4.27. BL31 Live Firmware Activation
This document outlines the current BL31 support for live firmware activation. Live firmware activation is essentially updating underlying firmware without rebooting the whole system, which can avoid the downtime of a reboot.
This is done by defining a special code section for errata and padding it to a fixed size, so the code in this section can change while reducing the chances that the rest of the compiled firmware is altered.
The current BL31 live activation framework does not replace the entire BL31 image, and instead simply replaces the CPU ops and errata code sections which is less risky and still allows for CPU library errata fixes to be deployed via LFA.
4.27.1. Limitations & Assumptions
At the time of this writing, LFA for BL31 is a proof of concept feature and has some limitations and assumptions that must be respected for it to work properly. The current implementation of BL31 LFA is not intended to be used in production environments and is for evaluation and testing purposes only.
Live Activation of BL31 images is limited to simple errata workarounds in assembly code only. A linker script change has been made to place errata code/data into a contiguous memory range which is padded up to PLAT_LFA_ERRATA_SECTION_SIZE bytes. This allows extra space to be left for errata workarounds to be added without moving anything else around or increasing the size of the image into a new page. This definition should be placed in the platform_def.h file.
Builds should be done using the same system, with the same GCC version, using the same build configuration and flags (except for new errata flags). Even still, it is not 100% guaranteed that the compiler will not change anything, but it is likely that live activation will work.
Warm reboots should be used with live activations to ensure there are no issues with unwinding the stack.
4.27.2. Challenges
The main challenge is ensuring that TF-A builds are capable of live-activation without making an onerous amount of assumptions. Unfortunately, the ways of going about this are not trivial. Longer term, persistent state data in TF-A needs to be identified and placed into a defined data structure at a specific memory address to ensure that it stays in the same place across live activations. This would allow the compiler and linker to move things around while still allowing everything to work properly.
Additionally, we need a way to reliably determine whether an image can be successfully live-activated before attempting it, as an incompatible image will likely result in a crash, wiping out everything and requiring a full system reboot.
4.27.3. Running the Code
Basic LFA testing can be done with TFTF on an FVP model, so to start off build TFTF with the following parameters.
make CROSS_COMPILE=aarch64-none-elf- PLAT=fvp TESTS=lfa all
Then in TF-A, build with these parameters:
make CROSS_COMPILE=aarch64-none-elf- PLAT=fvp LFA_SUPPORT=1 ENABLE_LFA_BL31=1 BL33=path/to/tftf.bin all fip
Once the build is complete, stash the bl1.bin and fip.bin files, make any changes you want to try to live activate in the CPU library, then do the build again. The resulting bl31.bin file is what we will load into FVP memory to load and live activate.
The model used for testing is FVP_Base_RevC-2xAEMvA, other models could be used as well with appropriate build and run parameters.
./FVP_Base_RevC-2xAEMvA \
--data cluster0.cpu0=path/to/new/bl31.bin@0xFB000000 \
-C bp.flashloader0.fname=path/to/fip.bin \
-C bp.secure_memory=1 \
-C bp.secureflashloader.fname=path/to/bl1.bin \
-C cache_state_modelled=0 \
-C cluster0.restriction_on_speculative_execution=2 \
-C cluster1.restriction_on_speculative_execution=2 \
-C pctl.startup=0.0.0.0
