5.3. Arm CPU Specific Build Macros
This document describes the various build options present in the CPU specific operations framework to enable errata workarounds and to enable optimizations for a specific CPU on a platform.
5.3.1. Security Vulnerability Workarounds
TF-A exports a series of build flags which control which security vulnerability workarounds should be applied at runtime.
WORKAROUND_CVE_2017_5715: Enables the security workaround for CVE-2017-5715. This flag can be set to 0 by the platform if none of the PEs in the system need the workaround. Setting this flag to 0 provides no performance benefit for non-affected platforms, it just helps to comply with the recommendation in the spec regarding workaround discovery. Defaults to 1.WORKAROUND_CVE_2018_3639: Enables the security workaround for CVE-2018-3639. Defaults to 1. The TF-A project recommends to keep the default value of 1 even on platforms that are unaffected by CVE-2018-3639, in order to comply with the recommendation in the spec regarding workaround discovery.DYNAMIC_WORKAROUND_CVE_2018_3639: Enables dynamic mitigation for CVE-2018-3639. This build option should be set to 1 if the target platform contains at least 1 CPU that requires dynamic mitigation. Defaults to 0.WORKAROUND_CVE_2022_23960: Enables mitigation for CVE-2022-23960. This build option should be set to 1 if the target platform contains at least 1 CPU that requires this mitigation. Defaults to 1.WORKAROUND_CVE_2024_5660: Enables mitigation for CVE-2024-5660. The fix is to disable hardware page aggregation by setting CPUECTLR_EL1[46] in EL3 FW. This build option should be set to 1 if the target platform contains at least 1 CPU that requires this mitigation. Defaults to 1.WORKAROUND_CVE_2024_7881: Enables mitigation for CVE-2024-7881. This build option should be set to 1 if the target platform contains at least 1 CPU that requires this mitigation. Defaults to 1.WORKAROUND_CVE_2025_0647: Enables mitigation for CVE-2025-0647. This build option should be set to 1 if the target platform contains at least 1 CPU that requires this mitigation. Defaults to 1.WORKAROUND_CVE_2025_10263: Enables mitigation for CVE-2025-10263. This build option should be set to 1 if the target platform contains at least 1 CPU that requires this mitigation. Defaults to 0, due to the nature of this workaround it cannot be checked at runtime so should not be enabled unless needed by the platform.WORKAROUND_CVE_2026-0995: Enables mitigation for CVE-2026-0995. This build option should be set to 1 if the target platform contains at least 1 C1 Pro CPU. Platforms should also inlcude lib/cpus/helpers/aarch64/c1_pro_pubsub.c in BL31_SOURCES. Defaults to 0.
5.3.2. CPU Errata Workarounds
TF-A exports a series of build flags which control the errata workarounds that are applied to each CPU by the reset handler. The errata details can be found in the CPU specific errata documents published by Arm: For example: Cortex-A72 MPCore Software Developers Errata Notice
The errata workarounds are implemented for a particular revision or a set of
processor revisions. This is checked by the reset handler at runtime. Each
errata workaround is identified by its ID as specified in the processor’s
errata notice document. The format of the define used to enable/disable the
errata workaround is ERRATA_<Processor name>_<ID>, where the Processor name
is for example A57 for the Cortex_A57 CPU.
Refer to CPU errata implementation for information on how to write errata workaround functions.
All workarounds are disabled by default. The platform is responsible for enabling these workarounds according to its requirement by defining the errata workaround build flags in the platform specific makefile. In case these workarounds are enabled for the wrong CPU revision then the errata workaround is not applied. In the DEBUG build, this is indicated by printing a warning to the crash console.
In the current implementation, a platform which has more than 1 variant with different revisions of a processor has no runtime mechanism available for it to specify which errata workarounds should be enabled or not.
The value of the build flags is 0 by default, that is, disabled. A value of 1 will enable it.
For Cortex-A9, the following errata build flags are defined :
ERRATA_A9_794073: This applies errata 794073 workaround to Cortex-A9 CPU. This needs to be enabled for all revisions of the CPU.
For Cortex-A15, the following errata build flags are defined :
ERRATA_A15_816470: This applies errata 816470 workaround to Cortex-A15 CPU. This needs to be enabled only for revision >= r3p0 of the CPU.ERRATA_A15_827671: This applies errata 827671 workaround to Cortex-A15 CPU. This needs to be enabled only for revision >= r3p0 of the CPU.
For Cortex-A17, the following errata build flags are defined :
ERRATA_A17_852421: This applies errata 852421 workaround to Cortex-A17 CPU. This needs to be enabled only for revision <= r1p2 of the CPU.ERRATA_A17_852423: This applies errata 852423 workaround to Cortex-A17 CPU. This needs to be enabled only for revision <= r1p2 of the CPU.
For Cortex-A35, the following errata build flags are defined :
ERRATA_A35_855472: This applies errata 855472 workaround to Cortex-A35 CPUs. This needs to be enabled only for revision r0p0 of Cortex-A35.
For Cortex-A53, the following errata build flags are defined :
ERRATA_A53_819472: This applies errata 819472 workaround to all CPUs. This needs to be enabled only for revision <= r0p1 of Cortex-A53.ERRATA_A53_824069: This applies errata 824069 workaround to all CPUs. This needs to be enabled only for revision <= r0p2 of Cortex-A53.ERRATA_A53_826319: This applies errata 826319 workaround to Cortex-A53 CPU. This needs to be enabled only for revision <= r0p2 of the CPU.ERRATA_A53_827319: This applies errata 827319 workaround to all CPUs. This needs to be enabled only for revision <= r0p2 of Cortex-A53.ERRATA_A53_835769: This applies erratum 835769 workaround at compile and link time to Cortex-A53 CPU. This needs to be enabled for some variants of revision <= r0p4. This workaround can lead the linker to create*.stubsections.ERRATA_A53_836870: This applies errata 836870 workaround to Cortex-A53 CPU. This needs to be enabled only for revision <= r0p3 of the CPU. From r0p4 and onwards, this errata is enabled by default in hardware. Identical toA53_DISABLE_NON_TEMPORAL_HINT.ERRATA_A53_843419: This applies erratum 843419 workaround at link time to Cortex-A53 CPU. This needs to be enabled for some variants of revision <= r0p4. This workaround can lead the linker to emit*.stubsections which are 4kB aligned.ERRATA_A53_855873: This applies errata 855873 workaround to Cortex-A53 CPUs. Though the erratum is present in every revision of the CPU, this workaround is only applied to CPUs from r0p3 onwards, which feature a chicken bit in CPUACTLR_EL1 to enable a hardware workaround. Earlier revisions of the CPU have other errata which require the same workaround in software, so they should be covered anyway.ERRATA_A53_1530924: This applies errata 1530924 workaround to all revisions of Cortex-A53 CPU.
For Cortex-A55, the following errata build flags are defined :
ERRATA_A55_768277: This applies errata 768277 workaround to Cortex-A55 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A55_778703: This applies errata 778703 workaround to Cortex-A55 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A55_798797: This applies errata 798797 workaround to Cortex-A55 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A55_846532: This applies errata 846532 workaround to Cortex-A55 CPU. This needs to be enabled only for revision <= r0p1 of the CPU.ERRATA_A55_903758: This applies errata 903758 workaround to Cortex-A55 CPU. This needs to be enabled only for revision <= r0p1 of the CPU.ERRATA_A55_1221012: This applies errata 1221012 workaround to Cortex-A55 CPU. This needs to be enabled only for revision <= r1p0 of the CPU.ERRATA_A55_1530923: This applies errata 1530923 workaround to all revisions of Cortex-A55 CPU.
For Cortex-A57, the following errata build flags are defined :
ERRATA_A57_806969: This applies errata 806969 workaround to Cortex-A57 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A57_813419: This applies errata 813419 workaround to Cortex-A57 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A57_813420: This applies errata 813420 workaround to Cortex-A57 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A57_814670: This applies errata 814670 workaround to Cortex-A57 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A57_817169: This applies errata 817169 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r0p1 of the CPU.ERRATA_A57_817171: This applies erratum 817171 workaround to Cortex-A57CPU. This needs to be enabled for revisions r0p0, r0p1 of the CPU. It is fixed in r1p0.
ERRATA_A57_826974: This applies errata 826974 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r1p1 of the CPU.ERRATA_A57_826977: This applies errata 826977 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r1p1 of the CPU.ERRATA_A57_828024: This applies errata 828024 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r1p1 of the CPU.ERRATA_A57_829520: This applies errata 829520 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r1p2 of the CPU.ERRATA_A57_833471: This applies errata 833471 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r1p2 of the CPU.ERRATA_A57_836019: This applies erratum 836019 workaround to Cortex-A57CPU. This needs to be enabled for revisions r0p0, r0p1, r1p0, r1p1, r1p2, r1p3 of the CPU. It is still open.
ERRATA_A57_859972: This applies errata 859972 workaround to Cortex-A57 CPU. This needs to be enabled only for revision <= r1p3 of the CPU.ERRATA_A57_1319537: This applies errata 1319537 workaround to all revisions of Cortex-A57 CPU.
For Cortex-A65, the following errata build flags are defined :
ERRATA_A65_1179935: This applies errata 1179935 workaround to Cortex-A65 CPU. This needs to be enabled only for revision r0p0 of the CPU, and is fixed in r1p0.ERRATA_A65_1227419: This applies errata 1227419 workaround to Cortex-A65 CPU. This needs to be enabled only for revision r0p0 and r1p0 of the CPU and is fixed in r1p1.ERRATA_A65_1541130: This applies errata 1541130 workaround to r0p0, r1p0, r1p1, r1p2 revisions of the CPU and is still open.
For Cortex-A65AE, the following errata build flags are defined :
ERRATA_A65AE_1638571: This applies errata 1638571 workaround to Cortex-A65AE CPU. This needs to be enabled r0p0, r1p0, r1p1 revisions of the CPU and is still open.
For Cortex-A72, the following errata build flags are defined :
ERRATA_A72_859971: This applies errata 859971 workaround to Cortex-A72 CPU. This needs to be enabled only for revision <= r0p3 of the CPU.ERRATA_A72_1319367: This applies errata 1319367 workaround to all revisions of Cortex-A72 CPU.
For Cortex-A73, the following errata build flags are defined :
ERRATA_A73_852427: This applies errata 852427 workaround to Cortex-A73 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A73_855423: This applies errata 855423 workaround to Cortex-A73 CPU. This needs to be enabled only for revision <= r0p1 of the CPU.
For Cortex-A75, the following errata build flags are defined :
ERRATA_A75_764081: This applies errata 764081 workaround to Cortex-A75 CPU. This needs to be enabled only for revision r0p0 of the CPU.ERRATA_A75_790748: This applies errata 790748 workaround to Cortex-A75CPU. This needs to be enabled only for revision r0p0 of the CPU.
For Cortex-A76, the following errata build flags are defined :
ERRATA_A76_1073348: This applies errata 1073348 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r1p0 of the CPU.ERRATA_A76_1130799: This applies errata 1130799 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r2p0 of the CPU.ERRATA_A76_1165347: This applies errata 1165347 workaround to Cortex-A76 CPU. This needs to be enabled for revisions r0p0, r1p0, and r2p0 of the CPU. It is fixed in r3p0.ERRATA_A76_1165522: This applies errata 1165522 workaround to all revisions of Cortex-A76 CPU. This errata is fixed in r3p0 but due to limitation of errata framework this errata is applied to all revisions of Cortex-A76 CPU.ERRATA_A76_1207823: This applies errata 1207823 workaround to Cortex-A76 CPU. This needs to be enabled for revisions r0p0, r1p0, and r2p0 of the CPU. It is fixed in r3p0.ERRATA_A76_1220197: This applies errata 1220197 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r2p0 of the CPU.ERRATA_A76_1257314: This applies errata 1257314 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_A76_1262606: This applies errata 1262606 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_A76_1262888: This applies errata 1262888 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_A76_1275112: This applies errata 1275112 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_A76_1791580: This applies errata 1791580 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r4p0 of the CPU.ERRATA_A76_1868343: This applies errata 1868343 workaround to Cortex-A76 CPU. This needs to be enabled only for revision <= r4p0 of the CPU.ERRATA_A76_1946160: This applies errata 1946160 workaround to Cortex-A76 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r3p0, r3p1, r4p0, and r4p1 of the CPU. It is still open.ERRATA_A76_2356586: This applies erratum 2356586 workaround to Cortex-A76CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r3p0, r3p1, r4p0, r4p1 of the CPU. It is still open.
ERRATA_A76_2743102: This applies errata 2743102 workaround to Cortex-A76 CPU. This needs to be enabled for all revisions <= r4p1 of the CPU and is still open.ERRATA_A76_3888013: This applies erratum 3888013 workaround to Cortex-A76CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r3p0, r3p1, r4p0, r4p1 of the CPU. It is still open.
For Cortex-A76AE, the following errata build flags are defined :
ERRATA_A76AE_1931427: This applies errata 1931427 workaround to Cortex-A76AE CPU. This needs to be enabled for revision r0p0 and r1p0 of the CPU and it is fixed in r1p1.ERRATA_A76AE_1931435: This applies errata 1931435 workaround to Cortex-A76AE CPU. This needs to be enabled for revision r0p0 and r1p0 of the CPU and it is fixed in r1p1.ERRATA_A76AE_1969401: This applies errata 1969401 workaround to Cortex-A76AE CPU. This needs to be enabled for revision r0p0 and r1p0 of the CPU and it is fixed in r1p1.ERRATA_A76AE_2371140: This applies errata 2371140 workaround to Cortex-A76AE CPU. This needs to be enabled for all revisions <= r1p1 of the CPU and is still open.ERRATA_A76AE_2753838: This applies errata 2753838 workaround to Cortex-A76AE CPU. This needs to be enabled for all revisions <= r1p1 of the CPU and is still open.ERRATA_A76AE_3888014: This applies erratum 3888014 workaround toCortex-A76AE CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 of the CPU. It is still open.
For Cortex-A77, the following errata build flags are defined :
ERRATA_A77_1160841: This applies erratum 1160841 workaround to Cortex-A77CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A77_1204882: This applies erratum 1204882 workaround to Cortex-A77CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A77_1220737: This applies erratum 1220737 workaround to Cortex-A77CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A77_1253791: This applies erratum 1253791 workaround to Cortex-A77CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A77_1273521: This applies erratum 1273521 workaround to Cortex-A77CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A77_1508412: This applies errata 1508412 workaround to Cortex-A77 CPU. This needs to be enabled only for revision <= r1p0 of the CPU.ERRATA_A77_1515815: This applies erratum 1515815 workaround to Cortex-A77CPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r1p1.
ERRATA_A77_1925769: This applies errata 1925769 workaround to Cortex-A77 CPU. This needs to be enabled only for revision <= r1p1 of the CPU.ERRATA_A77_1946167: This applies errata 1946167 workaround to Cortex-A77 CPU. This needs to be enabled only for revision <= r1p1 of the CPU.ERRATA_A77_1791578: This applies errata 1791578 workaround to Cortex-A77 CPU. This needs to be enabled for r0p0, r1p0, and r1p1, it is still open.ERRATA_A77_2356587: This applies errata 2356587 workaround to Cortex-A77 CPU. This needs to be enabled for r0p0, r1p0, and r1p1, it is still open.
ERRATA_A77_1800714: This applies errata 1800714 workaround to Cortex-A77 CPU. This needs to be enabled for revisions <= r1p1 of the CPU.
ERRATA_A77_2743100: This applies errata 2743100 workaround to Cortex-A77 CPU. This needs to be enabled for r0p0, r1p0, and r1p1, it is still open.
ERRATA_A77_3888015: This applies erratum 3888015 workaround to Cortex-A77CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 of the CPU. It is still open.
For Cortex-A78, the following errata build flags are defined :
ERRATA_A78_1467580: This applies erratum 1467580 workaround to Cortex-A78CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A78_1479939: This applies erratum 1479939 workaround to Cortex-A78CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A78_1492189: This applies erratum 1492189 workaround to Cortex-A78CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A78_1503072: This applies erratum 1503072 workaround to Cortex-A78CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A78_1515634: This applies erratum 1515634 workaround to Cortex-A78CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A78_1688305: This applies errata 1688305 workaround to Cortex-A78 CPU. This needs to be enabled only for revision r0p0 - r1p0 of the CPU.ERRATA_A78_1827429: This applies erratum 1827429 workaround to Cortex-A78CPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r1p1.
ERRATA_A78_1941498: This applies errata 1941498 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0, r1p0, and r1p1 of the CPU.ERRATA_A78_1951500: This applies errata 1951500 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r1p0 and r1p1, r0p0 has the same issue but there is no workaround for that revision.ERRATA_A78_1821534: This applies errata 1821534 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0 and r1p0.ERRATA_A78_1952683: This applies errata 1952683 workaround to Cortex-A78 CPU. This needs to be enabled for revision r0p0, it is fixed in r1p0.ERRATA_A78_2242635: This applies errata 2242635 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r1p0, r1p1, and r1p2. The issue is present in r0p0 but there is no workaround. It is still open.ERRATA_A78_2376745: This applies errata 2376745 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, and r1p2, and it is still open.ERRATA_A78_2395406: This applies errata 2395406 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, and r1p2, and it is still open.ERRATA_A78_2742426: This applies erratum 2742426 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 and it is still open.ERRATA_A78_2772019: This applies errata 2772019 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, and r1p2, and it is still open.ERRATA_A78_2779479: This applies erratum 2779479 workaround to Cortex-A78 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 and it is still open.ERRATA_A78_3888017: This applies erratum 3888017 workaround to Cortex-A78CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
ERRATA_A78_4302972: This applies erratum 4302972 workaround to Cortex-A78CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
For Cortex-A78AE, the following errata build flags are defined :
ERRATA_A78_AE_1827431: This applies erratum 1827431 workaround toCortex-A78AE CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A78_AE_1827433: This applies erratum 1827433 workaround toCortex-A78AE CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A78_AE_1941500This applies errata 1941500 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0 and r0p1. This erratum is still open.
ERRATA_A78_AE_1951502: This applies errata 1951502 workaround to Cortex-A78AE CPU. This needs to be enabled for revisions r0p0 and r0p1. This erratum is still open.ERRATA_A78_AE_2242639: This applies erratum 2242639 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1 of the CPU. It is fixed in r0p2. There is no workaround for revision r0p0.
ERRATA_A78_AE_2376748: This applies errata 2376748 workaround to Cortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. This erratum is still open.ERRATA_A78_AE_2395408: This applies errata 2395408 workaround to Cortex-A78AE CPU. This needs to be enabled for revisions r0p0 and r0p1. This erratum is still open.ERRATA_A78_AE_2466780: This applies erratum 2466780 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1 of the CPU. It is fixed in r0p2.
ERRATA_A78_AE_2743229: This applies erratum 2743229 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is fixed in r0p3.
ERRATA_A78_AE_2779481: This applies erratum 2779481 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is fixed in r0p3.
ERRATA_A78_AE_3888018: This applies erratum 3888018 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 of the CPU. It is still open.
ERRATA_A78_AE_4302973: This applies erratum 4302973 workaround toCortex-A78AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 of the CPU. It is still open.
For Cortex-A78C, the following errata build flags are defined :
ERRATA_A78C_1827430: This applies errata 1827430 workaround to Cortex-A78C CPU. This needs to be enabled for revision r0p0. The erratum is fixed in r0p1.ERRATA_A78C_1827440: This applies errata 1827440 workaround to Cortex-A78C CPU. This needs to be enabled for revision r0p0. The erratum is fixed in r0p1.ERRATA_A78C_1941499: This applies erratum 1941499 workaround toCortex-A78C CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A78C_1951501: This applies erratum 1951501 workaround toCortex-A78C CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A78C_2242638: This applies errata 2242638 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p1, r0p2 and it is still open.ERRATA_A78C_2376746: This applies erratum 2376746 workaround toCortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
ERRATA_A78C_2376749: This applies errata 2376749 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p1 and r0p2. This erratum is still open.ERRATA_A78C_2395407: This applies erratum 2395407 workaround toCortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
ERRATA_A78C_2395411: This applies errata 2395411 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p1 and r0p2. This erratum is still open.ERRATA_A78C_2478780: This applies erratum 2478780 workaround toCortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
ERRATA_A78C_2683027: This applies errata 2683027 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p1 and r0p2. This erratum is still open.ERRATA_A78C_2743232: This applies erratum 2743232 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p1 and r0p2. This erratum is still open.ERRATA_A78C_2772121: This applies errata 2772121 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. This erratum is still open.ERRATA_A78C_2779483: This applies erratum 2779483 workaround toCortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
ERRATA_A78C_2779484: This applies errata 2779484 workaround to Cortex-A78C CPU. This needs to be enabled for revisions r0p1 and r0p2. This erratum is still open.ERRATA_A78C_3888019: This applies erratum 3888019 workaround toCortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
ERRATA_A78C_4302974: This applies erratum 4302974 workaround toCortex-A78C CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
For Cortex-X1 CPU, the following errata build flags are defined:
ERRATA_X1_1467580: This applies erratum 1467580 workaround to Cortex-X1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X1_1492189: This applies erratum 1492189 workaround to Cortex-X1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X1_1503072: This applies erratum 1503072 workaround to Cortex-X1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X1_1515634: This applies erratum 1515634 workaround to Cortex-X1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X1_1479939: This applies erratum 1479939 workaround to Cortex-X1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X1_1821534This applies errata 1821534 workaround to Cortex-X1CPU. This needs to be enabled only for revision <= r1p0 of the CPU.
ERRATA_X1_1688305This applies errata 1688305 workaround to Cortex-X1CPU. This needs to be enabled only for revision <= r1p0 of the CPU.
ERRATA_X1_1827429This applies errata 1827429 workaround to Cortex-X1CPU. This needs to be enabled only for revision <= r1p0 of the CPU.
ERRATA_X1_1941498: This applies erratum 1941498 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 of the CPU. It is fixed in r1p2.
ERRATA_X1_1951500: This applies erratum 1951500 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 of the CPU. It is fixed in r1p2.
ERRATA_X1_1952683: This applies erratum 1952683 workaround to Cortex-X1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X1_2376745: This applies erratum 2376745 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
ERRATA_X1_2395406: This applies erratum 2395406 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
ERRATA_X1_2742426: This applies erratum 2742426 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
ERRATA_X1_2779479: This applies erratum 2779479 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
ERRATA_X1_3888017: This applies erratum 3888017 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
ERRATA_X1_4302972: This applies erratum 4302972 workaround to Cortex-X1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
For Cortex-X1C CPU, the following errata build flags are defined:
ERRATA_X1C_1827430: This applies erratum 1827430 workaround toCortex-X1C CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X1C_1827440: This applies erratum 1827440 workaround toCortex-X1C CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X1C_1941499: This applies erratum 1941499 workaround toCortex-X1C CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X1C_1951501: This applies erratum 1951501 workaround toCortex-X1C CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X1C_2376746: This applies erratum 2376746 workaround toCortex-X1C CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU. It is still open.
ERRATA_X1C_2395407: This applies erratum 2395407 workaround toCortex-X1C CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU. It is still open.
ERRATA_X1C_2743232: This applies erratum 2743232 workaround toCortex-X1C CPU. This needs to be enabled for revisions r0p1 and r0p2 of the CPU. It is fixed in r0p3.
ERRATA_X1C_2779483: This applies erratum 2779483 workaround toCortex-X1C CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU. It is still open.
ERRATA_X1C_3888019: This applies erratum 3888019 workaround toCortex-X1C CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU. It is still open.
ERRATA_X1C_4302974: This applies erratum 4302974 workaround toCortex-X1C CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU. It is still open.
For Neoverse N1, the following errata build flags are defined :
ERRATA_N1_925373: This applies erratum 925373 workaround to Neoverse N1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_N1_1073348: This applies errata 1073348 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision r0p0 and r1p0 of the CPU.ERRATA_N1_1130799: This applies errata 1130799 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r2p0 of the CPU.ERRATA_N1_1165347: This applies errata 1165347 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r2p0 of the CPU.ERRATA_N1_1207823: This applies errata 1207823 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r2p0 of the CPU.ERRATA_N1_1220197: This applies errata 1220197 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r2p0 of the CPU.ERRATA_N1_1257314: This applies errata 1257314 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_N1_1262606: This applies errata 1262606 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_N1_1262888: This applies errata 1262888 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_N1_1275112: This applies errata 1275112 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_N1_1315703: This applies errata 1315703 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r3p0 of the CPU.ERRATA_N1_1542419: This applies errata 1542419 workaround to Neoverse-N1 CPU. This needs to be enabled only for revisions r3p0 - r4p0 of the CPU.ERRATA_N1_1791580: This applies erratum 1791580 workaround to Neoverse N1CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r3p0, r3p1, r4p0 of the CPU. It is fixed in r4p1.
ERRATA_N1_1868343: This applies errata 1868343 workaround to Neoverse-N1 CPU. This needs to be enabled only for revision <= r4p0 of the CPU.ERRATA_N1_1946160: This applies errata 1946160 workaround to Neoverse-N1 CPU. This needs to be enabled for revisions r3p0, r3p1, r4p0, and r4p1, for revisions r0p0, r1p0, and r2p0 there is no workaround.ERRATA_N1_2743102: This applies errata 2743102 workaround to Neoverse-N1 CPU. This needs to be enabled for all revisions <= r4p1 of the CPU and is still open.ERRATA_N1_3324349: This applies errata 3324349 workaround to Neoverse-N1 CPU. This needs to be enabled for all revisions <= r4p1 of the CPU and is still open.ERRATA_N1_3888013: This applies erratum 3888013 workaround to Neoverse N1CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r3p0, r3p1, r4p0, r4p1 of the CPU. It is still open.
For Neoverse V1, the following errata build flags are defined :
ERRATA_V1_1542436: This applies erratum 1542436 workaround to Neoverse V1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_V1_1618634: This applies erratum 1618634 workaround to Neoverse V1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_V1_1618635: This applies errata 1618635 workaround to Neoverse-V1 CPU. This needs to be enabled for revision r0p0 of the CPU, it is fixed in r1p0.ERRATA_V1_1618636: This applies erratum 1618636 workaround to Neoverse V1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_V1_1619807: This applies erratum 1619807 workaround to Neoverse V1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_V1_1654562: This applies erratum 1654562 workaround to Neoverse V1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_V1_1674403: This applies erratum 1674403 workaround to Neoverse V1CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_V1_1774420: This applies errata 1774420 workaround to Neoverse-V1 CPU. This needs to be enabled only for revisions r0p0 and r1p0, it is fixed in r1p1.ERRATA_V1_1791573: This applies errata 1791573 workaround to Neoverse-V1 CPU. This needs to be enabled only for revisions r0p0 and r1p0, it is fixed in r1p1.ERRATA_V1_1852267: This applies errata 1852267 workaround to Neoverse-V1 CPU. This needs to be enabled only for revisions r0p0 and r1p0, it is fixed in r1p1.ERRATA_V1_1925756: This applies errata 1925756 workaround to Neoverse-V1 CPU. This needs to be enabled for r0p0, r1p0, and r1p1, it is still open.ERRATA_V1_1940577: This applies errata 1940577 workaround to Neoverse-V1 CPU. This needs to be enabled only for revision r1p0 and r1p1 of the CPU.ERRATA_V1_1966096: This applies errata 1966096 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r1p0 and r1p1 of the CPU, the issue is present in r0p0 as well but there is no workaround for that revision. It is still open.ERRATA_V1_2139242: This applies errata 2139242 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0, and r1p1 of the CPU. It is still open.ERRATA_V1_2216392: This applies errata 2216392 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r1p0 and r1p1 of the CPU, the issue is present in r0p0 as well but there is no workaround for that revision. It is still open.ERRATA_V1_2294912: This applies errata 2294912 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0, and r1p1 and r1p2 of the CPU.ERRATA_V1_2348377: This applies errata 2348377 workaroud to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0 and r1p1 of the CPU. It has been fixed in r1p2.ERRATA_V1_2372203: This applies errata 2372203 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0 and r1p1 of the CPU. It is still open.ERRATA_V1_2743093: This applies errata 2743093 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 of the CPU. It is still open.ERRATA_V1_2743233: This applies erratum 2743233 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, and r1p2 of the CPU. It is still open.ERRATA_V1_2779461: This applies erratum 2779461 workaround to Neoverse-V1 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.ERRATA_V1_3888016: This applies erratum 3888016 workaround to Neoverse V1CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 of the CPU. It is still open.
For Neoverse V2, the following errata build flags are defined :
ERRATA_V2_2394277: This applies erratum 2394277 workaround to Neoverse V2CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_V2_2618597: This applies errata 2618597 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V2_2662553: This applies errata 2662553 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V2_2719105: This applies errata 2719105 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V2_2743011: This applies errata 2743011 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V2_2779510: This applies errata 2779510 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V2_2801372: This applies errata 2801372 workaround to Neoverse-V2 CPU, this affects all configurations. This needs to be enabled for revisions r0p0 and r0p1. It has been fixed in r0p2.ERRATA_V2_3099206: This applies errata 3099206 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0, r0p1, and r0p2. Open and is still open.ERRATA_V2_3442699: This applies errata 3442699 workaround to Neoverse-V2 CPU. This needs to be enabled for revision r0p0 - r0p2 and is still open.ERRATA_V2_3701771: This applies errata 3701771 workaround to Neoverse-V2 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 and is still open.ERRATA_V2_3841324: This applies errata 3841324 workaround to Neoverse-V2 CPU. This needs to be enabled only for revisions r0p0 and r0p1 of the CPU. It is fixed in r0p2.ERRATA_V2_3888126: This applies errata 3888126 workaround to Neoverse-V2 CPU. This needs to be enabled only for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.ERRATA_V2_4302968: This applies errata 4302968 workaround to Neoverse-V2 CPU. This needs to be enabled only for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
For Neoverse V3, the following errata build flags are defined :
ERRATA_V3_2970647: This applies errata 2970647 workaround to Neoverse-V3 CPU. This needs to be enabled for revision r0p0. It is fixed in r0p1.ERRATA_V3_3312417: This applies errata 3312417 workaround to Neoverse-V3 CPU. This needs to be enabled for revisions r0p0 and r0p1 of the CPU and is fixed in r0p2.ERRATA_V3_3696307: This applies errata 3696307 workaround to Neoverse-V3 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V3_3701767: This applies errata 3701767 workaround to Neoverse-V3 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU and is still open.ERRATA_V3_3734562: This applies errata 3734562 workaround to Neoverse-V3 CPU. This needs to be enabled for revisions r0p0 and r0p1 of the CPU and is fixed in r0p2.ERRATA_V3_3782181: This applies errata 3782181 workaround to Neoverse-V3 CPU. This needs to be enabled for revision r0p1 of the CPU and is fixed in r0p2.ERRATA_V3_3864536: This applies errata 3864536 workaround to Neoverse-V3 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU and is still open.ERRATA_V3_3878291: This applies errata 3878291 workaround to Neoverse-V3 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU and is still open.
For Cortex-A710, the following errata build flags are defined :
ERRATA_A710_1785648: This applies erratum 1785648 workaround toCortex-A710 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A710_1793423: This applies erratum 1793423 workaround toCortex-A710 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A710_1847092: This applies erratum 1847092 workaround toCortex-A710 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A710_1887102: This applies erratum 1887102 workaround toCortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r2p0.
ERRATA_A710_1901946: This applies errata 1901946 workaround to Cortex-A710 CPU. This needs to be enabled only for revision r1p0. It has been fixed in r2p0.ERRATA_A710_1916945: This applies errata 1916945 workaround to Cortex-A710 CPU. This needs to be enabled only for revisions r0p0 and r1p0. It has been fixed in r2p0.ERRATA_A710_1917258: This applies errata 1917258 workaround to Cortex-A710 CPU. This needs to be enabled only for revisions r0p0 and r1p0. It has been fixed in r2p0.ERRATA_A710_1927200: This applies errata 1927200 workaround to Cortex-A710 CPU. This needs to be enabled only for revisions r0p0 and r1p0. It has been fixed in r2p0.ERRATA_A710_1987031: This applies errata 1987031 workaround to Cortex-A710 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU. It is still open.ERRATA_A710_2081180: This applies errata 2081180 workaround to Cortex-A710 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU. It is still open.ERRATA_A710_2055002: This applies errata 2055002 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r1p0, r2p0 of the CPU and is still open.ERRATA_A710_2017096: This applies errata 2017096 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is still open.ERRATA_A710_2083908: This applies errata 2083908 workaround to Cortex-A710 CPU. This needs to be enabled for revision r2p0 of the CPU and is still open.ERRATA_A710_2267065: This applies errata 2267065 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is fixed in r2p1.ERRATA_A710_2136059: This applies errata 2136059 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is fixed in r2p1.ERRATA_A710_2147715: This applies errata 2147715 workaround to Cortex-A710 CPU. This needs to be enabled for revision r2p0 of the CPU and is fixed in r2p1.ERRATA_A710_2216384: This applies errata 2216384 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is fixed in r2p1.ERRATA_A710_2282622: This applies errata 2282622 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_A710_2291219: This applies errata 2291219 workaround toCortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is fixed in r2p1.
ERRATA_A710_2008768: This applies errata 2008768 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is fixed in r2p1.ERRATA_A710_2371105: This applies errata 2371105 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0 and r2p0 of the CPU and is fixed in r2p1.ERRATA_A710_2742423: This applies errata 2742423 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_A710_2768515: This applies errata 2768515 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_A710_2778471: This applies errata 2778471 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_A710_3324338: This applies errata 3324338 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_A710_3701772: This applies errata 3701772 workaround to Cortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r2p1 of the CPU and is still open.ERRATA_A710_3888122: This applies erratum 3888122 workaround toCortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r2p1 of the CPU. It is still open.
ERRATA_A710_4302969: This applies erratum 4302969 workaround toCortex-A710 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0, r2p1 of the CPU. It is still open.
For Neoverse N2, the following errata build flags are defined :
ERRATA_N2_2002655: This applies errata 2002655 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2009478: This applies errata 2009478 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2067956: This applies errata 2067956 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2025414: This applies errata 2025414 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2138953: This applies errata 2138953 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 and r0p3 of the Neoverse N2 cpu and is still open.ERRATA_N2_2138956: This applies errata 2138956 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2138958: This applies errata 2138958 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2189731: This applies errata 2189731 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2242400: This applies errata 2242400 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2242415: This applies errata 2242415 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2280757: This applies errata 2280757 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU and is fixed in r0p1.ERRATA_N2_2326639: This applies errata 2326639 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU, it is fixed in r0p1.ERRATA_N2_2340933: This applies errata 2340933 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU, it is fixed in r0p1.ERRATA_N2_2346952: This applies errata 2346952 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU, it is fixed in r0p3.ERRATA_N2_2376738: This applies errata 2376738 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0, r0p1, r0p2, r0p3 and is still open.ERRATA_N2_2388450: This applies errata 2388450 workaround to Neoverse-N2 CPU. This needs to be enabled for revision r0p0 of the CPU, it is fixed in r0p1.ERRATA_N2_2743014: This applies errata 2743014 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is fixed in r0p3.ERRATA_N2_2743089: This applies errata 2743089 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is fixed in r0p3.ERRATA_N2_2779511: This applies errata 2779511 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is fixed in r0p3.ERRATA_N2_3324339: This applies errata 3324339 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and is still open.ERRATA_N2_3099213: This applies errata 3099213 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and is still open.ERRATA_N2_3701773: This applies errata 3701773 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and is still open.ERRATA_N2_3888123: This applies errata 3888123 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and is still open.ERRATA_N2_4302970: This applies errata 4302970 workaround to Neoverse-N2 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and is still open.
For Neoverse N3, the following errata build flags are defined :
ERRATA_N3_3456111: This applies errata 3456111 workaround to Neoverse-N3 CPU. This needs to be enabled for revisions r0p0 and r0p1 and is still open.ERRATA_N3_3699563: This applies errata 3699563 workaround to Neoverse-N3 CPU. This needs to be enabled for revisions r0p0 and is still open.ERRATA_N3_3711915: This applies erratum 3711915 workaround to theNeoverse-N3 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_N3_3866095: This applies erratum 3866095 workaround to theNeoverse-N3 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
For Cortex-X2, the following errata build flags are defined :
ERRATA_X2_1785648: This applies erratum 1785648 workaround to Cortex-X2CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X2_1793423: This applies erratum 1793423 workaround to Cortex-X2CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X2_1863568: This applies erratum 1863568 workaround to Cortex-X2CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X2_1887102: This applies erratum 1887102 workaround to Cortex-X2CPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r2p0.
ERRATA_X2_1887413: This applies erratum 1887413 workaround to Cortex-X2CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X2_1901946: This applies errata 1901946 workaround to Cortex-X2 CPU. This needs to be enabled only for r1p0, it is fixed in r2p0.ERRATA_X2_1916945: This applies errata 1916945 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU, it is fixed in r2p0.ERRATA_X2_1917258: This applies errata 1917258 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU, it is fixed in r2p0.ERRATA_X2_1927200: This applies errata 1927200 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU, it is fixed in r2p0.ERRATA_X2_1934260: This applies errata 1934260 workaround to Cortex-X2 CPU. This needs to be enabled only for revision r1p0 of the CPU, it is fixed in r2p0.ERRATA_X2_2002765: This applies errata 2002765 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2017096: This applies errata 2017096 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2081180: This applies errata 2081180 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2083908: This applies errata 2083908 workaround to Cortex-X2 CPU. This needs to be enabled only for revision r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2136059: This applies errata 2136059 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2147715: This applies errata 2147715 workaround to Cortex-X2 CPU. This needs to be enabled only for revision r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2216384: This applies errata 2216384 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2267065: This applies errata 2267065 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2282622: This applies errata 2282622 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_2291219: This applies errata 2291219 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2371105: This applies errata 2371105 workaround to Cortex-X2 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r2p0 of the CPU, it is fixed in r2p1.ERRATA_X2_2742423: This applies errata 2742423 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_2768515: This applies errata 2768515 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_2778471: This applies errata 2778471 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_3324338: This applies errata 3324338 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_3701772: This applies errata 3701772 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_3888122: This applies errata 3888122 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.ERRATA_X2_4302969: This applies errata 4302969 workaround to Cortex-X2 CPU. This needs to be enabled for revisions r0p0, r1p0, r2p0 and r2p1 of the CPU and is still open.
For Cortex-X3, the following errata build flags are defined :
ERRATA_X3_2138930: This applies erratum 2138930 workaround to Cortex-X3CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X3_2147714: This applies erratum 2147714 workaround to Cortex-X3CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X3_2184829: This applies erratum 2184829 workaround to Cortex-X3CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X3_2214778: This applies erratum 2214778 workaround to Cortex-X3CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_X3_2266875: This applies errata 2266875 workaround to the Cortex-X3 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU, it is fixed in r1p1.ERRATA_X3_2302506: This applies errata 2302506 workaround to the Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r1p1, it is fixed in r1p2.ERRATA_X3_2313909: This applies errata 2313909 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU, it is fixed in r1p1.ERRATA_X3_2372204: This applies errata 2372204 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU, it is fixed in r1p1.ERRATA_X3_2615812: This applies errata 2615812 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r1p1 of the CPU, it is fixed in r1p2.ERRATA_X3_2641945: This applies errata 2641945 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0 and r1p0 of the CPU. It is fixed in r1p1.ERRATA_X3_2742421: This applies errata 2742421 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r1p1. It is fixed in r1p2.ERRATA_X3_2743088: This applies errata 2743088 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r1p1. It is fixed in r1p2.ERRATA_X3_2779509: This applies errata 2779509 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r1p1 of the CPU. It is fixed in r1p2.ERRATA_X3_3213672: This applies errata 3213672 workaround to Cortex-X3 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 of the CPU. It is still open.ERRATA_X3_3692984: This applies errata 3692984 workaround to Cortex-X3 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 of the CPU. It is still open.ERRATA_X3_3701769: This applies errata 3701769 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0, r1p1 and r1p2 of the CPU and it is still open.ERRATA_X3_3827463: This applies errata 3827463 workaround to Cortex-X3 CPU. This needs to be enabled only for revisions r0p0, r1p0 and r1p1 of the CPU. It is fixed in r1p2.ERRATA_X3_3888125: This applies errata 3888125 workaround to Cortex-X3 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 of the CPU. It is still open.ERRATA_X3_4302966: This applies errata 4302966 workaround to Cortex-X3 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2 of the CPU. It is still open.
For Cortex-X4, the following errata build flags are defined :
ERRATA_X4_2302507: This applies erratum 2302507 workaround to Cortex-X4CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X4_2620954: This applies erratum 2620954 workaround to Cortex-X4CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X4_2631888: This applies erratum 2631888 workaround to Cortex-X4CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X4_2646977: This applies erratum 2646977 workaround to Cortex-X4CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X4_2726228: This applies erratum 2726228 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_2740089: This applies errata 2740089 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_2763018: This applies errata 2763018 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_2816013: This applies errata 2816013 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_2897503: This applies errata 2897503 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_2923985: This applies errata 2923985 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_2957258: This applies errata 2957258 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_3076789: This applies errata 3076789 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X4_3133195: This applies errata 3133195 workaround to Cortex-X4 CPU. This needs to be enabled for revision r0p2. It is fixed in r0p3.ERRATA_X4_3701758: This applies errata 3701758 workaround to Cortex-X4 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 and r0p3. It is still open.ERRATA_X4_3841338: This applies erratum 3841338 workaround to Cortex-X4CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_X4_3887999: This applies errata 3887999 workaround to Cortex-X4 CPU. This needs to be enabled for revision r0p0, r0p1, r0p2 and r0p3. It is still open.
For Cortex-X925, the following errata build flags are defined :
ERRATA_X925_2921199: This applies errata 2921199 workaround to Cortex-X925 CPU. This needs to be enabled for revision r0p0. It is fixed in r0p1.ERRATA_X925_2922378: This applies errata 2922378 workaround to Cortex-X925 CPU. This needs to be enabled for revision r0p0. It is fixed in r0p1.ERRATA_X925_2933290: This applies errata 2933290 workaround to Cortex-X925 CPU. This needs to be enabled for revision r0p0. It is fixed in r0p1.ERRATA_X925_2963999: This applies errata 2963999 workaround to Cortex-X925 CPU. This needs to be enabled for revision r0p0. It is fixed in r0p1.ERRATA_X925_3324334: This applies errata 3324334 workaround to Cortex-X925 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X925_3692980: This applies errata 3692980 workaround to Cortex-X925 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X925_3730893: This applies errata 3730893 workaround to Cortex-X925 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X925_3865185: This applies errata 3865185 workaround to Cortex-X925 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_X925_3701747: This applies errata 3701747 workaround to Cortex-X925 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is still open.
For Cortex-A510, the following errata build flags are defined :
ERRATA_A510_1910738: This applies erratum 1910738 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_1937669: This applies erratum 1937669 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_1942494: This applies erratum 1942494 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_1952872: This applies erratum 1952872 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_1966377: This applies erratum 1966377 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_1975068: This applies erratum 1975068 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_1976290: This applies erratum 1976290 workaround toCortex-A510 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A510_2002389: This applies erratum 2002389 workaround toCortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1 of the CPU. It is fixed in r0p2.
ERRATA_A510_2008766: This applies errata 2008766 workaround to Cortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3, r1p0, r1p1, r1p2 and r1p3. It is still open.ERRATA_A510_2027318: This applies erratum 2027318 workaround toCortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1 of the CPU. It is fixed in r0p2.
ERRATA_A510_2028010: This applies erratum 2028010 workaround toCortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1 of the CPU. It is fixed in r0p2.
ERRATA_A510_2288014: This applies errata 2288014 workaround to Cortex-A510 CPU. This needs to be enabled only for revisions r0p0, r0p1, r0p2, r0p3 and r1p0, it is fixed in r1p1.ERRATA_A510_2042739: This applies errata 2042739 workaround to Cortex-A510 CPU. This needs to be enabled only for revisions r0p0, r0p1 and r0p2, it is fixed in r0p3.ERRATA_A510_2041909: This applies errata 2041909 workaround to Cortex-A510 CPU. This needs to be enabled only for revision r0p2 and is fixed in r0p3. The issue is also present in r0p0 and r0p1 but there is no workaround for those revisions.ERRATA_A510_2080326: This applies errata 2080326 workaround to Cortex-A510 CPU. This needs to be enabled only for revision r0p2 and is fixed in r0p3. This issue is also present in r0p0 and r0p1 but there is no workaround for those revisions.ERRATA_A510_2169012: This applies errata 2169012 workaround to Cortex-A510 CPU. This needs to be enabled only for revisions r0p0, r0p1, r0p2, r0p3 and r1p0, it is fixed in r1p1.ERRATA_A510_2218134: This applies errata 2218134 workaround to Cortex-A510 CPU. This needs to be enabled only for revision r1p0 and is fixed in r1p1.ERRATA_A510_2250311: This applies errata 2250311 workaround to Cortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and r1p0, it is fixed in r1p1. This workaround disables MPMM even if ENABLE_MPMM=1.ERRATA_A510_2218950: This applies errata 2218950 workaround to Cortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and r1p0, it is fixed in r1p1.ERRATA_A510_2172148: This applies errata 2172148 workaround to Cortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3 and r1p0, it is fixed in r1p1.ERRATA_A510_2347730: This applies errata 2347730 workaround to Cortex-A510 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3, r1p0 and r1p1. It is fixed in r1p2.ERRATA_A510_2371937: This applies errata 2371937 workaround to Cortex-A510 CPU. This needs to applied for revisions r0p0, r0p1, r0p2, r0p3, r1p0, r1p1, and is fixed in r1p2.ERRATA_A510_2420992: This applies errata 2420992 workaround to Cortex-A510 CPU. This needs to applied for revisions r1p0 and r1p1, and is fixed in r1p2.ERRATA_A510_2666669: This applies errata 2666669 workaround to Cortex-A510 CPU. This needs to applied for revisions r0p0, r0p1, r0p2, r0p3, r1p0, r1p1. It is fixed in r1p2.ERRATA_A510_2684597: This applies erratum 2684597 workaround to Cortex-A510 CPU. This needs to be applied to revision r0p0, r0p1, r0p2, r0p3, r1p0, r1p1 and r1p2. It is fixed in r1p3.ERRATA_A510_2971420: This applies erratum 2971420 workaround to Cortex-A510 CPU. This needs to be applied to revisions r0p1, r0p2, r0p3, r1p0, r1p1, r1p2 and r1p3 and is still open.ERRATA_A510_3672349: This applies erratum 3672349 workaround to Cortex-A510 CPU. This needs to be applied to revisions r0p1, r0p2, r0p3, r1p0, r1p1, r1p2 and r1p3 and is still open.ERRATA_A510_3704847: This applies erratum 3704847 workaround to Cortex-A510 CPU. This needs to be applied to revisions r0p1, r0p2, r0p3, r1p0, r1p1, r1p2 and r1p3 and is still open.ERRATA_A510_4568615: This applies erratum 4568615 workaround to Cortex-A510 CPU. This needs to be applied to all revisions and is still open.
For Cortex-A520, the following errata build flags are defined :
ERRATA_A520_2630792: This applies errata 2630792 workaround to Cortex-A520 CPU. This needs to applied for revisions r0p0, r0p1 of the CPU and is still open.ERRATA_A520_2677201: This applies erratum 2677201 workaround toCortex-A520 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r0p1.
ERRATA_A520_2858100: This applies errata 2858100 workaround to Cortex-A520 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is still open.ERRATA_A520_2938996: This applies errata 2938996 workaround to Cortex-A520 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A520_3631357: This applies erratum 3631357 workaround toCortex-A520 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3, r0p4 of the CPU. It is still open.
ERRATA_A520_3685825: This applies erratum 3685825 workaround toCortex-A520 CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2, r0p3, r0p4 of the CPU. It is still open.
ERRATA_A520_4491980: This applies erratum 4491980 workaround toCortex-A520 CPU. This needs to be applied to all revisions and is still open.
For Cortex-A520_AE, the following errata build flags are defined :
ERRATA_A520_AE_3674306: This applies errata 3674306 workaround to Cortex-A520_AE CPU. This needs to be enabled for revisions r0p0, r0p1. It is still open.ERRATA_A520_AE_3711577: This applies errata 3711577 workaround to Cortex-A520_AE CPU. This needs to be enabled for revisions r0p0, r0p1. It is still open.
For Cortex-A715, the following errata build flags are defined :
ERRATA_A715_2238661: This applies erratum 2238661 workaround toCortex-A715 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A715_2239006: This applies erratum 2239006 workaround toCortex-A715 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A715_2275754: This applies erratum 2275754 workaround toCortex-A715 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A715_2284544: This applies erratum 2284544 workaround toCortex-A715 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A715_2285473: This applies erratum 2285473 workaround toCortex-A715 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A715_2292761: This applies erratum 2292761 workaround toCortex-A715 CPU. This needs to be enabled for revision r0p0 of the CPU. It is fixed in r1p0.
ERRATA_A715_2331818: This applies errata 2331818 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0 and r1p0. It is fixed in r1p1.ERRATA_A715_2344187: This applies errata 2344187 workaround toCortex-A715 CPU. This needs to be enabled for revisions r0p0 and r1p0. It is fixed in r1p1.
ERRATA_A715_2376701: This applies errata 2376701 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0 and r1p0. It is fixed in r1p1.ERRATA_A715_2409570: This applies errata 2409570 workaround to Cortex-A715 CPU. This needs to be enabled only for revision r1p0. It is fixed in r1p1. This errata also applies to r0p0 but that revision has a different workaround, and since r0p0 is not used in production hardware it is not implemented.ERRATA_A715_2413290: This applies errata 2413290 workaround to Cortex-A715 CPU. This needs to be enabled only for revision r1p0 and when SPE(Statistical profiling extension)=True. The errata is fixed in r1p1.ERRATA_A715_2420947: This applies errata 2420947 workaround to Cortex-A715 CPU. This needs to be enabled only for revision r1p0. It is fixed in r1p1.ERRATA_A715_2429384: This applies errata 2429384 workaround to Cortex-A715 CPU. This needs to be enabled for revision r1p0. There is no workaround for revision r0p0. It is fixed in r1p1.ERRATA_A715_2561034: This applies errata 2561034 workaround to Cortex-A715 CPU. This needs to be enabled only for revision r1p0. It is fixed in r1p1.ERRATA_A715_2728106: This applies errata 2728106 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0, r1p0 and r1p1. It is fixed in r1p2.ERRATA_A715_2804830: This applies errata 2804830 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 and r1p2. It is fixed in r1p3.ERRATA_A715_3456084: This applies errata 3456084 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 and r1p3. It is still open.ERRATA_A715_3699560: This applies errata 3699560 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p2 and r1p3. It is still open.ERRATA_A715_3711916: This applies errata 3711916 workaround to Cortex-A715 CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1, r1p2 and r1p3. It is still open.
For Cortex-A720, the following errata build flags are defined :
ERRATA_A720_2729604: This applies errata 2729604 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A720_2792132: This applies errata 2792132 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A720_2844092: This applies errata 2844092 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A720_2926083: This applies errata 2926083 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A720_2940794: This applies errata 2940794 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A720_3456091: This applies errata 3456091 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is still open.ERRATA_A720_3699561: This applies errata 3699561 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is still open.ERRATA_A720_3711910: This applies errata 3711910 workaround to Cortex-A720 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is still open.
For Cortex-A720_AE, the following errata build flags are defined :
ERRATA_A720_AE_3456103: This applies errata 3456103 workaround to Cortex-A720_AE CPU. This needs to be enabled for revisions r0p0 and r0p1. It is still open.ERRATA_A720_AE_3699562: This applies errata 3699562 workaround to Cortex-A720_AE CPU. This needs to be enabled for revisions r0p0. It is still open.
For Cortex-A725, the following errata build flags are defined :
ERRATA_A725_2874943: This applies errata 2874943 workaround to Cortex-A725 CPU. This needs to be enabled for revisions r0p0 when FEAT_SPE is enabled. It is fixed in r0p1.ERRATA_A725_2936490: This applies errata 2936490 workaround to Cortex-A725 CPU. This needs to be enabled for revisions r0p0. It is fixed in r0p1.ERRATA_A725_3456106: This applies errata 3456106 workaround to Cortex-A725 CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2. It is still open.ERRATA_A725_3699564: This applies errata 3699564 workaround to Cortex-A725 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_A725_3711914: This applies errata 3711914 workaround to Cortex-A725 CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.
For C1-Ultra, the following errata build flags are defined :
ERRATA_C1ULTRA_3324333: This applies erratum 3324333 workaround to C1-Ultra CPU. This needs to be enabled for revision r0p0 and is fixed in r1p0.ERRATA_C1ULTRA_3502731: This applies erratum 3502731 workaround to C1-Ultra CPU. This needs to be enabled for revision r0p0 and is fixed in r1p0.ERRATA_C1ULTRA_3658374: This applies erratum 3658374 workaround to C1-Ultra CPU. This needs to be enabled for revisions r0p0 and r1p0 and is still open.ERRATA_C1ULTRA_3684152: This applies erratum 3684152 workaround to C1-Ultra CPU. This needs to be enabled for revision r0p0 and is fixed in r1p0.ERRATA_C1ULTRA_3705939: This applies erratum 3705939 workaround to C1-Ultra CPU. This needs to be enabled for revisions r0p0 and r1p0 and is still open.ERRATA_C1ULTRA_3815514: This applies erratum 3815514 workaround to C1-Ultra CPU. This needs to be enabled for revisions r0p0 and r1p0 and is still open.ERRATA_C1ULTRA_3865171: This applies erratum 3865171 workaround to C1-Ultra CPU. This needs to be enabled for revisions r0p0 and r1p0 and is still open.ERRATA_C1ULTRA_3926381: This applies erratum 3926381 workaround to C1-Ultra CPU. This needs to be enabled for revision r1p0 and is still open.ERRATA_C1ULTRA_4102704: This applies erratum 4102704 workaround to C1-Ultra CPU. This needs to be enabled for revisions r0p0 and r1p0 and is still open.ERRATA_C1ULTRA_4302962: This applies erratum 4302962 workaround to theC1-ULTRA CPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r1p1.
ERRATA_C1ULTRA_4623386: This applies erratum 4623386 workaround to theC1-ULTRA CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 of the CPU. It is still open.
For C1-Premium, the following errata build flags are defined :
ERRATA_C1PREMIUM_3324333: This applies errata 3324333 workaround to C1-Premium CPU. This needs to be enabled for revision r0p0, and is fixed in r1p0.ERRATA_C1PREMIUM_3502731: This applies errata 3502731 workaround to C1-Premium CPU. This needs to be enabled for revision r0p0, and is fixed in r1p0.ERRATA_C1PREMIUM_3684152: This applies errata 3684152 workaround to C1-Premium CPU. This needs to be enabled for revision r0p0, and is fixed in r1p0.ERRATA_C1PREMIUM_3705939: This applies errata 3705939 workaround to C1-Premium CPU. This needs to be enabled for revisions r0p0, r1p0 and is still open.ERRATA_C1PREMIUM_3815514: This applies errata 3815514 workaround to C1-Premium CPU. This needs to be enabled for revisions r0p0, r1p0 and is still open.ERRATA_C1PREMIUM_3865171: This applies errata 3865171 workaround to C1-Premium CPU. This needs to be enabled for revisions r0p0, r1p0 and is still open.ERRATA_C1PREMIUM_3926381: This applies errata 3926381 workaround to C1-Premium CPU. This needs to be enabled for revision r1p0 and is still open.ERRATA_C1PREMIUM_4102704: This applies errata 4102704 workaround to C1-Premium CPU. This needs to be enabled for revisions r0p0, r1p0 and is still open.ERRATA_C1PREMIUM_4302962: This applies erratum 4302962 workaround to theC1-PREMIUM CPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r1p1.
ERRATA_C1PREMIUM_4623386: This applies erratum 4623386 workaround to theC1-PREMIUM CPU. This needs to be enabled for revisions r0p0, r1p0, r1p1 of the CPU. It is still open.
For C1-Pro, the following errata build flags are defined :
ERRATA_C1PRO_3619847: This applies errata 3619847 workaround to C1-Pro CPU. This needs to be enabled only for revision r0p0 and is fixed in r1p0.ERRATA_C1PRO_3338470: This applies errata 3338470 workaround to C1-Pro CPU. This needs to be enabled only for revision r0p0 and is fixed in r1p0.ERRATA_C1PRO_3362007: This applies errata 3362007 workaround to C1-Pro CPU. This needs to be enabled only for revision r0p0 and is fixed in r1p0.ERRATA_C1PRO_3684268: This applies erratum 3684268 workaround to C1-ProCPU. This needs to be enabled for revisions r0p0, r1p0 of the CPU. It is fixed in r1p1.
ERRATA_C1PRO_3686597: This applies errata 3686597 workaround to C1-Pro CPU. This needs to be enabled for revisions r0p0 and r1p0 of the CPU, it is fixed in r1p1.ERRATA_C1PRO_3694158: This applies errata 3694158 workaround to C1-Pro CPU. This needs to be enabled for revisions r0p0, r1p0 and r1p1 and is fixed in r1p2.ERRATA_C1PRO_3706576: This applies errata 3706576 workaround to C1-Pro CPU. This needs to be enabled for revisions r0p0 and r1p0 of the CPU, it is fixed in r1p1.ERRATA_C1PRO_3300099: This applies errata 3300099 workaround to C1-Pro CPU. This needs to be enabled for revisions r0p0 and r1p0 of the CPU, it is fixed in r1p1.ERRATA_C1PRO_3773617: This applies errata 3773617 workaround to C1-Pro CPU. This needs to be enabled for revision r1p1 of the CPU, it is fixed in r1p2.
For C1-Nano, the following errata build flags are defined :
ERRATA_C1NANO_3392149: This applies errata 3392149 workaround to C1-Nano CPU. This needs to be enabled for revision r0p0 and is fixed in r0p1.ERRATA_C1NANO_3419531: This applies errata 3419531 workaround to C1-Nano CPU. This needs to be enabled for revision r0p0 and is fixed in r0p1.ERRATA_C1NANO_3437202: This applies errata 3437202 workaround to C1-Nano CPU. This needs to be enabled for revision r0p0 and is fixed in r0p1.ERRATA_C1NANO_3516455: This applies errata 3516455 workaround to C1-Nano CPU. This needs to be enabled for revision r0p0 and is fixed in r0p1.ERRATA_C1NANO_3616450: This applies errata 3616450 workaround to C1-Nano CPU. This needs to be enabled for revision r0p0 and is fixed in r0p1.ERRATA_C1NANO_3630925: This applies errata 3630925 workaround to C1-Nano CPU. This needs to be enabled for revision r0p0 and is fixed in r0p1.ERRATA_C1NANO_3754876: This applies errata 3754876 workaround to C1-Nano CPU. This needs to be enabled for revisions r0p0 and r0p1, and is fixed in r0p2.ERRATA_C1NANO_4497400: This applies errata 4497400 workaround to C1-Nano CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2. It is fixed in r0p3.
For Neoverse-V3AE, the following errata build flags are defined:
ERRATA_V3AE_3984852: This applies erratum 3984852 workaround to the Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.ERRATA_V3AE_4302965: This applies erratum 4302965 workaround to the Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU. It is still open.
In addition, the following errata build flags are shared with the Neoverse-V3:
ERRATA_V3_2970647: This applies errata 2970647 workaround to Neoverse-V3AE CPU. This needs to be enabled for revision r0p0. It is fixed in r0p1.ERRATA_V3_3312417: This applies errata 3312417 workaround to Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0 and r0p1 of the CPU and is fixed in r0p2.ERRATA_V3_3696307: This applies errata 3696307 workaround to Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0 and r0p1. It is fixed in r0p2.ERRATA_V3_3701767: This applies errata 3701767 workaround to Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0, r0p1, r0p2 of the CPU and is still open.ERRATA_V3_3734562: This applies errata 3734562 workaround to Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0 and r0p1 of the CPU and is fixed in r0p2.ERRATA_V3_3782181: This applies errata 3782181 workaround to Neoverse-V3AE CPU. This needs to be enabled for revision r0p1 of the CPU and is fixed in r0p2.ERRATA_V3_3864536: This applies errata 3864536 workaround to Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU and is still open.ERRATA_V3_3878291: This applies errata 3878291 workaround to Neoverse-V3AE CPU. This needs to be enabled for revisions r0p0, r0p1 and r0p2 of the CPU and is still open.
5.3.3. DSU Errata Workarounds
Similar to CPU errata, TF-A also implements workarounds for DSU (DynamIQ Shared Unit) errata. The DSU errata details can be found in the respective Arm documentation:
Each erratum is identified by an ID, as defined in the DSU errata notice
document. Thus, the build flags which enable/disable the errata workarounds
have the format ERRATA_DSU_<ID>. The implementation and application logic
of DSU errata workarounds are similar to CPU errata workarounds.
For DSU errata, the following build flags are defined:
ERRATA_DSU_798953: This applies errata 798953 workaround for the affected DSU configurations. This errata applies only for those DSUs that revision is r0p0 (on r0p1 it is fixed). However, please note that this workaround results in increased DSU power consumption on idle.ERRATA_DSU_936184: This applies errata 936184 workaround for the affected DSU configurations. This errata applies only for those DSUs that contain the ACP interface and the DSU revision is older than r2p0 (on r2p0 it is fixed). However, please note that this workaround results in increased DSU power consumption on idle.ERRATA_DSU_2313941: This applies errata 2313941 workaround for the affected DSU configurations. This errata applies for those DSUs with revisions r0p0, r1p0, r2p0, r2p1, r3p0, r3p1 and is still open. However, please note that this workaround results in increased DSU power consumption on idle.ERRATA_DSU_2900952: This applies errata 2900952 workaround for the affected DSU-120 configurations. This erratum applies to some r2p0 implementations and is fixed in r2p1. The affected r2p0 implementations are determined by reading the IMP_CLUSTERREVIDR_EL1[1] register bit and making sure it’s clear.
5.3.4. CPU Specific optimizations
This section describes some of the optimizations allowed by the CPU micro architecture that can be enabled by the platform as desired.
SKIP_A57_L1_FLUSH_PWR_DWN: This flag enables an optimization in the Cortex-A57 cluster power down sequence by not flushing the Level 1 data cache. The L1 data cache and the L2 unified cache are inclusive. A flush of the L2 by set/way flushes any dirty lines from the L1 as well. This is a known safe deviation from the Cortex-A57 TRM defined power down sequence. Each Cortex-A57 based platform must make its own decision on whether to use the optimization.A53_DISABLE_NON_TEMPORAL_HINT: This flag disables the cache non-temporal hint. The LDNP/STNP instructions as implemented on Cortex-A53 do not behave in a way most programmers expect, and will most probably result in a significant speed degradation to any code that employs them. The Armv8-A architecture (see Arm DDI 0487A.h, section D3.4.3) allows cores to ignore the non-temporal hint and treat LDNP/STNP as LDP/STP instead. Enabling this flag enforces this behaviour. This needs to be enabled only for revisions <= r0p3 of the CPU and is enabled by default.A57_DISABLE_NON_TEMPORAL_HINT: This flag has the same behaviour asA53_DISABLE_NON_TEMPORAL_HINTbut for Cortex-A57. This needs to be enabled only for revisions <= r1p2 of the CPU and is enabled by default, as recommended in section “4.7 Non-Temporal Loads/Stores” of the Cortex-A57 Software Optimization Guide.- ‘’A57_ENABLE_NON_CACHEABLE_LOAD_FWD’’: This flag enables non-cacheable
streaming enhancement feature for Cortex-A57 CPUs. Platforms can set this bit only if their memory system meets the requirement that cache line fill requests from the Cortex-A57 processor are atomic. Each Cortex-A57 based platform must make its own decision on whether to use the optimization. This flag is disabled by default.
NEOVERSE_Nx_EXTERNAL_LLC: This flag indicates that an external last level cache(LLC) is present in the system, and that the DataSource field on the master CHI interface indicates when data is returned from the LLC. This is used to control how the LL_CACHE* PMU events count. Default value is 0 (Disabled).NEOVERSE_Vx_EXTERNAL_LLC: This flag has the same behaviour asNEOVERSE_Nx_EXTERNAL_LLCbut for Neoverse-V2. This is disabled by default. Default value is 0 (Disabled).NEOVERSE_N2_PREFETCHER_DISABLE: This flag disables the region prefetcher on the Neoverse N2 core. This is used during performance analysis to get clean and repeatable measurements of the cache by preventing speculative data fetches from interfering with benchmark results. Default value is 0 (Disabled).
5.3.5. GIC Errata Workarounds
GIC600_ERRATA_WA_2384374: This flag applies part 2 of errata 2384374 workaround for the affected GIC600 and GIC600-AE implementations. It applies to implementations of GIC600 and GIC600-AE with revisions less than or equal to r1p6 and r0p2 respectively. If the platform sets GICV3_SUPPORT_GIC600, then this flag is enabled; otherwise, it is 0 (Disabled).
Copyright (c) 2014-2026, Arm Limited and Contributors. All rights reserved.
