4.22. Vendor Specific EL3 Monitor Service Calls
This document enumerates and describes the Vendor Specific EL3 Monitor Service Calls.
These are Service Calls defined by the vendor of the EL3 Monitor.
They are accessed via SMC (“SMC calls”) instruction executed from Exception
Levels below EL3. SMC calls for Vendor Specific EL3 Monitor Services:
Follow SMC Calling Convention;
Use SMC function IDs that fall in the vendor-specific EL3 range, which are
SMC Function Identifier |
Service Type |
0x87000000 - 0x8700FFFF |
SMC32: Vendor Specific EL3 Monitor Service Calls |
0xC7000000 - 0xC700FFFF |
SMC64: Vendor Specific EL3 Monitor Service Calls |
Vendor-specific EL3 monitor services are as follows:
Service Type |
FID’s Usage |
0x87000010 - 0x8700001F (SMC32) |
DebugFS Interface |
0 - 11 are in use.
12 - 15 are reserved for future expansion.
0xC7000010 - 0xC700001F (SMC64) |
0x87000020 - 0x8700002F (SMC32) |
Performance Measurement Framework (PMF) |
0,1 is in use.
0xC7000020 - 0xC700002F (SMC64) |
0x87000030 - 0x8700003F (SMC32) |
ACS (Architecture Compliance Suite) SMC handler |
0 in use.
1 - 15 are reserved for future expansion.
0xC7000030 - 0xC700003F (SMC64) |
0x87000040 - 0x8700004F (SMC32) |
TPM Start method |
0 is in use but not currently implemented.
0xC7000040 - 0xC700004F (SMC64) |
0x87000050 - 0x8700FFFF (SMC32) |
Reserved |
0xC7000050 - 0xC700FFFF (SMC64) |
Source definitions for vendor-specific EL3 Monitor Service Calls used by TF-A are located in
the ven_el3_svc.h header file.
VEN_EL3_SVC_VERSION_MAJOR |
VEN_EL3_SVC_VERSION_MINOR |
Changes |
1 |
0 |
Added Debugfs and PMF services. |
1 | 1 | Added ACS SMC handler services. |
1 | 2 | Added TPM Start method. |
Table 1: Showing different versions of Vendor-specific service and changes done with each version
Each sub service will have its own version, one FID allocated for sub service version.
- Some ground rules when one should update top level version.
VEN_EL3_SVC_VERSION_MAJOR is incremented when any of the sub service version discovery FID changes or the FID that was allocated for discovery changes. So any breaking subfeature discovery changes will lead to major version update.
VEN_EL3_SVC_VERSION_MINOR is incremented when we add a new FID or a new sub service. For example adding an new monitor service at 0x30, Debugfs starts at 0x10 and PMF starts at 0x20 next one will start at 0x30, this will need a update to minor version.
4.22.1. Performance Measurement Framework (PMF)
The Performance Measurement Framework allows callers to retrieve timestamps captured at various paths in TF-A execution.
4.22.2. DebugFS interface
The optional DebugFS interface is accessed through Vendor specific EL3 service. Refer to DebugFS interface documentation for further details and usage.
4.22.3. Architecture Compliance Suite (ACS) SMC handler
The Architecture Compliance Suite (ACS) SMC handler allows callers to branch to their ACS EL3 code based on their respective use-cases. For more details on System ACS, System ACS.
4.22.4. TPM Start method
TPM start method as mentioned in TCG ACPI specification section 3.3.1.
Copyright (c) 2024-2025, Arm Limited and Contributors. All rights reserved.
