9.14. Advisory TFV-14 (CVE-2026-34879)
BL1 FWU range-check mismatch in FWU_SMC_IMAGE_COPY can cause out-of-range memory access. |
Reported on 16 Jan 2026 |
TF-A releases with BL1 FWU mode enabled prior to the fixes in 48739 and 48740. |
Platforms that enable BL1 FWU mode and expose FWU_SMC_IMAGE_COPY to the Normal World. |
Denial of Service (secure world data abort / reboot loop). |
48739 “fix(bl1): harden FWU copy/auth overflow checks” 48740 “fix(arm): harden FWU address range checks” |
Prasanth Sundararajan https://www.linkedin.com/in/prasanthsundararajan/ |
9.14.1. Description
In BL1 Firmware Update (FWU) mode, the FWU_SMC_IMAGE_COPY path validated image ranges using an overflow check based on (size - 1) but then consumed the full block size in subsequent range checks and memcpy operations. This created a mismatch where certain malformed requests could pass validation and later trigger a memcpy from an invalid or unmapped address.
A compromised Normal World component can issue a malformed FWU_SMC_IMAGE_COPY request while the device is in FWU mode, pass validation, and cause BL1 to attempt to copy from an invalid address. In testing, this results in a BL1 data abort and can lead to a secure-side reboot loop (availability impact).
9.14.2. Exploitability Details
This issue is exploitable only when the device is running in BL1 FWU mode and the FWU_SMC_IMAGE_COPY interface is reachable from the Normal World. An attacker needs control of a Normal World component capable of issuing SMC calls in FWU mode (for example, a compromised bootloader, recovery image, or update agent). No secure-world code execution is required; the attack is performed entirely through crafted FWU requests.
The attacker submits a request with carefully chosen source address and size parameters that pass the legacy range validation but produce a different effective range when the copy occurs. Because the copy uses the full block size, BL1 attempts to read from an invalid or unmapped address, resulting in a secure-world data abort. In practice this yields a denial of service in FWU mode, often observed as a secure-side reboot loop.
9.14.3. Mitigation and Recommendations
The issue is fixed by making overflow and range validation match the actual block size used by bl1_plat_mem_check() and memcpy(), and by validating end-exclusive ranges computed safely from (base + size).
Users should apply the fixes in the commits referenced below and ensure that all TF-A builds enabling BL1 FWU mode include these changes.
