path to a directory on the host machine where a custom installation of OpenSSL is located, which is used to build the certificate generation, firmware encryption and FIP tools. If this option is not set, the default OS installation will be used.USE_SP804_TIMER: Use the SP804 timer instead of the Generic Timer for functions that wait for an arbitrary time length (udelay and mdelay). The default value is 0.CONDITIONAL_CMO: Boolean option to enable call to platform-defined routineplat_can_cmowhich will return zero if cache management operations should be skipped and non-zero otherwise. By default, this option is disabled which means platform hook won’t be checked and CMOs will always be performed when related functions are called.ERRATA_ABI_SUPPORT: Boolean option to enable support for Errata management firmware interface for the BL31 image. By default its disabled (0).ERRATA_NON_ARM_INTERCONNECT: Boolean option to enable reporting of errata affecting platforms with a non-arm interconnect using the errata ABI. By default it is disabled (0).ENABLE_CONSOLE_GETC: Boolean option to enable getc() feature in console driver(s). By default it is disabled (0) because it constitutes an attack vector into TF-A by potentially allowing an attacker to inject arbitrary data. This option should only be enabled on a need basis if there is a use case for reading characters from the console.
2.6.2. CPU Architecture feature options
2.6.2.1. Meta options
ARCH: Choose the target build architecture for TF-A. It can take eitheraarch64oraarch32as values. By default, it is defined toaarch64.ARM_ARCH_MAJOR: The major version of Arm Architecture to target when compiling TF-A. Its value must be numeric, and defaults to 8 . See also, Armv8 Architecture Extensions and Armv7 Architecture Extensions in Firmware Design.ARM_ARCH_MINOR: The minor version of Arm Architecture to target when compiling TF-A. Its value must be a numeric, and defaults to 0. See also, Armv8 Architecture Extensions in Firmware Design.ARM_ARCH_FEATURE: Optional Arm Architecture build option which specifies one or more feature modifiers. This option has the form[no]feature+...and defaults tonone. It translates into compiler option-march=armvX[.Y]-a+[no]feature+.... See compiler’s documentation for the list of supported feature modifiers.
2.6.2.2. CPU feature enables
This section describes flags that control the enablement of Architectural features in the A class Armv8.0+ architecture. Unless stated otherwise, these flags support The ENABLE_FEAT mechanism and take numeric values from 0 to 2.
FEATURE_DETECTION: Boolean option to enable the architectural features verification mechanism. This is a debug feature that compares the architectural features enabled through the feature specific build flags (ENABLE_FEAT_xxx) with the features actually available on the CPU running, and reports any discrepancies.It is expected that this feature is only used for flexible platforms like software emulators, or for hardware platforms at bringup time, to verify that the configured feature set matches the CPU. Default value is
0.CTX_INCLUDE_NEVE_REGS: When set, causes the Armv8.4-NV registers to be saved/restored when entering/exiting an EL2 execution context. Default value is 0.CTX_INCLUDE_PAUTH_REGS: Enables Pointer Authentication for Secure world. This will cause the ARMv8.3-PAuth registers to be included when saving and restoring the CPU context as part of world switch. Automatically enabled whenBRANCH_PROTECTIONis enabled. Default value is 0.Note that Pointer Authentication is enabled for Non-secure world irrespective of the value of this flag if the CPU supports it. Alternatively, when
BRANCH_PROTECTIONis enabled, this flag is superseded.CTX_INCLUDE_AARCH32_REGS: Boolean option that, when set to 1, will cause the AArch32 system registers to be included when saving and restoring the CPU context. The option must be set to 0 for AArch64-only platforms (that is on hardware that does not implement AArch32, or at least not at EL1 and higher ELs). Default value is 1.CTX_INCLUDE_FPREGS: Boolean option that, when set to 1, will cause the FP registers to be included when saving and restoring the CPU context. Default is 0.CTX_INCLUDE_MPAM_REGS: Boolean option that, when set to 1, will cause the Memory System Resource Partitioning and Monitoring (MPAM) registers to be included when saving and restoring the CPU context. Default is ‘0’.CTX_INCLUDE_SVE_REGS: Boolean option that, when set to 1, will cause the SVE registers to be included when saving and restoring the CPU context. Note that this build option requiresENABLE_SVE_FOR_SWDto be enabled. In general, it is recommended to perform SVE context management in lower ELs and skip in EL3 due to the additional cost of maintaining large data structures to track the SVE state. Hence, the default value is 0.DISABLE_MTPMU: DisablesFEAT_MTPMU(Multi Threaded PMU).FEAT_MTPMUis an optional feature available on Armv8.6 onwards. Default is0.ENABLE_FEAT_AMU: Enables Activity Monitor Unit extensions. This is an optional architectural feature available on v8.4 onwards. Some v8.2 implementations also implement an AMU and this option can be used to enable this feature on those systems as well. The default is 0.AMU_RESTRICT_COUNTERS: Register reads to the group 1 counters will return zero at all but the highest implemented exception level. External memory-mapped debug accesses are unaffected by this control. The default value is 1 for all platforms.ENABLE_FEAT_AMUv1p1: Enables theFEAT_AMUv1p1extension.FEAT_AMUv1p1is an optional feature available on Arm v8.6 onwards. Default value is0.ENABLE_FEAT_CLRBHB: Enables the CLRBHB instruction.Clear Branch History clears the branch history for the current context to the extent that branch history information created before the CLRBHB instruction cannot be used by code. This is an optional architectural feature available on v8.0 onwards and is a mandatory feature from v8.9 onwards. Default value is
0.
ENABLE_FEAT_CPA2: Enables theFEAT_CPA2extension. It enables checked pointer arithmetic in EL3, which will result in address faults in the event that a pointer arithmetic overflow error occurs. This is an optional feature starting from Arm v9.4. Default value is0.ENABLE_FEAT_CSV2_2: Enables theFEAT_CSV2_2extension. It allows access to the SCXTNUM_EL2 (Software Context Number) register during EL2 context save/restore operations.FEAT_CSV2_2is an optional feature available on Arm v8.0 onwards. Default value is0.ENABLE_FEAT_CSV2_3: Enables support forFEAT_CSV2_3extension. This feature is supported in AArch64 state only and is an optional feature available in Arm v8.0 implementations.FEAT_CSV2_3implies the implementation ofFEAT_CSV2_2. Default value is0.ENABLE_FEAT_CRYPTO: Enables theFEAT_CRYPTOextension. It allows using the SIMD crypto extension AES, SHA1 and SHA2 instructions for mbedtls HASH256, which speeds up the authentication process of the subsequent images in BL1 and BL2.FEAT_CRYPTOis an optional feature available on Arm v8 onwards. Setting this flag to 2 has the same effect as 0 since there is no way to do runtime checks. Default value is0.ENABLE_FEAT_CRYPTO_SHA3: Enables theFEAT_CRYPTOextension. It allows using the SIMD crypto extension SHA3 instructions for mbedtls HASH384 and HASH512, which speeds up the authentication process of the subsequent images in BL1 and BL2.FEAT_CRYPTO_SHA3is an optional feature available on Arm v8.2 onwards. Setting this flag to 2 has the same effect as 0 since there is no way to do runtime checks. Default value is0.ENABLE_FEAT_DEBUGV8P9: EnablesFEAT_DEBUGV8P9extension which allows the ability to implement more than 16 breakpoints and/or watchpoints. This feature is mandatory from v8.9 and is optional from v8.8. Default value is0.ENABLE_FEAT_DIT: EnablesFEAT_DIT(Data Independent Timing) extension. It allows setting theDITbit of PSTATE in EL3.FEAT_DITis a mandatory architectural feature and is enabled from v8.4 and upwards. Default value is0.ENABLE_FEAT_ECV: Enables support for the Enhanced Counter Virtualization feature, allowing for access to the CNTPOFF_EL2 (Counter-timer Physical Offset register) during EL2 to EL3 context save/restore operations. Its a mandatory architectural feature and is enabled from v8.6 and upwards. Default value is0.ENABLE_FEAT_FPMR: Enables support for Floating Point Mode Register feature, allowing access to the FPMR register. FPMR register controls the behaviors of FP8 instructions. It is an optional architectural feature from v9.2 and upwards. This flag can take value of 0 to 2, to align with theFEATURE_DETECTIONmechanism. Default value is0.ENABLE_FEAT_FGT: Enables support for FGT (Fine Grain Traps) feature allowing for access to the HDFGRTR_EL2 (Hypervisor Debug Fine-Grained Read Trap Register) during EL2 to EL3 context save/restore operations. Its a mandatory architectural feature and is enabled from v8.6 and upwards. Default value is0.ENABLE_FEAT_FGT2: Enables support for FGT2 (Fine Grain Traps 2) feature allowing for access to Fine-grained trap 2 registers during EL2 to EL3 context save/restore operations. Its an optional architectural feature and is available from v8.8 and upwards. Default value is0.ENABLE_FEAT_FGWTE3: Enables support for Fine Grained Write Trap EL3 (FEAT_FGWTE3), a feature that allows EL3 to restrict overwriting certain EL3 registers after boot. This lockdown is established by setting individual trap bits for system registers that are not expected to be overwritten after boot. This feature is an optional architectural feature and is available from Armv9.4 onwards. The default value is 0.Note
This feature currently traps access to all EL3 registers in
FGWTE3_EL3, except forMDCR_EL3,MPAM3_EL3,TPIDR_EL3``(when ``CRASH_REPORTING=1), andSCTLR_EL3``(when ``HW_ASSISTED_COHERENCY=0). If additional traps need to be disabled for specific platforms, please contact the Arm team on TF-A public mailing list.ENABLE_FEAT_HDBSS: Enables support for HDBSS (Hardware Dirty state tracking structure) by settingSCR_EL3.HDBSSEnfor NS world. This is an optional architectural feature and is available from v9.4 and upwards. Default value is0.ENABLE_FEAT_HACDBS: Enables support for HACDBS (Hardware accelerator for cleaning Dirty state) by settingSCR_EL3.HACDBSEnfor NS world. This is an optional architectural feature and is available from v9.4 and upwards. Default value is0.ENABLE_FEAT_HCX: Sets the bit SCR_EL3.HXEn in EL3 to allow access to HCRX_EL2 (extended hypervisor control register) from EL2 as well as adding HCRX_EL2 to the EL2 context save/restore operations. Its a mandatory architectural feature and is enabled from v8.7 and upwards. Default value is0.ENABLE_FEAT_IDTE3: Sets SCR_EL3.TID3/TID5 bits, which enables trapping of ID register reads by lower ELs to EL3. This allows EL3 to control the feature visibility to lower ELs by returning a sanitized value based on current feature enablement status. Hypervisors are expected to cache ID register during their boot stage. Default value is0. This feature is EXPERIMENTAL.Note
This feature traps all lower EL accesses to Group 3 and Group 5 ID registers to EL3. This can incur a performance impact and platforms should enable them only if they have a specific need.
ENABLE_FEAT_MOPS: Enables FEAT_MOPS (Standardization of memory operations) when INIT_UNUSED_NS_EL2=1. This feature is mandatory from v8.8 and enabling of FEAT_MOPS does not require any settings from EL3 as the controls are present in EL2 registers (HCRX_EL2.{MSCEn,MCE2} and SCTLR_EL2.MSCEn) and in most configurations we expect EL2 to be present. But in case of INIT_UNUSED_NS_EL2=1 , EL3 should configure the EL2 registers. Default value is0.ENABLE_FEAT_MTE2: Enables Memory Tagging Extension2 if the platform wants to use this feature and MTE2 is enabled at ELX. Default value is0.ENABLE_FEAT_PAN: Enables theFEAT_PAN(Privileged Access Never) extension.FEAT_PANadds a bit to PSTATE, generating a permission fault for any privileged data access from EL1/EL2 to virtual memory address, accessible at EL0, provided (HCR_EL2.E2H=1). It is a mandatory architectural feature and is enabled from v8.1 and upwards. Default value is0.BRANCH_PROTECTION: Enables ARMv8.3 Pointer Authentication and ARMv8.5 Branch Target Identification support for TF-A BL images themselves. If enabled, it is needed to use a compiler that supports the option-mbranch-protection. The value of the-march(viaARM_ARCH_MINORandARM_ARCH_MAJOR) option will control which instructions will be emitted (HINT space or not). Selects the branch protection features to use:0: Default value turns off all types of branch protection (FEAT_STATE_DISABLED)
1: Enables all types of branch protection features
2: Return address signing to its standard level
3: Extend the signing to include leaf functions
4: Turn on branch target identification mechanism
5: Enables all types of branch protection features, only if present in hardware (FEAT_STATE_CHECKED).
The table below summarizes
BRANCH_PROTECTIONvalues, GCC compilation options and resulting PAuth/BTI features.Value
GCC option
PAuth
BTI
0
none
N
N
1
standard
Y
Y
2
pac-ret
Y
N
3
pac-ret+leaf
Y
N
4
bti
N
Y
5
dynamic
Y
Y
This option defaults to 0. Note that Pointer Authentication is enabled for Non-secure world irrespective of the value of this option if the CPU supports it.
ENABLE_FEAT_PAUTH_LR: Enables the use ofFEAT_PAUTH_LRextension at EL3.FEAT_PAUTH_LRis an optional feature available from Arm v9.4 onwards. This feature requiresFEAT_PAuthto be enabled via theBRANCH_PROTECTIONflag. Default value is0.ENABLE_FEAT_RNG: Enables theFEAT_RNGextension.FEAT_RNGis an optional feature available on Arm v8.5 onwards. Default value is0.ENABLE_FEAT_RNG_TRAP: Enables theFEAT_RNG_TRAPextension. This feature is only supported in AArch64 state. Default value is0.FEAT_RNG_TRAPis an optional feature from Armv8.5 onwards.ENABLE_FEAT_SB: Lets the TF-A code use theFEAT_SB(Speculation Barrier) instructionFEAT_SBis an optional feature and defaults to0for pre-Armv8.5 CPUs, but is mandatory for Armv8.5 or later CPUs. It is enabled from v8.5 and upwards and if needed can be overidden from platforms explicitly. Default value is0.ENABLE_FEAT_SEL2: Enables theFEAT_SEL2(Secure EL2) extension.FEAT_SEL2is a mandatory feature available on Arm v8.4. Default is0.ENABLE_FEAT_TWED: Enables theFEAT_TWED(Delayed trapping of WFE Instruction) extension.FEAT_TWEDis a optional feature available on Arm v8.6. Default is0.When
ENABLE_FEAT_TWEDis set to1, WFE instruction trapping gets delayed by the amount of value inTWED_DELAY.ENABLE_FEAT_VHE: Enables theFEAT_VHE(Virtualization Host Extensions) extension. It allows access to CONTEXTIDR_EL2 register during EL2 context save/restore operations.``FEAT_VHE`` is a mandatory architectural feature and is enabled from v8.1 and upwards. Default value is0.ENABLE_FEAT_TCR2: Sets the bit SCR_EL3.ENTCR2 in EL3 to allow access to TCR2_EL2 (extended translation control) from EL2 as well as adding TCR2_EL2 to the EL2 context save/restore operations. Its a mandatory architectural feature and is enabled from v8.9 and upwards. Default value is0.ENABLE_FEAT_S2PIE: Enables support for FEAT_S2PIE at EL2 and below, and context switch relevant registers. Default value is0.ENABLE_FEAT_S1PIE: Enables support for FEAT_S1PIE at EL2 and below, and context switch relevant registers. Default value is0.ENABLE_FEAT_S2POE: Enables support for FEAT_S2POE at EL2 and below, and context switch relevant registers. Default value is0.ENABLE_FEAT_S1POE: Enables support for FEAT_S1POE at EL2 and below, and context switch relevant registers. Default value is0.ENABLE_FEAT_GCS: Sets the bit SCR_EL3.GCSEn in EL3 to allow use of Guarded Control Stack from EL2 as well as adding the GCS registers to the EL2 context save/restore operations. Default value is0.
ENABLE_FEAT_GCIE: Boolean value to enable support for the GICv5 CPU interface (seeUSE_GIC_DRIVERfor the IRI). GICv5 and GICv3 are mutually exclusive so theENABLE_FEATmechanism is currently not supported. Default value is0.
ENABLE_FEAT_THE: Enables support for FEAT_THE (Translation Hardening Extension) at EL2 and below, setting the bit SCR_EL3.RCWMASKEn in EL3 to allow access to RCWMASK_EL1 and RCWSMASK_EL1 registers and context switch them. Its an optional architectural feature and is available from v8.8 and upwards. Default value is0.ENABLE_FEAT_SCTLR2: Enables support for FEAT_SCTLR2 (Extension to SCTLR_ELx) at EL2 and below, setting the bit SCR_EL3.SCTLR2En in EL3 to allow access to SCTLR2_ELx registers and context switch them. This feature is OPTIONAL from Armv8.0 implementations and mandatory in Armv8.9 implementations. Default value is0.ENABLE_FEAT_STEP2: Enables support for FEAT_STEP2 by settingMDCR_EL3.EnSTEPOPso that lower ELs can accessMDSTEPOP_EL1. This feature is optional from Armv9.4 implementations and is mandatory in Armv9.5 implementations. Defaults value is0.ENABLE_FEAT_D128: Enables support for FEAT_D128 at EL2 and below, setting the bit SCT_EL3.D128En in EL3 to allow access to 128 bit version of system registers like PAR_EL1, TTBR0_EL1, TTBR1_EL1, TTBR0_EL2, TTBR1_EL2, TTBR0_EL12, TTBR1_EL12 , VTTBR_EL2, RCWMASK_EL1, and RCWSMASK_EL1. Its an optional architectural feature and is available from 9.3 and upwards. Default value is0.ENABLE_FEAT_UINJ: Enables FEAT_UINJ support, which is hardware based injection of undefined instruction exceptions. The objective of this feature is to provide higher privilege software with a future proofed mechanism to inject an Undefined Instruction exception into lower privilege software. It is an optional architectural feature from v9.0 and mandatory from v9.6. This flag can take value of 0 to 2, to align with theFEATURE_DETECTIONmechanism. Default value is0.ENABLE_FEAT_MEC: Enables support for the ARMv9.2 Memory Encryption Contexts (MEC). MEC supports multiple encryption contexts for Realm security state and only one encryption context for the rest of the security states. Default value is 0.ENABLE_FEAT_MORELLO: Enables the Morello capability aware firmware. This option is experimental and supported only with LLVM CLANG toolchain and not with GCC toolchain. Capability awareness is currently enabled only in BL31 firmware and not in other firmware types of trusted firmware. Enabling this on regular AARCH64 system might not work.ENABLE_FEAT_RAS: Enables Armv8.2 RAS features. RAS features are an optional extension for pre-Armv8.2 CPUs, but are mandatory for Armv8.2 or later CPUs. NOTE: This flag enables use of IESB capability to reduce entry latency into EL3 even when RAS error handling is not performed on the platform. Hence this flag is recommended to be turned on Armv8.2 and later CPUs. The default is 0.ENABLE_FEAT_RME: Enables support for the ARMv9 Realm Management Extension. Default value is 0. This flag solely controls the architectural bits of RME, to let TF-A run in the “root” physical address space and this will setup Granule Protection Tables (GPT). Also this will make BL2 run in EL3, so it has access to the new root address space. For deploying a Realm-EL2 payload (RMM), also setENABLE_RMMand provide an RMM image file.ENABLE_SPE_FOR_NS: Enables Statistical Profiling extensions. This is an optional architectural feature for AArch64. The default is 2 but is automatically disabled when the target architecture is AArch32.ENABLE_FEAT_SPEV1P5: Numeric value to enableFEAT_SPEv1p5related Features (FEAT_SPE_EXCandFEAT_SPE_nVM) support and requiresENABLE_SPE_FOR_NSto be enabled. This is an optional architectural feature for AArch64. This flag can take the values 0 to 2, to align with theENABLE_FEATmechanism. The default is0.ENABLE_SVE_FOR_NS: Enables Scalable Vector Extension (SVE) for the Non-secure world only. SVE is an optional architectural feature for AArch64. The default value is 2.Note that when SVE is enabled for the Non-secure world, access to SVE, SIMD and floating-point functionality from the Secure world is independently controlled by build option
ENABLE_SVE_FOR_SWD. When enablingCTX_INCLUDE_FPREGSandENABLE_SVE_FOR_NStogether, it is mandatory to enableCTX_INCLUDE_SVE_REGS. This is to avoid corruption of the Non-secure world data in the Z-registers which are aliased by the SIMD and FP registers.ENABLE_SVE_FOR_SWD: Boolean option to enable SVE and FPU/SIMD functionality for the Secure world. SVE is an optional architectural feature for AArch64. The default is 0 and it is automatically disabled when the target architecture is AArch32.Note
This build flag requires
ENABLE_SVE_FOR_NSto be enabled. When enablingENABLE_SVE_FOR_SWD, a developer must carefully consider whetherCTX_INCLUDE_SVE_REGSis also needed.ENABLE_BRBE_FOR_NS: Enables access to the branch record buffer registers from NS ELs when FEAT_BRBE is implemented. BRBE is an optional architectural feature for AArch64. The default is 0 and it is automatically disabled when the target architecture is AArch32.ENABLE_FEAT_BRBEV1P1: Numeric value to enable support forFEAT_BRBEv1p1, which allows Branch recording at EL3 via the functionsbrbe_start_recording(),brbe_stop_recording(), andbrbe_dump_branch_records(). FEAT_BRBEv1p1 is an optional architectural feature available from Arm v9.2 onwards and is EXPERIMENTAL. This flag may be renamed or removed in the future. Default value is 0.ENABLE_TRBE_FOR_NS: Enables access of trace buffer control registers from NS ELs, NS-EL2 or NS-EL1(when NS-EL2 is implemented but unused) when FEAT_TRBE is implemented. TRBE is an optional architectural feature for AArch64. The default is 0 and it is automatically disabled when the target architecture is AArch32.USE_SPINLOCK_CAS: Uses FEAT_LSE atomics instead of load/store exclusive instructions with spinlocks. FEAT_LSE is a mandatory feature from v8.1, however it is only architecturally guaranteed to work on “conventional memory” which may not apply to tightly coupled memory (eg. SRAM, TF-A’s usual place). Platforms must check if TF-A’s memory can be targetted by atomics before enabling this feature. Expected to increase performance on systems with many cores. The default is 0.ENABLE_SYS_REG_TRACE_FOR_NS: Enables trace system registers access from NS ELs, NS-EL2 or NS-EL1 (when NS-EL2 is implemented but unused). This feature is available if trace unit such as ETMv4.x, and ETE(extending ETM feature) is implemented. The default is 0.ENABLE_TRF_FOR_NS: Enables trace filter control registers access from NS ELs, NS-EL2 or NS-EL1 (when NS-EL2 is implemented but unused), if FEAT_TRF is implemented. This flag is disabled by default.ENABLE_SME_FOR_NS: Enables Scalable Matrix Extension (SME), SVE, and FPU/SIMD for the non-secure world only. These features share registers so are enabled together. Using this option without ENABLE_SME_FOR_SWD=1 will cause SME, SVE, and FPU/SIMD instructions in secure world to trap to EL3. RequiresENABLE_SVE_FOR_NSto be set as SME is a superset of SVE. SME is an optional architectural feature for AArch64. Default is 0.ENABLE_SME2_FOR_NS: Enables Scalable Matrix Extension version 2 (SME2) for the non-secure world only. SME2 is an optional architectural feature for AArch64. This should be set along with ENABLE_SME_FOR_NS=1, if not, the default SME accesses will still be trapped. Default is 0.ENABLE_FEAT_MPAM: Enables lower ELs to use MPAM feature. MPAM is an optional Armv8.4 extension that enables various memory system components and resources to define partitions; software running at various ELs can assign themselves to desired partition to control their performance aspects.When this option is set to
1or2, EL3 allows lower ELs to access their own MPAM registers without trapping into EL3. This option doesn’t make use of partitioning in EL3, however. Platform initialisation code should configure and use partitions in EL3 as required. This option defaults to2since MPAM is enabled by default for NS world only. The flag is automatically disabled when the target architecture is AArch32.ENABLE_FEAT_MPAM_PE_BW_CTRL: This option enables Armv9.3 MPAM PE-side bandwidth controls and disables traps to EL3/EL2 (whenINIT_UNUSED_NS_EL2= 1). The default is0.ENABLE_FEAT_LS64_ACCDATA: Enables access to, and save and restore the ACCDATA_EL1 system register, at EL2 and below. Default value is0.ENABLE_FEAT_AIE: Enables access to the (A)MAIR2 system registers from non-secure world. Default value is0.ENABLE_FEAT_PFAR: Enables access to the PFAR system registers from non-secure world. Default value is0.ENABLE_FEAT_AxERR: Enables the use of FEAT_ADERR and FEAT_ANERR at EL3, allowing EL3 Device and Normal memory External Aborts (like consuming RAS poison) to be handled asynchronously in exchange for improved performance. Platforms should not enable this option if this behaviour is undesirable. Default value is0.ENABLE_FEAT_SRMASK`: Enables alias and bitwise write masks for EL1 control registers and equivalent bitwise write masks for NS EL2. Default value is0.ENABLE_FEAT_TRBE_EXC: Enables trace buffer management events to be reported as profiling exceptions. Default value is0.
2.6.3. GIC driver options
The generic GIC driver can be included with the USE_GIC_DRIVER option. It is
a numeric option that can take the following values:
0: generic GIC driver not enabled. Any support is entirely in platform code. Strongly discouraged for GIC based interrupt controllers.
1: enable the use of the generic GIC driver but do not include any files or function definitions. It is then the platform’s responsibility to provide these. This is useful if the platform either has a custom GIC implementation or an alternative interrupt controller design. Use of this option is strongly discouraged for standard GIC implementations.
2: use the GICv2 driver
3: use the GICv3 driver. See the next section on how to further configure it. Use this option for GICv4 implementations. Requires callinggic_set_gicr_frames().
5: use the EXPERIMENTAL GICv5 driver. RequiresENABLE_FEAT_GCIE=1.For GIC driver versions other than
1, deciding when to save and restore GIC context on a power domain state transition, as well as any GIC actions outside of the PSCI library’s visibility are the platform’s responsibility. The driver provides implementations of all necessary subroutines, they only need to be called as appropriate.
2.6.3.1. GICv3 driver options
USE_GIC_DRIVER=3 is the preferred way of including GICv3 driver files. The
old (deprecated) way of included them is using the directive:
include drivers/arm/gic/v3/gicv3.mk
The driver can be configured with the following options set in the platform makefile:
GICV3_SUPPORT_GIC600: Add support for the GIC-600 variants of GICv3. Enabling this option will add runtime detection support for the GIC-600, so is safe to select even for a GIC500 implementation. This option defaults to 0.GICV3_SUPPORT_GIC600AE_FMU: Add support for the Fault Management Unitfor GIC-600 AE. Enabling this option will introduce support to initialize the FMU. Platforms should call the init function during boot to enable the FMU and its safety mechanisms. This option defaults to 0.
GICV3_IMPL_GIC600_MULTICHIP: Selects GIC-600 variant with multichip functionality. This option defaults to 0GICV3_OVERRIDE_DISTIF_PWR_OPS: Allows override of default implementation ofarm_gicv3_distif_pre_saveandarm_gicv3_distif_post_restorefunctions. This is required for FVP platform which need to simulate GIC save and restore during SYSTEM_SUSPEND without powering down GIC. Default is 0.GIC_ENABLE_V4_EXTN: Enables GICv4 related changes in GICv3 driver. This option defaults to 0.GIC_EXT_INTID: When set to1, GICv3 driver will support extended PPI (1056-1119) and SPI (4096-5119) range. This option defaults to 0.
2.6.4. Debugging options
To compile a debug version and make the build more verbose use
make PLAT=<platform> DEBUG=1 V=1 all
AArch64 GCC 11 uses DWARF version 5 debugging symbols by default. Some tools
(for example Arm-DS) might not support this and may need an older version of
DWARF symbols to be emitted by GCC. This can be achieved by using the
-gdwarf-<version> flag, with the version being set to 2, 3, 4 or 5. Setting
the version to 4 is recommended for Arm-DS.
When debugging logic problems it might also be useful to disable all compiler
optimizations by using -O0.
Warning
Using -O0 could cause output images to be larger and base addresses
might need to be recalculated (see the Memory layout on Arm development
platforms section in the Firmware Design).
Extra debug options can be passed to the build system by setting CFLAGS or
LDFLAGS:
CFLAGS='-O0 -gdwarf-2' \
Note that using -Wl, style compilation driver options in CFLAGS will be
ignored as the linker is called directly.
It is also possible to introduce an infinite loop to help in debugging the
post-BL2 phase of TF-A. This can be done by rebuilding BL1 with the
SPIN_ON_BL1_EXIT=1 build flag. Refer to the Common build options
section. In this case, the developer may take control of the target using a
debugger when indicated by the console output. When using Arm-DS, the following
commands can be used:
# Stop target execution
interrupt
# Prepare your debugging environment, e.g. set breakpoints
# Jump over the debug loop
set var $AARCH64::$Core::$PC = $AARCH64::$Core::$PC + 4
# Resume execution
continue
2.6.5. Experimental build options
2.6.5.1. Common build options
DICE_PROTECTION_ENVIRONMENT: Boolean flag to specify the measured boot backend whenMEASURED_BOOTis enabled. The default value is0. When set to1then measurements and additional metadata collected during the measured boot process are sent to the DICE Protection Environment for storage and processing. A certificate chain, which represents the boot state of the device, can be queried from the DPE.DRTM_SUPPORT: Boolean flag to enable support for Dynamic Root of Trust for Measurement (DRTM). This feature has trust dependency on BL31 for taking the measurements and recording them as per PSA DRTM specification. For platforms which use BL2 to load/authenticate BL31TRUSTED_BOARD_BOOTcan be used and for the platforms which useRESET_TO_BL31platform owners should have mechanism to authenticate BL31. This option defaults to 0.ENABLE_RMM: Boolean flag to enable the Realm-EL2 payload (RMM). This will take care of loading and initialising an image in Realm-EL2, and will at runtime dispatch calls from non-secure world to the RMM, if applicable. Default value is 0. Setting this flag implies that RMM must be enabled therefore, it mandatesENABLE_FEAT_RMEto 1.ENABLE_RME: This options will be deprecated. Please useENABLE_FEAT_RME. Until deprecated, setting this option to 1, will also setENABLE_FEAT_RMEandENABLE_RMMto 1.RMMD_ENABLE_IDE_KEY_PROG: Boolean flag to enable support for RMM EL3 interface to program and manage IDE keys at the PCIe Root Port (RP). Default value is 0. This option will be removed in a future release. Please use FIRME IDE key management serviceFIRME_SUPPORT_IDE_KMinstead.RMM_V1_COMPAT: Boolean flag to enable support for RMM v1.x compatibility mode. When set to 0, TF-A will use the RMM-EL3 interface version required for RMMv2.0. Default value is 0.FIRME_SUPPORT: This option enables the FIRME service in TF-A.FIRME_SUPPORT_IDE_KM: Boolean flag to enable the IDE key management FIRME service. This service gets enabled for NS instance whenENABLE_RMMis 0 or for Realm instance whenENABLE_RMMis 1. This flag depends onFIRME_SUPPORTbuild flag. Default value is 0.RMMD_ENABLE_EL3_TOKEN_SIGN: Numeric value to enable support for singing realm attestation token signing requests in EL3. This flag can take the values 0 and 1. The default value is0. When set to1, this option enables additional RMMD SMCs to push and pop requests for signing to EL3 along with platform hooks that must be implemented to service those requests and responses.ENABLE_SME_FOR_SWD: Boolean option to enable the Scalable Matrix Extension for secure world. Used along with SVE and FPU/SIMD. ENABLE_SME_FOR_NS and ENABLE_SVE_FOR_SWD must also be set to use this. Default is 0.ENABLE_SPMD_LP: This boolean option is used jointly with the SPM Dispatcher option (SPD=spmd). When enabled (1) it indicates support for logical partitions in EL3, managed by the SPMD as defined in the FF-A v1.2 specification. This flag is disabled by default. This flag must not be used ifSPMC_AT_EL3is enabled.PSA_CRYPTO: Boolean option for enabling MbedTLS PSA crypto APIs support. The platform will use PSA compliant Crypto APIs during authentication and image measurement process by enabling this option. It uses APIs defined as per the PSA Crypto API specification. This feature is only supported if using MbedTLS 3.x version. It is disabled (0) by default.LFA_SUPPORT: Boolean flag to enable support for Live Firmware activation as per the specification. This option defaults to 0.ENABLE_LFA_BL31: Boolean flag to enable live activation of BL31 using the EL3 LFA framework. This option depends onLFA_SUPPORTand defaults to 0. See BL31 Live Firmware Activation for the design, assumptions, and limitations of BL31 self-update.TRANSFER_LIST: Setting this to1enables support for Firmware Handoff using Transfer List defined in Firmware Handoff specification. This defaults to0. Current implementation follows the Firmware Handoff specification v0.9.USE_DEBUGFS: When set to 1 this option exposes a virtual filesystem interface through BL31 as a SiP SMC function. Default is disabled (0).HOB_LIST: Setting this to1enables support for passing boot information using HOB defined in Platform Initialization specification. This defaults to0.ENABLE_ACS_SMC: When set to1, this enables support for ACS SMC handler code to handle SMC calls from the Architecture Compliance Suite. The handler is intentionally empty to reserve the SMC section and allow project-specific implementations in future ACS use cases.
2.6.5.2. Firmware update options
PSA_FWU_SUPPORT: Enable the firmware update mechanism as per the PSA FW update specification. The default value is 0. PSA firmware update implementation has few limitations, such as:BL2 is not part of the protocol-updatable images. If BL2 needs to be updated, then it should be done through another platform-defined mechanism.
It assumes the platform’s hardware supports CRC32 instructions.
NR_OF_FW_BANKS: Define the number of firmware banks. This flag is used in defining the firmware update metadata structure. This flag is by default set to ‘2’.NR_OF_IMAGES_IN_FW_BANK: Define the number of firmware images in each firmware bank. Each firmware bank must have the same number of images as per the PSA FW update specification. This flag is used in defining the firmware update metadata structure. This flag is by default set to ‘1’.PSA_FWU_METADATA_FW_STORE_DESC: To be enabled when the FWUmetadata contains image description. The default value is 1.
The version 2 of the FWU metadata allows for an opaque metadata structure where a platform can choose to not include the firmware store description in the metadata structure. This option indicates if the firmware store description, which provides information on the updatable images is part of the structure.
2.6.5.3. SP Live Activation build options
SUPPORT_SP_LIVE_ACTIVATION: Boolean option to enable live activation of Secure Partition(s) by using common SPMD LSP helpers. Enforces all of the following dependencies are met:LFA_SUPPORT=1to enable the live activation service in BL31.ENABLE_SPMD_LP=1allows SPMD logical secure partition to be enabled.SPMD_SPM_AT_SEL2=1as the current implementation only supports working with an S-EL2 SPMC (for example, Hafnium) to live activate an SP; It is incompatible with EL3 SPMC.
This flag is experimental and currently exercised on FVP. Default value is 0.
2.6.5.4. Negative test scenario options
TEST_IO_SHORT_READ_FI: Boolean flag to enable a negative-test for the BL image loader. When set to1, TF-A intentionally simulates a short read for the image selected byTEST_IO_SHORT_READ_FI_IMAGE_IDby reporting fewer bytes read than the image size. This exercises the “read too short” error handling path inload_image()and is intended for test/CI only. Default is0(disabled). Must not be used on production devices.TEST_IO_SHORT_READ_FI_IMAGE_ID: Numeric flag that selects theimage_idfor which the short-read fault is injected whenTEST_IO_SHORT_READ_FI=1. The value must match the image identifiers used by the platform image loading flow (for exampleBL31_IMAGE_ID,BL33_IMAGE_ID, etc., depending on the build and platform). Default is0.
Copyright (c) 2019-2026, Arm Limited. All rights reserved.
