4.27. CPU Monitor Service Calls
This document enumerates and describes the CPU Monitor Service Calls.
These are Service Calls defined by the implementation of the CPU Monitor. They are accessed via SMC (“SMC calls”) instruction executed from Exception Levels below EL3. SMC calls for CPU Monitor Services:
SMC Function Identifier
Service Type
0x81000000 - 0x8100FFFF
SMC32: CPU Monitor Service Calls
0xC1000000 - 0xC100FFFF
SMC64: CPU Monitor Service Calls
CPU monitor services are as follows:
Service Type
FID’s Usage
0x81000010 - 0x8100001F (SMC32)
CVE-2026-0995 mitigation for C1-Pro CPU
0 is in use. 1 - 15 are Reserved.
0xC1000010 - 0xC100001F (SMC64)
0x81000020 - 0x8100FFFF (SMC32)
Reserved
Reserved
0xC1000020 - 0xC100FFFF (SMC64)
Source definitions for CPU Monitor Service Calls used by TF-A are located in the cpu_svc.h header file.
CPU_SVC_VERSION_MAJOR
CPU_SVC_VERSION_MINOR
Changes
1
0
Added for mitigating for CVE-2026-0995 erratum for C1-Pro CPU .
Table 1: Showing different versions of CPU service and changes done with each version
Each sub service will have its own version, one FID allocated for sub service version.
Some ground rules when one should update top level version.
  • CPU_SVC_VERSION_MAJOR is incremented when any of the sub service version discovery FID changes or the FID that was allocated for discovery changes. So any breaking subfeature discovery changes will lead to major version update.
  • CPU_SVC_VERSION_MINOR is incremented when we add a new FID or a new sub service. For example adding an new monitor service at 0x20.
Copyright (c) 2026, Arm Limited and Contributors. All rights reserved.
