9.12. Advisory TFV-12 (CVE-2024-5660)
When Hardware Page Aggregation (HPA) is enabled memory accesses may be translated incorrectly.
CVE-2024-5660
Date
Reported on 26 Jan 2024
TF-A version from v2.2 to v2.12 LTS releases lts-v2.8.0 to lts-v2.8.26 LTS releases lts-v2.10.0 to lts-v2.10.10
Configurations Affected
Arm CPUs with Hardware Page Aggregation (HPA) running in environments where a modified, untrusted guest OS may operate, especially with specific hypervisors.
Potential for a compromised guest OS to attack the host via HPA mechanism, resulting in possible information disclosure.
Gerrit-Patches
Arm
9.12.1. Description
A vulnerability has been identified in certain Arm CPUs implementing the Hardware Page Aggregation (HPA) feature. In environments utilizing virtualization, a specially crafted or compromised guest operating system could exploit this vulnerability to affect the host system. This could potentially lead to information disclosure depending on the deployment scenario and hypervisor configuration.
The below table lists the CPUs that mitigate against this vulnerability in TF-A.
Core
Cortex-A77
Cortex-A78
Cortex-A78C
Cortex-A78AE
Cortex-A710
Cortex-X1
Cortex-X2
Cortex-X3
Cortex-X4
Cortex-X925
Neoverse-V1
Neoverse-V2
Neoverse-V3
Neoverse-N2
9.12.2. Mitigation and Recommendations
Arm recommends following the mitigation steps and configuration changes described in the official advisory. The issue is avoided by setting CPUECTLR_EL1[46] to 1 which will disable hardware page aggregation.
Users should refer to the latest firmware updates as provided by vendors and ensure that HPA-related security mitigations are enabled where applicable.
For further technical information, affected CPUs, and detailed guidance, refer to the full Official Arm Advisory.
