4.21. Granule Protection Tables Library
This document describes the design of the Granule Protection Tables (GPT) library used by Trusted Firmware-A (TF-A). This library provides the APIs needed to transition granules between different PAS (physical address spaces) at runtime.
4.21.1. Design Concepts and Interfaces
In the runtime initialization step, the runtime firmware locates the existing tables in memory using the GPT register configuration and saves important data to a structure used by the granule transition service which will be covered more below.
In the reference implementation for FVP models, you can find an example runtime
initialization API call gpt_runtime_init in
plat/arm/common/arm_bl31_setup.c.
During the table creation time, the GPT lib opportunistically fuses contiguous
GPT L1 entries having the same PAS. The maximum size of supported contiguous
blocks is defined by RME_GPT_MAX_BLOCK build option.
4.21.1.1. Granule Transition Service
The Granule Transition Service allows memory mapped with
GPT_MAP_REGION_GRANULE ownership to be changed using SMC calls. Non-secure
granules can be transitioned to either realm or secure space, and realm and
secure granules can be transitioned back to non-secure. This library only
allows Level 1 entries to be transitioned. The lib may either shatter
contiguous blocks or fuse adjacent GPT entries to form a contiguous block
opportunistically. Depending on the maximum block size, the fuse operation may
propogate to higher block sizes as allowed by RME Architecture. Thus a higher
maximum block size may have a higher runtime cost due to software operations
that need to be performed for fuse to bigger block sizes. This cost may
be offset by better TLB performance due to the higher block size and platforms
need to make the trade-off decision based on their particular workload.
4.21.1.2. Locking Scheme
During Granule Transition access to L1 tables is controlled by a lock to ensure
that no more than one CPU is allowed to make changes at any given time.
The granularity of the lock is defined by RME_GPT_BITLOCK_BLOCK build option
which defines the size of the memory block protected by one bit of bitlock_t
structure. Setting this option to 0 chooses a single spinlock for all GPT L1
table entries.
4.21.2. Library APIs
The public APIs and types can be found in include/lib/gpt_rme/gpt_rme.h and
this section is intended to provide additional details.
To enable runtime granule transition below APIs must be used:
Firmware must use these APIs after successful RME initiazation.
Firmware must call
gpt_runtime_initto initialize the bitlocks using by legacy GPT library to transition GPI at runtime using delegate/undelegate calls. Granule protection checks must be enabled already or this function will return an error.Firmware must call
gpt_delegate_pastransition a granule from NS PAS to Realm or Secure PAS.Firmware must call
gpt_undelegate_pastransition a granule from Realm or Secure PAS to NS PAS.
4.21.2.1. API Constraints
The platform allocates the bitlock array which contains fine-grained
bitlock_tdata structures. The RME GPT library will check that the array has at least the amount of memory defined by PPS andRME_GPT_BITLOCK_BLOCKvalue.
4.21.2.2. Sample calculation for bitlocks array size
Let PPS=256TB and RME_GPT_BITLOCK_BLOCK=1
The size of bitlocks array in bits is the total protected space (PPS) divided
by the size of memory block per bit. The size of memory block
is RME_GPT_BITLOCK_BLOCK (number of 512MB blocks per bit) times
512MB (0x20000000). This is then divided by the number of bits in bitlock_t
structure (8) to get the size of array in bytes.
In other words, we can find the total size of bitlock_t array
in bytes with PPS / (RME_GPT_BITLOCK_BLOCK * 0x20000000 * 8).
Substitute values to get this: 0x1000000000000 / (1 * 0x20000000 * 8)
And solve to get 0x10000 bytes.
