2.4. Experimental Nix flake
The TF-A repository includes an experimental Nix flake that you can use to build known-good configurations of TF-A.
The flake’s interface is preliminary and is likely to change.
2.4.1. Prerequisites
Before using the flake, follow the instructions on the Nix download page to install Nix for your system. You will also need to enable the nix-command and flakes experimental features; Nix’s flake documentation explains how to do this for individual commands, and its configuration reference covers persistent settings.
2.4.2. Discovering configurations
A good place to start is nix flake show, which lists the outputs that the flake provides. Run it from the root of the TF-A repository:
nix flake show
Look under packages for your host system to choose a firmware configuration to build. The host system is the machine on which you will run the build tools; the firmware’s target platform and architecture are selected separately by each configuration.
The examples below assume that you are working from the repository root. Wherever you see <package>, replace it with a package name from the listing for your host system.
2.4.3. Building TF-A
Once you have chosen a package, pass its name to nix build to build that firmware configuration:
nix build '.#<package>'
Here, . refers to your current checkout, and the name after # selects the package.
When it is asked to build a package, Nix takes a snapshot of the source tree and builds it in a separate directory. When you are working in a local Git checkout, this snapshot includes your changes to tracked files, but does not include untracked files. If you add new files, make sure to use git add to include them in the snapshot too; you can build your changes without committing them first.
By convention, TF-A packages provide an out output containing the artifacts that all consumers of TF-A need to build a complete software stack, and a debug output containing artifacts useful for debugging the firmware.
Nix selects the out output by default. When the build succeeds, you can access these artifacts through a symbolic link called result.
If you need a package’s debugging artifacts, you can explicitly request them by building its debug output:
nix build '.#<package>^debug'
You can then access these artifacts through the result-debug symbolic link. If you need both the firmware and its debugging artifacts, you can select all outputs together:
nix build '.#<package>^*'
Both outputs come from the same firmware build. Selecting debug makes the debugging artifacts available, but it does not enable the TF-A DEBUG build option - that is dictated by the package’s firmware configuration.
If you want to follow the build in more detail, add --print-build-logs when running nix build to show log output while it runs.
Copyright (c) 2026, Arm Limited. All rights reserved.
