4.19. Chain of trust bindings
The device tree allows to describe the chain of trust with the help of ‘cot’ node which contain ‘manifests’ and ‘images’ as sub-nodes. ‘manifests’ and ‘images’ nodes contains number of sub-nodes (i.e. ‘certificate’ and ‘image’ nodes) mentioning properties of the certificate and image respectively.
Also, device tree describes ‘non-volatile-counters’ node which contains number of sub-nodes mentioning properties of all non-volatile-counters used in the chain of trust.
4.19.1. cot
This is root node which contains ‘manifests’ and ‘images’ as sub-nodes
4.19.2. Manifests and Certificate node bindings definition
  • Manifests node
    Description: Container of certificate nodes.
    PROPERTIES
    • compatible:
      Usage: required
      Value type: <string>
      Definition: must be “arm, cert-descs”
  • Certificate node
    Description:
    Describes certificate properties which are used during the authentication process.
    PROPERTIES
    • root-certificate
      Usage:
      Required for the certificate with no parent. In other words, certificates which are validated using root of trust public key.
      Value type: <boolean>
    • image-id
      Usage: Required for every certificate with unique id.
      Value type: <u32>
    • parent
      Usage:
      It refers to their parent image, which typically contains information to authenticate the certificate. This property is required for all non-root certificates.
      This property is not required for root-certificates as root-certificates are validated using root of trust public key provided by platform.
      Value type: <phandle>
    • signing-key
      Usage:
      For non-root certificates, this property is used to refer public key node present in parent certificate node and it is required property for all non-root certificates which are authenticated using public-key present in parent certificate.
      This property is not required for all root-certificates. If omitted, the root certificate will be validated using the default platform ROTPK. If instead the root certificate needs validating using a different ROTPK, the signing-key property should provide a reference to the ROTPK node to use.
    • antirollback-counter
      Usage:
      This property is used by all certificates which are protected against rollback attacks using a non-volatile counter and it is an optional property.
      This property is used to refer one of the non-volatile counter sub-node present in ‘non-volatile counters’ node.
    SUBNODES
    • Description:
      Hash and public key information present in the certificate are shown by these nodes.
    • public key node
      Description: Provide public key information in the certificate.
      PROPERTIES
      • oid
        Usage:
        This property provides the Object ID of public key provided in the certificate with the help of which public key information can be extracted.
    • hash node
      Description: Provide the hash information in the certificate.
      PROPERTIES
      • oid
        Usage:
        This property provides the Object ID of hash provided in the certificate with the help of which hash information can be extracted.
Example:
cot {
   manifests {
      compatible = "arm, cert-descs”
      trusted-key-cert: trusted-key-cert {
         root-certificate;
         image-id = <TRUSTED_KEY_CERT_ID>;
         antirollback-counter = <&trusted_nv_ctr>;
         trusted-world-pk: trusted-world-pk {
            oid = TRUSTED_WORLD_PK_OID;
         non-trusted-world-pk: non-trusted-world-pk {
            oid = NON_TRUSTED_WORLD_PK_OID;
      scp_fw_key_cert: scp_fw_key_cert {
         image-id = <SCP_FW_KEY_CERT_ID>;
         parent = <&trusted-key-cert>;
         signing-key = <&trusted_world_pk>;
         scp_fw_content_pk: scp_fw_content_pk {
            oid = SCP_FW_CONTENT_CERT_PK_OID;
      next-certificate {
4.19.3. Images and Image node bindings definition
  • Images node
    Description: Container of image nodes
    PROPERTIES
    • compatible:
      Usage: required
      Definition: must be “arm, img-descs”
  • Image node
    Description:
    Describes image properties which will be used during authentication process.
    PROPERTIES
    • image-id
      Usage: Required for every image with unique id.
      Value type: <u32>
    • parent
      Usage:
      Required for every image to provide a reference to its parent image, which contains the necessary information to authenticate it.
    • hash
      Usage:
      Required for all images which are validated using hash method. This property is used to refer hash node present in parent certificate node.
      Note:
      Currently, all images are validated using ‘hash’ method. In future, there may be multiple methods can be used to validate the image.
Example:
cot {
   images {
      compatible = "arm, img-descs";
      scp_bl2_image {
         image-id = <SCP_BL2_IMAGE_ID>;
         parent = <&scp_fw_content_cert>;
         hash = <&scp_fw_hash>;
      next-img {
4.19.4. non-volatile counter node binding definition
  • non-volatile counters node
    Description: Contains properties for non-volatile counters.
    PROPERTIES
    • compatible:
      Usage: required
      Definition: must be “arm, non-volatile-counter”
    • #address-cells
      Usage: required
      Value type: <u32>
      Definition:
      Must be set according to address size of non-volatile counter register
    • #size-cells
      Usage: required
      Value type: <u32>
      Definition: must be set to 0
    SUBNODE
    • counters node
      Description: Contains various non-volatile counters present in the platform.
    PROPERTIES
    • id
      Usage: Required for every nv-counter with unique id.
      Value type: <u32>
    • reg
      Usage:
      Register base address of non-volatile counter and it is required property.
      Value type: <u32>
    • oid
      Usage:
      This property provides the Object ID of non-volatile counter provided in the certificate and it is required property.
Example: Below is non-volatile counters example for ARM platform
non_volatile_counters: non_volatile_counters {
     compatible = "arm, non-volatile-counter";
     #address-cells = <1>;
     #size-cells = <0>;
     trusted_nv_ctr: trusted_nv_ctr {
        id  = <TRUSTED_NV_CTR_ID>;
        reg = <TFW_NVCTR_BASE>;
        oid = TRUSTED_FW_NVCOUNTER_OID;
     non_trusted_nv_ctr: non_trusted_nv_ctr {
        id  = <NON_TRUSTED_NV_CTR_ID>;
        reg = <NTFW_CTR_BASE>;
        oid = NON_TRUSTED_FW_NVCOUNTER_OID;
4.19.5. rot_keys node binding definition
  • rot_keys node
    Description: Contains root-of-trust keys for the root certificates.
    SUBNODES
    • Description:
      Root of trust key information present in the root certificates are shown by these nodes.
    • rot key node
      Description: Provide ROT key information in the certificate.
      PROPERTIES
      • oid
        Usage:
        This property provides the Object ID of ROT key provided in the certificate.
Example: Below is rot_keys example for CCA platform
rot_keys {
     swd_rot_pk: swd_rot_pk {
        oid = SWD_ROT_PK_OID;
     prot_pk: prot_pk {
        oid = PROT_PK_OID;
4.19.6. Future update to chain of trust binding
This binding document needs to be revisited to generalise some terminologies which are currently specific to X.509 certificates for e.g. Object IDs.
Copyright (c) 2020-2024, Arm Limited. All rights reserved.
