9.13. Advisory TFV-13 (CVE-2024-7881)
An unprivileged context can trigger a data memory-dependent prefetch engine to fetch the contents of a privileged location and consume those contents as an address that is also dereferenced.
CVE-2024-7881
Date
Reported on 16 August 2024
TF-A version from v2.2 to v2.12 LTS releases lts-v2.8.0 to lts-v2.8.28 LTS releases lts-v2.10.0 to lts-v2.10.12
Configurations Affected
All
Potential leakage of secure world data to normal world.
Gerrit topic #ar/smccc_arch_wa_4 Also see mitigation guidance in the Official Arm Advisory
Arm
9.13.1. Description
An issue has been identified in some Arm-based CPUs that may allow an unprivileged context to trigger a data memory-dependent prefetch engine to fetch the contents of a privileged location (for which it does not have read permission) and consume those contents as an address that is also dereferenced.
The following table identifies all affected CPUs and revisions for which a mitigation is provided in TF-A.
CPU
Affected Versions
Fix Status
cortex-x3
r0p0, r1p0, r1p1, r1p2
open
cortex-x4
r0p0, r0p1, r0p2
fixed in r0p3
cortex-x925
r0p0, r0p1
fixed in r0p2
neoverse-v2
r0p0, r0p1, r0p2
open
neoverse-v3
r0p0, r0p1
fixed in r0p2
neoverse-v3ae
r0p0, r0p1
fixed in r0p2
c1-premium
r0p0
fixed in r1p0
c1-pro
r0p0, r1p0
fixed in r1p1
c1-ultra
r0p0
fixed in r1p0
9.13.2. Mitigation and Recommendations
Arm recommends following the mitigation steps and configuration changes described in the official advisory. The mitigation for CVE-2024-7881 is implemented at EL3 and addresses vulnerabilities caused by memory-dependant speculative prefetching. This issue can be avoided by disabling the affected prefetcher. For most cores, this is done by setting CPUACTLR6_EL1[41] = 1. For C1-Pro, the affected prefetcher is instead disabled by setting IMP_CPUECTLR_EL1[49] = 1.
Arm has updated the SMC Calling Convention spec so that privileged normal world software can identify when the issue has been mitigated in firmware (SMCCC_ARCH_WORKAROUND_4). Refer to the SMC Calling Convention Specification for more details.
The above workaround is enabled by default (on vulnerable CPUs only). Platforms can choose to disable them at compile time if they do not require them.
For further technical information, affected CPUs, and detailed guidance, refer to the full Official Arm Advisory.
