4.20. RMM-EL3 Communication interface
This document defines the communication interface between RMM and EL3. There are two parts in this interface: the boot interface and the runtime interface.
The Boot Interface defines the ABI between EL3 and RMM when the CPU enters R-EL2 for the first time after boot. The cold boot interface defines the ABI for the cold boot path and the warm boot interface defines the same for the warm path.
The RMM-EL3 runtime interface defines the ABI for EL3 services which can be invoked by RMM as well as the register save-restore convention when handling an SMC call from NS.
The below sections discuss these interfaces more in detail.
4.20.1. RMM-EL3 Interface versioning
The RMM Boot and Runtime Interface uses a version number to check compatibility with the register arguments passed as part of Boot Interface and RMM-EL3 runtime interface.
The Boot Manifest, discussed later in section Boot Manifest, uses a separate version number but with the same scheme.
The version number is a 32-bit type with the following fields:
Bits
Value
[0:15]
VERSION_MINOR
[16:30]
VERSION_MAJOR
[31]
RES0
The version numbers are sequentially increased and the rules for updating them are explained below:
  • VERSION_MAJOR: This value is increased when changes break compatibility with previous versions. If the changes on the ABI are compatible with the previous one, VERSION_MAJOR remains unchanged.
  • VERSION_MINOR: This value is increased on any change that is backwards compatible with the previous version. When VERSION_MAJOR is increased, VERSION_MINOR must be set to 0.
  • RES0: Bit 31 of the version number is reserved 0 as to maintain consistency with the versioning schemes used in other parts of RMM.
This document specifies the 2.0 version of Boot Interface ABI and RMM-EL3 services specification and the 0.5 version of the Boot Manifest.
4.20.2. RMM Boot Interface
This section deals with the Boot Interface part of the specification.
One of the goals of the Boot Interface is to allow EL3 firmware to pass down into RMM certain platform specific information dynamically. This allows RMM to be less platform dependent and be more generic across platform variations. It also allows RMM to be decoupled from the other boot loader images in the boot sequence and remain agnostic of any particular format used for configuration files.
The Boot Interface ABI defines a set of register conventions and also a memory based manifest file to pass information from EL3 to RMM. The Boot Manifest and the associated platform data in it can be dynamically created by EL3 and there is no restriction on how the data can be obtained (e.g by DTB, hoblist or other).
The register convention and the manifest are versioned separately to manage future enhancements and compatibility.
RMM completes the boot by issuing the RMM_BOOT_COMPLETE SMC (0xC40001CF) back to EL3. After the RMM has finished the boot process, it can only be entered from EL3 as part of RMI handling.
If RMM returns an error during boot (in any CPU), then RMM must not be entered from any CPU.
4.20.2.1. Cold Boot Interface
During cold boot RMM expects the following register values:
Register
Value
x0
Linear index of this PE. This index starts from 0 and must be less than the maximum number of CPUs to be supported at runtime (see x2).
x1
Version for this Boot Interface as defined in RMM-EL3 Interface versioning.
x2
Maximum number of CPUs to be supported at runtime. RMM should ensure that it can support this maximum number.
x3
Base address for the shared buffer used for communication between EL3 firmware and RMM. This buffer must be of 4KB size (1 page). The Boot Manifest must be present at the base of this shared buffer during cold boot.
x4
Activation token. Should be set to 0 on the initial boot of the system. For a subsequent warm boot or when using Live Firmware Activation, the activation token should be set to the value returned by RMM for this CPU during the initial boot (in x2).
During cold boot, EL3 firmware needs to allocate a 4KB page that will be passed to RMM in x3. This memory will be used as shared buffer for communication between EL3 and RMM. It must be assigned to Realm world and must be mapped with Normal memory attributes (IWB-OWB-ISH) at EL3. At boot, this memory will be used to populate the Boot Manifest. Since the Boot Manifest can be accessed by RMM prior to enabling its MMU, EL3 must ensure that proper cache maintenance operations are performed after the Boot Manifest is populated.
EL3 should also ensure that this shared buffer is always available for use by RMM during the lifetime of the system and that it can be used for runtime communication between RMM and EL3. For example, when RMM invokes attestation service commands in EL3, this buffer can be used to exchange data between RMM and EL3. It is also allowed for RMM to invoke runtime services provided by EL3 utilizing this buffer during the boot phase, prior to return back to EL3 via RMM_BOOT_COMPLETE SMC.
RMM should map this memory page into its Stage 1 page-tables using Normal memory attributes.
During runtime, it is the RMM which initiates any communication with EL3. If that communication requires the use of the shared area, it is expected that RMM needs to do the necessary concurrency protection to prevent the use of the same buffer by other PEs.
The following sequence diagram shows how a generic EL3 Firmware would boot RMM.
../_images/rmm_cold_boot_generic.png
4.20.2.2. Warm Boot Interface
At warm boot, RMM is already initialized and only some per-CPU initialization is still pending. The only argument that is required by RMM at this stage is the CPU Id, which will be passed through register x0 whilst x1 to x3 are RES0. This is summarized in the following table:
Register
Value
x0
x1
x2 - x3
RES0
4.20.2.3. Boot error handling and return values
After boot up and initialization, RMM returns control back to EL3 through a RMM_BOOT_COMPLETE SMC call. The first argument of this SMC call will be returned in x1 and it will encode a signed integer with the error reason. x2 will contain the per-CPU activation token, which is an opaque value that should be passed back to RMM when doing Live Firmware Activations or on a subsequent warm boot. The following table describes possible values for the error code in x1:
Error code
ID
E_RMM_BOOT_SUCCESS
Boot successful
0
E_RMM_BOOT_ERR_UNKNOWN
Unknown error
-1
E_RMM_BOOT_VERSION_NOT_VALID
Boot Interface version reported by EL3 is not supported by RMM
-2
E_RMM_BOOT_CPUS_OUT_OF_RANGE
Number of CPUs reported by EL3 larger than maximum supported by RMM
-3
E_RMM_BOOT_CPU_ID_OUT_OF_RANGE
Current CPU Id is higher or equal than the number of CPUs supported by RMM
-4
E_RMM_BOOT_INVALID_SHARED_BUFFER
Invalid pointer to shared memory area
-5
E_RMM_BOOT_MANIFEST_VERSION_NOT_SUPPORTED
Version reported by the Boot Manifest not supported by RMM
-6
E_RMM_BOOT_MANIFEST_DATA_ERROR
Error parsing core Boot Manifest
-7
For any error detected in RMM during cold or warm boot, RMM will return back to EL3 using RMM_BOOT_COMPLETE SMC with an appropriate error code. It is expected that EL3 will take necessary action to disable Realm world for further entry from NS Host on receiving an error. This will be done across all the PEs in the system so as to present a symmetric view to the NS Host. Any further warm boot by any PE should not enter RMM using the warm boot interface.
4.20.2.4. Boot Manifest
During cold boot, EL3 Firmware passes a memory Boot Manifest to RMM containing platform information.
This Boot Manifest is versioned independently of the Boot Interface, to help evolve the former independent of the latter. The current version for the Boot Manifest is v0.4 and the rules explained in RMM-EL3 Interface versioning apply on this version as well.
The Boot Manifest v0.4 has the following fields:
  • version : Version of the Manifest (v0.4)
  • plat_data : Pointer to the platform specific data and not specified by this document. These data are optional and can be NULL.
  • plat_dram : Structure encoding the NS DRAM information on the platform. This field is optional and platform can choose to zero out this structure if RMM does not need EL3 to send this information during the boot.
  • plat_console : Structure encoding the list of consoles for RMM use on the platform. This field is optional and platform can choose to not populate the console list if this is not needed by the RMM for this platform.
For the current version of the Boot Manifest, the core manifest contains a pointer to the platform data. EL3 must ensure that the whole Boot Manifest, including the platform data, if available, fits inside the RMM EL3 shared buffer.
For the data structure specification of Boot Manifest, refer to RMM-EL3 Boot Manifest structure
4.20.3. RMM-EL3 Runtime Interface
This section defines the RMM-EL3 runtime interface which specifies the ABI for EL3 services expected by RMM at runtime as well as the register save and restore convention between EL3 and RMM as part of RMI call handling. It is important to note that RMM is allowed to invoke EL3-RMM runtime interface services during the boot phase as well. The EL3 runtime service handling must not result in a world switch to another world unless specified. Both the RMM and EL3 are allowed to make suitable optimizations based on this assumption.
If the interface requires the use of memory, then the memory references should be within the shared buffer communicated as part of the boot interface. See Cold Boot Interface for properties of this shared buffer which both EL3 and RMM must adhere to.
4.20.3.1. RMM-EL3 runtime service return codes
The return codes from EL3 to RMM is a 32 bit signed integer which encapsulates error condition as described in the following table:
Error code
ID
E_RMM_OK
No errors detected
0
E_RMM_UNK
Unknown/Generic error
-1
E_RMM_BAD_ADDR
The value of an address used as argument was invalid
-2
E_RMM_BAD_PAS
Incorrect PAS
-3
E_RMM_NOMEM
Not enough memory to perform an operation
-4
E_RMM_INVAL
The value of an argument was invalid
-5
E_RMM_AGAIN
The resource is busy. Try again.
-6
If multiple failure conditions are detected in an RMM to EL3 command, then EL3 is allowed to return an error code corresponding to any of the failure conditions.
4.20.3.2. RMM-EL3 runtime services
The following table summarizes the RMM runtime services that need to be implemented by EL3 Firmware.
If an equivalent FIRME SMC is supported, it is recommended to use the FIRME interface as a future version of RMM-EL3 runtime service will remove the redundant SMCs.
FID
Command
Corresponding FIRME ABI
0xC400018F
RMM_RMI_REQ_COMPLETE
0xC40001B0
RMM_GTSI_DELEGATE
FIRME_GM_GPI_SET_FID
0xC40001B1
RMM_GTSI_UNDELEGATE
0xC40001B2
RMM_ATTEST_GET_REALM_KEY
0xC40001B3
RMM_ATTEST_GET_PLAT_TOKEN
FIRME_ATTEST_PAT_GET_FID
0xC40001B4
RMM_EL3_FEATURES
0xC40001B5
RMM_EL3_TOKEN_SIGN
0xC40001B6
RMM_MECID_KEY_UPDATE
FIRME_MEC_REFRESH_FID
0xC40001B7
RMM_IDE_KEY_PROG
FIRME_IDE_KEYSET_PROG_FID
0xC40001B8
RMM_IDE_KEY_SET_GO
FIRME_IDE_KEYSET_GO_FID
0xC40001B9
RMM_IDE_KEY_SET_STOP
FIRME_IDE_KEYSET_STOP
0xC40001BA
RMM_IDE_KM_PULL_RESPONSE
0xC40001BB
RMM_RESERVE_MEMORY
4.20.3.2.1. RMM_RMI_REQ_COMPLETE command
Notifies the completion of an RMI call to the Non-Secure world.
This call is the only function currently in RMM-EL3 runtime interface which results in a world switch to NS. This call is the reply to the original RMI call and it is forwarded by EL3 to the NS world.
4.20.3.2.1.1. FID
0xC400018F
4.20.3.2.1.2. Input values
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
err_code
x1
[63:0]
RmiCommandReturnCode
Error code returned by the RMI service invoked by NS World. See Realm Management Monitor specification for more info
4.20.3.2.1.3. Output values
This call does not return.
4.20.3.2.1.4. Failure conditions
Since this call does not return to RMM, there is no failure condition which can be notified back to RMM.
4.20.3.2.2. RMM_GTSI_DELEGATE command
Delegate a memory granule by changing its PAS from Non-Secure to Realm.
4.20.3.2.2.1. FID
0xC40001B0
4.20.3.2.2.2. Input values
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
base_pa
x1
[63:0]
Address
PA of the start of the granule to be delegated
4.20.3.2.2.3. Output values
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
Command return status
4.20.3.2.2.4. Failure conditions
The table below shows all the possible error codes returned in Result upon a failure. The errors are ordered by condition check.
ID
Condition
E_RMM_BAD_ADDR
PA does not correspond to a valid granule address
E_RMM_BAD_PAS
The granule pointed by PA does not belong to Non-Secure PAS
E_RMM_OK
No errors detected
4.20.3.2.3. RMM_GTSI_UNDELEGATE command
Undelegate a memory granule by changing its PAS from Realm to Non-Secure.
4.20.3.2.3.1. FID
0xC40001B1
4.20.3.2.3.2. Input values
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
base_pa
x1
[63:0]
Address
PA of the start of the granule to be undelegated
4.20.3.2.3.3. Output values
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
4.20.3.2.3.4. Failure conditions
ID
Condition
E_RMM_BAD_ADDR
E_RMM_BAD_PAS
The granule pointed by PA does not belong to Realm PAS
E_RMM_OK
No errors detected
4.20.3.2.4. RMM_ATTEST_GET_REALM_KEY command
Retrieve the Realm Attestation Token Signing key from EL3.
4.20.3.2.4.1. FID
0xC40001B2
4.20.3.2.4.2. Input values
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
buf_pa
x1
[63:0]
Address
PA where the Realm Attestation Key must be stored by EL3. The PA must belong to the shared buffer
buf_size
x2
[63:0]
Size in bytes of the Realm Attestation Key buffer. bufPa + bufSize must lie within the shared buffer
ecc_curve
x3
[63:0]
Enum
Type of the elliptic curve to which the requested attestation key belongs to. See Supported ECC Curves
4.20.3.2.4.3. Output values
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
keySize
x1
[63:0]
Size of the Realm Attestation Key
4.20.3.2.4.4. Failure conditions
ID
Condition
E_RMM_BAD_ADDR
PA is outside the shared buffer
E_RMM_INVAL
PA + BSize is outside the shared buffer
E_RMM_INVAL
Curve is not one of the listed in Supported ECC Curves
E_RMM_UNK
An unknown error occurred whilst processing the command
E_RMM_OK
No errors detected
4.20.3.2.4.5. Supported ECC Curves
ID
Curve
0
ECC SECP384R1
4.20.3.2.5. RMM_ATTEST_GET_PLAT_TOKEN command
Retrieve the Platform Token from EL3. If the entire token does not fit in the buffer, EL3 returns a hunk of the token (via tokenHunkSize parameter) and indicates the remaining bytes that are pending retrieval (via remainingSize parameter). The challenge object for the platform token must be populated in the buffer for the first call of this command and the size of the object is indicated by c_size parameter. Subsequent calls to retrieve remaining hunks of the token must be made with c_size as 0.
If c_size is not 0, this command could cause regeneration of platform token and will return token hunk corresponding to beginning of the token.
It is valid for the calls of this command to return E_RMM_AGAIN error, which is an indication to the caller to retry this command again. Depending on the platform, this mechanism can be used to implement queuing to HES, if HES is involved in platform token generation.
4.20.3.2.5.1. FID
0xC40001B3
4.20.3.2.5.2. Input values
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
buf_pa
x1
[63:0]
Address
PA of the platform attestation token. The challenge object must be passed in this buffer for the first call of this command. Any subsequent calls, if required to retrieve the full token, should not have this object. The PA must belong to the shared buffer.
buf_size
x2
[63:0]
Size in bytes of the platform attestation token buffer. bufPa + bufSize must lie within the shared buffer
c_size
x3
[63:0]
Size in bytes of the challenge object. It corresponds to the size of one of the defined SHA algorithms. Any subsequent calls, if required to retrieve the full token, should set this size to 0.
4.20.3.2.5.3. Output values
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
tokenHunkSize
x1
[63:0]
Size of the platform token hunk retrieved
remainingSize
x2
[63:0]
Remaining bytes of the token that are pending retrieval
4.20.3.2.5.4. Failure conditions
ID
Condition
E_RMM_AGAIN
Resource for Platform token retrieval is busy. Try again.
E_RMM_BAD_ADDR
E_RMM_INVAL
E_RMM_INVAL
CSize does not represent the size of a supported SHA algorithm for the first call to this command
E_RMM_INVAL
CSize is not 0 for subsequent calls to retrieve remaining hunks of the token
E_RMM_UNK
E_RMM_OK
No errors detected
4.20.3.2.6. RMM_EL3_FEATURES command
This command provides a mechanism to discover features and ABIs supported by the RMM-EL3 interface, for a given version. This command is helpful when there are platform specific optional RMM-EL3 interfaces and features exposed by vendor specific EL3 firmware, and a generic RMM that can modify its behavior based on discovery of EL3 features.
The features can be discovered by specifying the feature register index that has fields defined to indicate presence or absence of features and other relevant information. The feature register index is specified in the feat_reg_idx parameter. Each feature register is a 64 bit register.
This command is available from v0.4 of the RMM-EL3 interface.
The following is the register definition for feature register index 0 for v0.4 of the interface:
4.20.3.2.6.1. RMM-EL3 Feature Resister 0
63      32      31      16       15      8       7       1       0
                                             RMMD_EL3_TOKEN_SIGN
Bit Fields:
  • Bit 0: RMMD_EL3_TOKEN_SIGN
    • When set to 1, the RMMD_EL3_TOKEN_SIGN feature is enabled.
    • When cleared (0), the feature is disabled.
  • Bits [1:63]: Reserved (must be zero)
4.20.3.2.6.2. FID
0xC40001B4
4.20.3.2.6.3. Input values
Input values for RMM_EL3_FEATURES
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
feat_reg_idx
x1
[63:0]
UInt64
Feature register index. For v0.4, a value of 0 is the only acceptable value
4.20.3.2.6.4. Output values
Output values for RMM_EL3_FEATURES
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
feat_reg
x1
[63:0]
Value
Value of the register as defined above
4.20.3.2.6.5. Failure conditions
Failure conditions for RMM_EL3_FEATURES
ID
Condition
E_RMM_INVAL
feat_reg_idx is out of valid range
E_RMM_UNK
if the SMC is not present, if interface version is <0.4
E_RMM_OK
No errors detected
4.20.3.2.7. RMM_EL3_TOKEN_SIGN command
This command is an optional command that can be discovered using the RMM_EL3_FEATURES command. This command is used to send requests related to realm attestation token signing requests to EL3. The command supports 3 opcodes:
  • RMM_EL3_TOKEN_SIGN_PUSH_REQ_OP
  • RMM_EL3_TOKEN_SIGN_PULL_RESP_OP
  • RMM_EL3_TOKEN_SIGN_GET_RAK_PUB_OP
The above opcodes can be used to send realm attestation token signing requests to EL3 and get their response, so that the realm attestation token can be constructed.
This command is useful when the RMM may not have access to the private portion of the realm attestation key and needs signing services from EL3 or CCA HES, or other platform specific mechanisms to perform signing.
The RMM-EL3 interface for this command is modeled as two separate queues, one for signing requests and one for retrieving the signed responses. It is possible that the queue in EL3 is full or EL3 is busy and unable to service the RMM requests, in which case the RMM is expected to retry the push operation for requests and pop operation for responses.
4.20.3.2.7.1. FID
0xC40001B5
4.20.3.2.7.2. Input values
Input values for RMM_EL3_TOKEN_SIGN
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
opcode
x1
[63:0]
UInt64
Opcode that is one of:
  • RMM_EL3_TOKEN_SIGN_PUSH_REQ_OP: 0x1 - Opcode to push a token signing request to EL3 using struct el3_token_sign_request as described above
  • RMM_EL3_TOKEN_SIGN_PULL_RESP_OP: 0x2 - Opcode to pull a token signing response from EL3 using struct el3_token_sign_response as described above
  • RMM_EL3_TOKEN_SIGN_GET_RAK_PUB_OP: 0x3 - Opcode to get the realm attestation public key
buf_pa
x2
[63:0]
Address
PA where the request structure is stored for the opcode RMM_EL3_TOKEN_SIGN_PUSH_REQ_OP, the response structure needs to be populated for the opcode RMM_EL3_TOKEN_SIGN_PULL_RESP_OP, or where the public key must be populated for the opcode RMM_EL3_TOKEN_SIGN_GET_RAK_PUB_OP. The PA must belong to the RMM-EL3 shared buffer
buf_size
x3
[63:0]
Size in bytes of the input buffer in buf_pa. buf_pa + buf_size must lie within the shared buffer
ecc_curve
x4
[63:0]
Enum
Type of the elliptic curve to which the requested attestation key belongs to. See Supported ECC Curves. This parameter is valid on for the opcode RMM_EL3_TOKEN_SIGN_GET_RAK_PUB_OP
4.20.3.2.7.3. Output values
Output values for RMM_EL3_TOKEN_SIGN
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
Command return status. Valid for all opcodes listed in input values
retval1
x1
[63:0]
Value
If opcode is RMM_EL3_TOKEN_SIGN_GET_RAK_PUB_OP, then returns length of public key returned. Otherwise, reserved
4.20.3.2.7.4. Failure conditions
Failure conditions for RMM_EL3_TOKEN_SIGN
ID
Condition
E_RMM_INVAL
if opcode is invalid or buffer address and length passed to the EL3 are not in valid range corresponding to the RMM-EL3 shared buffer, or if the curve used for opcode RMM_EL3_TOKEN_SIGN_GET_RAK_PUB_OP is not the ECC P384 curve
E_RMM_UNK
E_RMM_AGAIN
For opcode RMM_EL3_TOKEN_SIGN_PUSH_REQ_OP, if the request is not queued since the EL3 queue is full, or if the response is not ready yet, for other opcodes
E_RMM_OK
No errors detected
4.20.3.2.8. RMM_MEC_REFRESH command
This command updates the tweak for the encryption key/programs a new encryption key associated with a given MECID. After the execution of this command, all memory accesses associated with the MECID are encrypted/decrypted using the new key. This command is available from v0.8 of the RMM-EL3 interface.
4.20.3.2.8.1. FID
0xC40001B6
4.20.3.2.8.2. Input values
Input values for RMM_MEC_REFRESH
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
mecid
x1
[47:32]
UInt64
mecid is a 16-bit value between 0 and 65,535 that identifies the MECID for which the encryption key is to be updated. Value has to be a valid MECID as per field MECIDWidthm1 read from MECIDR_EL2. Bits [63:16] must be 0.
mecid
x1
[31:1]
UInt64
Reserved, MBZ
reason
x1
[0]
UInt64
reason is a single bit field used to indicate the reason for the MEC refresh. Values are: 0 (Realm creation), 1 (Realm destruction).
4.20.3.2.8.3. Output values
Output values for RMM_MEC_REFRESH
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
4.20.3.2.8.4. Failure conditions
Failure conditions for RMM_MEC_REFRESH
ID
Condition
E_RMM_INVAL
If a field in the x1 register is incorrectly encoded or if MECID is invalid (larger than the common MECID width, determined by MECIDR_EL2.MECIDWidthm1 + 1 or by other system components, whichever is lower)
E_RMM_UNK
An unknown error occurred whilst processing the command, FEAT_MEC is not present in hardware or the SMC is not present if the version is < 0.8.
E_RMM_OK
No errors detected
4.20.3.2.9. RMM_IDE_KEY_PROG command
Set the key/IV info at Root port for an IDE stream as part of Device Assignment flow. This command is available from v0.6 of the RMM-EL3 interface.
Please refer to IDE-KM RFC for description of the IDE setup sequence and how this will be invoked by RMM.
The key is 256 bits and IV is 96 bits. The caller needs to call this SMC to program this key to the Rx, Tx ports and for each sub-stream corresponding to a single keyset.
4.20.3.2.9.1. FID
0xC40001B7
4.20.3.2.9.2. Input values
Input values for RMM_IDE_KEY_PROG
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
ecam_address
x1
[63:0]
UInt64
Used to identify the root complex(RC)
rp_id
x2
[63:0]
UInt64
Used to identify the root port within the root complex(RC)
Keyset[12]: Dir[11]: Substream[10:8]: StreamID[7:0]
x3
[63:0]
UInt64
IDE selective stream informationKey set: can be 0 or 1unused bits MBZ.
KeqQW0
x4
[63:0]
UInt64
Quad word of key [63:0]
KeqQW1
x5
[63:0]
UInt64
Quad word of key [127:64]
KeqQW2
x6
[63:0]
UInt64
Quad word of key [191:128]
KeqQW3
x7
[63:0]
UInt64
Quad word of key [255:192]
IFVQW0
x8
[63:0]
UInt64
Quad word of IV [63:0]
IFVQW1
x9
[63:0]
UInt64
Quad word of IV [95:64]
request_id
x10
[63:0]
UInt64
Used only in non-blocking mode. Ignored in blocking mode.
cookie
x11
[63:0]
UInt64
4.20.3.2.9.3. Output values
Output values for RMM_IDE_KEY_PROG
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
4.20.3.2.9.4. Failure conditions
Failure conditions for RMM_IDE_KEY_PROG
ID
Condition
E_RMM_OK
The Key programming is successful.
E_RMM_FAULT
The Key programming is not successful.
E_RMM_INVAL
The Key programming arguments are incorrect.
E_RMM_UNK
Unknown error or the SMC is not present if the version is < 0.6.
E_RMM_AGAIN
Returned only for non-blocking mode. IDE-KM interface is busy or request is full. Retry required.
E_RMM_INPROGRESS
Returned only for non-blocking mode. The caller must issue RMM_IDE_KM_PULL_RESPONSE SMC to pull the response.
4.20.3.2.10. RMM_IDE_KEY_SET_GO command
Activate the IDE stream at Root Port once the keys have been programmed as part of Device Assignment flow. This command is available from v0.6 of the RMM-EL3 interface.
Please refer to IDE-KM RFC for description of the IDE setup sequence and info on how this will be invoked by RMM.
The caller(RMM) needs to ensure the EL3_IDE_KEY_PROG() call had succeeded prior to this call.
4.20.3.2.10.1. FID
0xC40001B8
4.20.3.2.10.2. Input values
Input values for RMM_IDE_KEY_SET_GO
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
ecam_address
x1
[63:0]
UInt64
rp_id
x2
[63:0]
UInt64
x3
[63:0]
UInt64
IDE selective stream information. Key set can be 0 or 1. Unused bits MBZ.
request_id
x4
[63:0]
UInt64
cookie
x5
[63:0]
UInt64
4.20.3.2.10.3. Output values
Output values for RMM_IDE_KEY_SET_GO
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
4.20.3.2.10.4. Failure conditions
Failure conditions for RMM_IDE_KEY_SET_GO
ID
Condition
E_RMM_OK
The Key set go is successful.
E_RMM_FAULT
The Key set go is not successful.
E_RMM_INVAL
Incorrect arguments.
E_RMM_UNK
E_RMM_AGAIN
E_RMM_INPROGRESS
4.20.3.2.11. RMM_IDE_KEY_SET_STOP command
Deactivate the IDE stream at Root Port as part of Device Assignment flow. This command is available from v0.6 of the RMM-EL3 interface.
This SMC is used to tear down an IDE Stream.
4.20.3.2.11.1. FID
0xC40001B9
4.20.3.2.11.2. Input values
Input values for RMM_IDE_KEY_SET_STOP
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
ecam_address
x1
[63:0]
UInt64
rp_id
x2
[63:0]
UInt64
x3
[63:0]
UInt64
request_id
x4
[63:0]
UInt64
cookie
x5
[63:0]
UInt64
4.20.3.2.11.3. Output values
Output values for RMM_IDE_KEY_SET_STOP
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
4.20.3.2.11.4. Failure conditions
Failure conditions for RMM_IDE_KEY_SET_STOP
ID
Condition
E_RMM_OK
The Key set stop is successful.
E_RMM_FAULT
The Key set stop is not successful.
E_RMM_INVAL
E_RMM_UNK
E_RMM_AGAIN
E_RMM_INPROGRESS
4.20.3.2.12. RMM_IDE_KM_PULL_RESPONSE command
Retrieve the response from Root Port to a previous non-blocking IDE-KM SMC request as part of Device Assignment flow. This command is available from v0.6 of the RMM-EL3 interface.
The response from this call could correspond to any of the last pending requests and the RMM needs to identify the request and populate the response. For blocking calls, this SMC always returns E_RMM_UNK.
4.20.3.2.12.1. FID
0xC40001BA
4.20.3.2.12.2. Input values
Input values for RMM_IDE_KM_PULL_RESPONSE
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
ecam_address
x1
[63:0]
UInt64
rp_id
x2
[63:0]
UInt64
4.20.3.2.12.3. Output values
Output values for RMM_IDE_KM_PULL_RESPONSE
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
Result
x1
[63:0]
Error Code
Retrieved response corresponding to previous IDE_KM requests.
Result
x2
[63:0]
value
passthrough from requested SMC
Result
x3
[63:0]
value
4.20.3.2.12.4. Failure conditions
Failure conditions for RMM_IDE_KM_PULL_RESPONSE(x0)
ID
Condition
E_RMM_OK
Response is retrieved successfully.
E_RMM_INVAL
Arguments to pull response SMC is not correct.
E_RMM_UNK
E_RMM_AGAIN
IDE-KM response queue is empty and no response is available.
Failure conditions for RMM_IDE_KM_PULL_RESPONSE(x1)
ID
Condition
E_RMM_OK
The previous request was successful.
E_RMM_FAULT
The previous request was not successful.
E_RMM_INVAL
Arguments to previous request were incorrect.
E_RMM_UNK
Previous request returned unknown error.
4.20.3.2.13. RMM_RESERVE_MEMORY command
This command is used to reserve memory for the RMM, during RMM boot time. This is not a fully featured dynamic memory allocator, since reservations cannot be freed again, and they must happen during the cold/warm boot phase of RMM. However it allows to size data structures in RMM based on runtime decisions, for instance depending on the number of cores or the amount of memory installed. This command is available from v0.7 of the RMM-EL3 interface.
4.20.3.2.13.1. FID
0xC40001BB
4.20.3.2.13.2. Input values
Input values for RMM_RESERVE_MEMORY
Name
Register
Field
Type
fid
x0
[63:0]
UInt64
Command FID
size
x1
[63:0]
required size of the memory region, in bytes
args
x2
[63:56]
UInt64
alignment requirement, in bits. A value of 16 would return a 64 KB aligned base address.
args
x2
[55:32]
UInt64
reserved
args
x2
[31:1]
UInt64
flags (reserved)
args
x2
[0]
UInt64
flags: local CPU: Determines whether the reservation should be taken from a pool close to the calling CPU.
4.20.3.2.13.3. Output values
Output values for RMM_RESERVE_MEMORY
Name
Register
Field
Type
Result
x0
[63:0]
Error Code
address
x1
[63:0]
Address
Physical address of the reserved memory area.
4.20.3.2.13.4. Failure conditions
Failure conditions for RMM_RESERVE_MEMORY
ID
Condition
E_RMM_INVAL
unrecognised flag bit
E_RMM_UNK
if the SMC is not present, if interface version is <0.7
E_RMM_NOMEM
size of region is larger than the available memory
E_RMM_OK
No errors detected
4.20.4. EL3–RMM Register Context Management Contract
As part of the Non-secure (NS) <-> Realm world switch, EL3 shall maintain a separate register context for each world. During a world transition, EL3 shall save and restore the required register state to ensure correct execution, isolation, and security.
4.20.4.1. Register Context Managed by EL3
EL3 shall maintain a distinct register context per world and shall save and restore the following registers during a world switch.
General-Purpose and Stack Registers
  • General-purpose registers: x0–x30
  • Stack pointers: * SP_EL0 * SP_EL2
EL2 System Registers
EL3 shall save and restore all EL2 system registers corresponding to features enabled by EL3 (that is, registers with the _EL2 architectural suffix), excluding the registers listed below (see Registers Not Managed by EL3).
Pointer Authentication Registers
EL3 shall save and restore the following Pointer Authentication (PAuth) key registers:
  • APIA
  • APIB
  • APDA
  • APDB
  • APGA
4.20.4.2. Registers Not Managed by EL3
EL3 shall not save or restore the registers listed below. If the Realm world makes use of any of the registers below, the Realm Management Monitor (RMM) is responsible for ensuring their correct preservation.
EL2 Registers Excluded from EL3 Management
  • EL2 physical timer registers
  • EL2 virtual timer registers
  • ZCR_EL2
  • ICC_SRE_EL2 if interface version is >= 1.0
  • ICH_HCR_EL2 if interface version is >= 1.0
  • ICH_VMCR_EL2 if interface version is >= 1.0
Additional Registers Outside EL3 Scope
  • FP/SIMD registers
  • SVE registers
  • SME registers
  • EL1 and EL0 system registers (except the PAuth key registers listed above)
4.20.4.3. SMCCC Compliance
During SMC forwarding between the Non-secure world and the Realm world:
  • EL3 shall forward registers x0–x7 from the Non-secure context to the Realm context as SMC input arguments.
  • EL3 populates return values in registers x0–x7 on return back to Non-Secure.
In accordance with SMCCC v1.2:
  • Register x4-x7 shall be preserved if it is not used to return a result.
  • The responsibility for preserving x4-x7, when required, lies with RMM.
In accordance with SMCCC v1.3:
  • The Non-secure world may specify whether SVE context is in use.
  • If the SVE context is marked as not in use by the Non-secure world, RMM may choose not to preserve the incoming SVE state, even if SVE registers are used during Realm execution. Before returning to the Non-secure world, the SVE register state is cleared in this case
  • The same requirements apply to SME registers.
Note:
Communication between NS world and RMM as defined by the RMM specification expects a maximum of registers x0–x7 for input arguments and returns results in x0–x7. If a future RMM specification requires extended input or output beyond this register set, this section of EL3–RMM contract will be updated.
4.20.4.4. Security Requirement
EL3 shall adhere to this contract to preserve the confidentiality and integrity of the Realm world during world transitions. Non-compliance may cause state corruption or cross-world information leakage.
4.20.5. Types
4.20.5.1. RMM-EL3 Boot Manifest structure
The RMM-EL3 Boot Manifest v0.5 structure contains platform boot information passed from EL3 to RMM. The size of the Boot Manifest is 160 bytes.
The members of the RMM-EL3 Boot Manifest structure are shown in the following table:
Name
Offset
Type
version
0
uint32_t
Boot Manifest version
padding
4
uint32_t
Reserved, set to 0
plat_data
8
uint64_t
Pointer to Platform Data section
plat_dram
16
memory_info
NS DRAM Layout Info structure
plat_console
40
console_list
List of consoles available to RMM
plat_ncoh_region
64
memory_info
Device non-coherent ranges Info structure
plat_coh_region
88
memory_info
Device coherent ranges Info structure
plat_smmu
112
smmu_list
List of SMMUs available to RMM (from Boot Manifest v0.5)
plat_root_complex
136
root_complex_list
List of PCIe root complexes available to RMM (from Boot Manifest v0.5)
4.20.5.2. Memory Info structure
Memory Info structure contains information about platform memory layout. The members of this structure are shown in the table below:
Name
Offset
Type
num_banks
0
uint64_t
Number of memory banks/device regions
banks
8
memory_bank *
Pointer to ‘memory_bank’[] array
checksum
16
uint64_t
Checksum
Checksum is calculated as two’s complement sum of ‘num_banks’, ‘banks’ pointer and memory banks data array pointed by it.
4.20.5.3. Memory Bank/Device region structure
Memory Bank structure contains information about each memory bank/device region:
Name
Offset
Type
base
0
uint64_t
Base address
size
8
uint64_t
Size of memory bank/device region in bytes
4.20.5.4. Console List structure
Console List structure contains information about the available consoles for RMM. The members of this structure are shown in the table below:
Name
Offset
Type
num_consoles
0
uint64_t
Number of consoles
consoles
8
console_info *
Pointer to ‘console_info’[] array
checksum
16
uint64_t
Checksum
Checksum is calculated as two’s complement sum of ‘num_consoles’, ‘consoles’ pointer and the consoles array pointed by it.
4.20.5.5. Console Info structure
Console Info structure contains information about each Console available to RMM.
Name
Offset
Type
base
0
uint64_t
Console Base address
map_pages
8
uint64_t
Num of pages to map for console MMIO
name
16
char[8]
Name of console
clk_in_hz
24
uint64_t
UART clock (in Hz) for console
baud_rate
32
uint64_t
Baud rate
flags
40
uint64_t
Additional flags (RES0)
4.20.5.6. SMMU List structure
SMMU List structure contains information about SMMUs available for RMM. The members of this structure are shown in the table below:
Name
Offset
Type
num_smmus
0
uint64_t
Number of SMMUs
smmus
8
smmu_info *
Pointer to ‘smmu_info’[] array
checksum
16
uint64_t
Checksum
4.20.5.7. SMMU Info structure
SMMU Info structure contains information about each SMMU available to RMM.
Name
Offset
Type
smmu_base
0
uint64_t
SMMU Base address
smmu_r_base
8
uint64_t
SMMU Realm Pages base address
4.20.5.8. Root Complex List structure
Root Complex List structure contains information about PCIe root complexes available for RMM. The members of this structure are shown in the table below.
Name
Offset
Type
num_root_complex
0
uint64_t
Number of root complexes
rc_info_version
8
uint32_t
Root Complex Info structure version
padding
12
uint32_t
Reserved, set to 0
root_complex
16
root_complex_info *
Pointer to ‘root_complex’[] array
checksum
24
uint64_t
Checksum
The checksum calculation of Root Complex List structure includes all data structures referenced by ‘root_complex_info’ pointer.
4.20.5.9. Root Complex Info structure
Root Complex Info structure contains information about each PCIe root complex available to RMM. The table below describes the members of this structure as per v0.1.
Name
Offset
Type
ecam_base
0
uint64_t
PCIe ECAM Base address
segment
8
uint8_t
PCIe segment identifier
padding[3]
9
uint8_t
Reserved, set to 0
num_root_ports
12
uint32_t
Number of root ports
root_ports
16
root_port_info *
Pointer to ‘root_port_info’[] array
The Root Complex Info structure version uses the same numbering scheme as described in RMM-EL3 Interface versioning.
4.20.5.10. Root Port Info structure
Root Complex Info structure contains information about each root port in PCIe root complex.
Name
Offset
Type
root_port_id
0
uint16_t
Root Port identifier
padding
2
uint16_t
Reserved, set to 0
num_bdf_mappings
4
uint32_t
Number of BDF mappings
bdf_mappings
8
bdf_mapping_info *
Pointer to ‘bdf_mapping_info’[] array
4.20.5.11. BDF Mapping Info structure
BDF Mapping Info structure contains information about each Device-Bus-Function (BDF) mapping for PCIe root port.
Name
Offset
Type
mapping_base
0
uint16_t
Base of BDF mapping (inclusive)
mapping_top
2
uint16_t
Top of BDF mapping (inclusive)
mapping_off
4
uint16_t
Mapping offset, as per Arm Base System Architecture: StreamID = RequesterID[15:0] + (1<<16)*mapping_off
smmu_idx
6
uint16_t
SMMU index in ‘smmu_info’[] array
4.20.5.12. EL3 Token Sign Request structure
This structure represents a realm attestation token signing request.
Name
Offset
Type
sig_alg_id
0
uint32_t
Algorithm idenfier for the sign request. - 0x0: ECC SECP384R1 (ECDSA) - Other values reserved
rec_granule
8
uint64_t
Identifier used by RMM to associate a signing request to a realm. Must not be interpreted or modified.
req_ticket
16
uint64_t
Value used by RMM to associate request and responses. Must not be interpreted or modified.
hash_alg_id
24
uint32_t
Hash algorithm for data in hash_buf - 0x1: SHA2-384 - All other values reserved.
hash_buf
32
uint8_t[]
TBS (to-be-signed) Hash of length defined by hash algorithm hash_alg_id
4.20.5.13. EL3 Token Sign Response structure
This structure represents a realm attestation token signing response.
Name
Offset
Type
rec_granule
0
uint64_t
req_ticket
8
uint64_t
sig_len
16
uint16_t
Length of the signature_buf field
signature_buf
18
uint8_t[]
Signature
